Author Topic: Another 'help me choose a keyboard" thread - please help  (Read 3831 times)
Offline #1singed
« on: Thu, 26 September 2013, 20:03:10 »
I have about 80 dollars to spend on a mechanical keyboard.
I'm looking at a few keyboards, CM Storm Quickfire TK and Rapid, and Razer Blackwidow Tournament edition
At first I wanted to get the blackwidow, but i heard a lot of people saying razer products are really bad.
So its mostly quickfire rapid vs tk, help me decide between them.
I dig the sound of those cherry mx blues, i love making lots of noise when i type, makes me feel more productive. :p
I like to play osu, are cherry mx blues good for that?
Oh, and I use an imac, so are the cm storms compatible with them?
Offline Thimplum
  • Master of all Ponies
Re: Another 'help me choose a keyboard" thread - please help
« Reply #1 on: Thu, 26 September 2013, 20:26:43 »
If you've got the desk space, go for the TK. As for compatibility, it shouldn't be an issue.
TP4 FOR ADMIN 2013
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Thu, 26 September 2013, 20:27:06 »
If this is your first keyboard I'd probably suggest QuickFire Rapid.  It's more standard layout easier to get used to also later on if you want to change keycap it's easier.
As for iMac, I'm not too sure on that but I think TK has NKRO over USB and usually Mac will have issues with that.
I think QuickFire Rapid is a safer bet.
Offline Thimplum
« Reply #3 on: Thu, 26 September 2013, 20:27:50 »
As for iMac, I'm not too sure on that but I think QuickFire TK has NKRO over USB and usually Mac will have issues with that.
You can change it to 6KRO.
TP4 FOR ADMIN 2013
« Reply #4 on: Thu, 26 September 2013, 20:43:03 »
Desk space? The TK isn't any bigger than QFR is it?
Offline inteli722
« Reply #5 on: Thu, 26 September 2013, 20:51:11 »
Slightly wider.
Unless you NEED the tenkey, I would say go for the QuickFire Rapid, especially since it goes for $55 at times.
Waiting for: Phantom Plate
Offline Tony
« Reply #6 on: Thu, 26 September 2013, 21:14:14 »
QF Rapid. You can always buy a numpad later.
« Reply #7 on: Thu, 26 September 2013, 22:46:16 »
Welcome to Geekhack!
QFR - standard layout (which will make selecting your first set of custom keycaps so much easier), and it works fine with a Mac.
Offline Emospence
« Reply #8 on: Fri, 27 September 2013, 01:24:38 »
+1 Rapid
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline Linkbane
« Reply #9 on: Fri, 27 September 2013, 05:12:50 »
I prefer the TK, because you can still rather easily feel the arrow keys and it has backlighting so you can see your fingers. Of course, I touch type, but it's useful to see what keys your fingers are actually on. Its price is a slight bit higher, but I think that you'll like it. The Rapid is still a great option and cheap ($57 with blues!), but I feel like having a backlit keyboard is nice, along with the numpad functionality if necessary.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline Fragil1ty
  • Abre los ojos.
« Reply #10 on: Fri, 27 September 2013, 05:29:00 »
I had the Blackwidow Elite for the best part of 2 years and never had a problem, when people say that Razer products are bad they make be referring to cheap keyboards, headsets etc, not specifically the Blackwidow line. I personally think that the line of Blackwidow products are very well made.
I'd personally go for the Quickfire Rapid, I think it looks better, it's tenkeyless and I think it comes with MX Cherry Reds if I'm not mistaken.
It's compatible yes, all keyboards are compatible with all operating systems  but  it's just a matter of having the hotkeys work and what not, like I'm pretty sure the hotkeys provided will not work on the mac and obviously the windows key will be replaced by the Mac equivalent.
你搞砸了
Offline zoolzoo
« Reply #11 on: Fri, 27 September 2013, 05:41:41 »
You are going to have more fun with the Rapid!
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
« Reply #12 on: Fri, 27 September 2013, 05:59:31 »
Oh yeah - QFR you can get replacement (black) case tops, and then customise them for the ongoing GH birthday competition thing.
