Author Topic: Question about TKL and smaller boards.  (Read 2964 times)
Offline Exothermic
« on: Sat, 28 September 2013, 21:19:50 »
I have the Razer Naga mouse that I use for WoW, and I have all the side buttons bound to my numpad. If I were to use a keyboard without a numpad, would the computer still register the buttons on my mouse?
Offline bubchi89
Re: Question about TKL and smaller boards.
« Reply #1 on: Sat, 28 September 2013, 21:25:39 »
Hm. Consider unplugging your keyboard entirely and checking if your mouse works
Offline Jixr
« Reply #2 on: Sat, 28 September 2013, 21:31:19 »
I have a QFR TKL and a naga epic, yes, the buttons on your naga will still work fine as a number pad
Offline Exothermic
« Reply #3 on: Sat, 28 September 2013, 21:51:27 »
I wasn't saying I had a problem, I was asking if something would theoretically work.
Offline Exothermic
« Reply #4 on: Sat, 28 September 2013, 21:51:58 »
This is wonderful news! Time to convince people in the household not to judge me if I get another keyboard.
Offline bubchi89
« Reply #5 on: Sat, 28 September 2013, 23:58:12 »
I was trying to do the "teach a man to fish..." thing.
If you unplugged your keyboard I was 100% certain you would've noticed that your mouse still works totally fine. After seeing that, you might have reached the conclusion that your mouse and keyboard aren't tied together at all. Because they're not.
Offline terran5992
  • One With The Cup Rubber
« Reply #6 on: Sun, 29 September 2013, 00:22:47 »
Should have no problem
Offline Exothermic
« Reply #7 on: Sun, 29 September 2013, 08:56:32 »
Oh.... right. Wow now I feel stupid.
Offline babyface
« Reply #8 on: Sun, 29 September 2013, 09:33:26 »
I had a problem using the Naga with the Noppoo Choc Mini, so it is good news to hear TKL works.
It was a problem because the Num Lock toggles some of the alphas.
Where do you get the idea that an LZ-GH is basically a filco??
Offline Exothermic
« Reply #9 on: Sun, 29 September 2013, 13:20:01 »
Idk about you, but I'll probably just plug in some other keyboard to make sure the numlock is on. I can't imagine ever having a situation where I would want it off.
Offline ch_123
« Reply #10 on: Sun, 29 September 2013, 18:48:29 »
In this case, you want the num lock turned off, or some of the alpha keys act as number keys. The same applies to the Model M SSK for example
Offline Exothermic
« Reply #11 on: Sun, 29 September 2013, 19:15:02 »
Oh... so how would it work to have the mouse as a num pad with num lock off? I would probably be getting a poker 2.
