Author Topic: [Shipping to you] "Valentine" Pink & White keyset GB (Cherry font legends)  (Read 119280 times)
Offline jil_jil32
  • Tokyo Press <3
Re: [Taking orders] "White Valentine" doubleshot keyset group buy
« Reply #100 on: Fri, 04 October 2013, 12:55:44 »
Ah for those keys if you think you really need it just give me a note in the order form. If the current kits could be done I think I could provide those separately later for personal request, not 100% certain though. But I will give it a try.
My highest priority is the whole GB, that every kits could be done sucessfully, so the minor details will be discussed and dealt with later. I hope everyone can understand it for me.
Sounds good Jil.  Will the order form be updated with the new kits soon?  I'll be putting in my order once the form has the new kits!
Yes once I get the prices from SP I will update the form and the post #1. May be early next week the soonest.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #101 on: Fri, 04 October 2013, 17:58:51 »
So everyone is happy with the shade of pink from last time?
Offline deSheol
  • Thorpe
« Reply #102 on: Fri, 04 October 2013, 22:29:00 »
Yea, I think a different shade of pink would be better though..
Offline piraterice
« Reply #103 on: Sat, 05 October 2013, 01:12:38 »
I THINK IT IS COMPLICATED AND A LITTLE EXPENSIVE...WHY NOT JUSM MAKE THEM TO BE  87 OR  104 CAPS SET WITH DIFFERENT COLOR?
Offline Neebio
  • Dance Master
« Reply #104 on: Sat, 05 October 2013, 01:42:53 »
I honestly can't tell if this is troll or legitimate. The listed prices are theoretical maximums.  After all is said and done, the prices will likely be quite a bit lower than what is listed now. This is explained in the first and second posts of this thread.
While the kits offered are a little different than other group buys, I would not call it complicated. Request the kits that have the key caps you need to populate the keyboard you have.  The distribution of caps to kits has reached a good point I think.
If you are still unhappy with some aspect of this group buy, I suggest you explain yourself with some reasons, and refrain from caps lock power hours.
RK9000RE w/ Raindrop & DDR arrow keys
Cherry G80-11900LUMEU-2 w/ Red/Black SA keys
Offline jil_jil32
  • Tokyo Press <3
« Reply #105 on: Sat, 05 October 2013, 03:44:43 »
I also though about new shade of pink before but since I knew many people just like the color of the set last year I decided to keep it for this time. It must be great if you and some people said it and supported it while we're at the Interest check phase so we could have it discussed more in detail.
Let's do this GB as for the complete version of the Valentine set that I hope I could have done it since the first time but couldn't cause I didn't have enough experience back at that time. I will learn more about the custom colors and I think we can have new shade of pink after this GB.
Offline Rabbit
« Reply #106 on: Sat, 05 October 2013, 05:47:25 »
 :)I just hope the pink keycaps "IOU""HOME""love" could stay in the pink MODS.
Offline tradet
« Reply #107 on: Mon, 07 October 2013, 12:34:18 »
Just ordered!
Looking forward to having the manliest keyboard in the hood.
Offline jil_jil32
  • Tokyo Press <3
« Reply #108 on: Tue, 08 October 2013, 11:42:48 »
2.3 - PINK mod kit 03 - $38
2.4 - PINK mod kit 04 - $22
3.3 - GREY mod kit 03 - $38
3.4 - GREY mod kit 04 - $30
We have the prices for the new kits.
I also updated the post #1 and the order form so go go go just put your order in now! => http://goo.gl/S1sqnJ
« Last Edit: Tue, 08 October 2013, 11:47:04 by jil_jil32 »
Offline yicaoyimu
« Reply #109 on: Tue, 08 October 2013, 12:10:05 »
Ordered!
I just realised, there is no pink on grey stepped capslock?!  :eek:
Offline Neebio
  • Dance Master
« Reply #110 on: Tue, 08 October 2013, 12:34:13 »
Ordered!  Looking forward to getting my hands on these.
Offline jil_jil32
  • Tokyo Press <3
« Reply #111 on: Tue, 08 October 2013, 12:34:42 »
Ordered!
Yes there is no stepped capslock in the Grey kit. You will have both centered stem and off-centered stem CAPS as full-touch keys (no step)
Offline Kiric
« Reply #112 on: Tue, 08 October 2013, 21:15:17 »
I'm wondering if any spacebar in the white base kit can suit for a leopold keyboard (length 42.5mm to the center stem)
Offline yicaoyimu
« Reply #113 on: Tue, 08 October 2013, 22:50:13 »
I can tell you for sure that it will fit FC200R. And I believe it will fit other ANSI layout Leopold board. But I doubt any spacebar with fit FC660. I am always under the impression that FC660 has weird sized spacebar.
Offline LechnerDE
« Reply #114 on: Wed, 09 October 2013, 01:03:16 »
Yes, it will fit the FC200R but it won't fit the FC500R, FC700R or the FC660M.
For some odd reason Leopold decided not to follow common standards...
Offline jil_jil32
  • Tokyo Press <3
« Reply #115 on: Wed, 09 October 2013, 02:18:53 »
The 6.2x spacebars will fit the FC200R nicely.
And some people asked me why I packed 4 spacebars into the White base, not just 1 or 2? It's because the spacebars will be the superstars of the show this time.
So, order MOAR!!
Offline GeeNDL82
« Reply #116 on: Wed, 09 October 2013, 03:19:38 »
More option, more choice!!!!!!!!!
Order now ...... Order now ...... Order now ...... Order now ...... Order now ...... Order now ...... Order now ...... Order now ...... Order now ......
Vietnam Mechanical Keyboard Club: http://vietnammechkey.com/
Offline Latin00032
Re: [Taking orders] &quot;White Valentine&quot; doubleshot keyset group buy
« Reply #117 on: Wed, 09 October 2013, 05:02:54 »
So, order MOAR!!
I'm not sure if I understand. Why are the spacebars so great?
They don't look special in the mockups.
Are they different colors? Are they different profiles?
Offline jil_jil32
  • Tokyo Press <3
« Reply #118 on: Wed, 09 October 2013, 08:27:36 »
Their color and profile are shown exactly in the mockup. The special thing about them is a little secret that I would like to keep it as a surprise for everyone to find out later heheheh ^.^
Offline Latin00032
« Reply #119 on: Wed, 09 October 2013, 09:39:03 »
I wasn't going to join this gb but now I'm afraid to miss out if the spacebars are as cool as you say they will be.
Offline GeeNDL82
« Reply #120 on: Sat, 12 October 2013, 07:56:59 »
Offline LechnerDE
« Reply #121 on: Sat, 12 October 2013, 08:10:11 »
What is that supposed to mean?
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #122 on: Sat, 12 October 2013, 08:25:14 »
May be he wanna bump. But this is group buy not classfied, GeeNDL82. Please stop it :(.
Offline germy
« Reply #123 on: Sat, 12 October 2013, 08:25:48 »
Is there any particular reason why there couldn't be more transparency on how many kits have been ordered and how far we have to go to the next price tier? That would help sales right?
Online HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #124 on: Sat, 12 October 2013, 08:55:14 »
I think here is the answer germy
Stop derailing the thread to another story of yours fantastic world.
If you've followed the 23 Commando set GB, you will know why I do this kind of fixed prices for better organizing process. The prices now are the maximum amount, join now if you think you can afford it, or wait for some days if you want better prices. People can still have better prices if we can gather enough people, if you READ my previous post you will know it.
And if we're close to a pricebreak (5-10 kits) I will annouce it to attract more people. Is that any different from update every count to waste the time, or can't you realize the fact?
The prices now are for 75-100 sets so why do you want to know the prices for 150-200 sets since we're still at 20-30 sets?
Think before you post anything.
Offline germy
« Reply #125 on: Sat, 12 October 2013, 09:17:48 »
Ah, so its done in the name of efficiency.
Offline zenuty
« Reply #126 on: Sat, 12 October 2013, 21:44:39 »
It looks very strange and conufing about kind of kit
 :-X  :-X  :-X
LINE ID : zenuty
Skype ID : zenuty
www.facebook.com/zenuty
Offline GeeNDL82
« Reply #127 on: Sat, 12 October 2013, 22:11:58 »
Thank for dont understand me  :-*
that's mean i want to buy full pink and gray set. But out of cash.
So.............  >:D
  • Frenzy Classic.
« Reply #128 on: Sat, 12 October 2013, 22:40:10 »
So.............  >:D
That is your problem. That is not associated this group buy.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #129 on: Sun, 13 October 2013, 08:24:13 »
If the space bar is going to have text on it or something, then that could be a bad surprise for some people. Extra keys are an OK surprise, but modified keys from the example not so much.
Also if this is a not for profit group buy then the numbers of sets purchased so far should be available.
Offline dignitasDreAm
« Reply #130 on: Thu, 17 October 2013, 01:10:47 »
ordered. gogo ~
Offline jil_jil32
  • Tokyo Press <3
« Reply #131 on: Thu, 17 October 2013, 10:05:46 »
Yep about one more week and the order status is really slow, I guess we could not make it this time with this GB...
Offline yicaoyimu
« Reply #132 on: Thu, 17 October 2013, 11:13:39 »
No way. I saw a thread on a Chinese forum collecting orders for this set and there are quite a lot of orders. I guess they have not put the orders yet. I'll see what's going on over there.
EDIT: Hold on Jil, the order deadline in that thread is 10/22. Get ready for an order of around 40 sets at that time.
Wait.. Is it something with SP or not having enough orders..
« Last Edit: Thu, 17 October 2013, 11:36:32 by yicaoyimu »
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #133 on: Thu, 17 October 2013, 11:49:38 »
The way you set this up, it makes people not want to order because of the lack of transparency.
Offline MsYutai
« Reply #134 on: Thu, 17 October 2013, 12:35:32 »
I like the look of the set, however, I don't see a set that fulfills my needs in terms of keys... Have to get like 3 different sets and have overlap. O_o
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
Offline Neebio
  • Dance Master
« Reply #135 on: Thu, 17 October 2013, 13:20:18 »
If you're buying for a full keyboard (104~ keys) you will need three kits.  The base, mods, and number pad.  If you're buying for keyboards without a number pad, you should only need the base and one mod kit.  The mod kits are pretty complete as far as what's included.
Are you sure you'll need three kits? (assuming you're not buying for a full size keyboard)
Offline Neebio
  • Dance Master
« Reply #136 on: Thu, 17 October 2013, 13:30:16 »
This.  I mean I'm curious.. How many orders have even been made?  What are the price breaks like and have we reached any of them?  Seeing the numbers like that usually help convince people to order.
Also only showing the maximum price is REALLY discouraging to somebody who doesn't read the whole post and is only looking for numbers.  I understand that the maximum price is not the final price, but it's bad advertising and it's bad marketing.  While it might make your life easier for this group buy, what is better?  Making your life easier, but discouraging buyers?  Or making a bit more work for yourself, and encouraging buyers as well as promoting transparency?
I'm quite certain there's a reason that most all group buys show what the price breaks are like, and show how many orders they've received, because it helps market the group buy to potential buyers.
Not much that can be done about it now though, only a week left, and by the sounds of Jil's post, the damage is done...  Or, maybe if he updates the main post to include the order count as well as price breaks, and extends the deadline a week or two... maybe we'll pull in enough orders to make this a success.
« Last Edit: Thu, 17 October 2013, 13:32:22 by Neebio »
Offline divito
« Reply #137 on: Thu, 17 October 2013, 19:02:47 »
That's part of it for sure I think. I was originally interested, but basically it came to what others have said:
- There are a crazy numbers of kits, requiring 3 just for an average keyboard.
- Extremely odd key groupings, but that's still related to the large quantity of kit options.
- No listing of price breaks.
- No mention of order quantity or progress.
- The posts by the OP are a little hostile, but meh.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline lotus1109
« Reply #138 on: Sun, 20 October 2013, 19:42:23 »
I wish to have a tkl size grey mods with the "I Love You"… is that possible to grab that in 2 kits only? :)
Offline Easonic
« Reply #139 on: Sun, 20 October 2013, 20:38:04 »
more than 40 ,
Offline 눈호랑이
« Reply #140 on: Wed, 23 October 2013, 05:06:57 »
Ordered today :D  (quite expensive, though...)
Offline yicaoyimu
« Reply #141 on: Thu, 24 October 2013, 02:45:27 »
It's Oct 24th already. Is this GB still happening?
Offline jil_jil32
  • Tokyo Press <3
« Reply #142 on: Thu, 24 October 2013, 08:29:21 »
I just received some late orders and the quantity is quite good now, though not enough to run the GB yet. I will need some more time to find a better way to have this GB run, please wait for me about one more week. I will send everyone joined this GB an email about the details.
Offline voice
« Reply #143 on: Thu, 24 October 2013, 09:01:55 »
not enough? :-[
Offline Neebio
  • Dance Master
« Reply #144 on: Mon, 04 November 2013, 17:45:57 »
So what's going on with this?  Update?
Offline kgr0501
« Reply #145 on: Thu, 07 November 2013, 01:05:47 »
Does anyone get any email or PM about this GB? Is this GB not going to make it?
Offline jil_jil32
  • Tokyo Press <3
« Reply #146 on: Sun, 10 November 2013, 04:37:31 »
Dear everyone,
I still have something to do before I can let everyone know about the progress of this... I have limited time but I want to let you know that I'm still working on it!
I want more time to do but I can't ~~
Offline kickaboob
« Reply #147 on: Mon, 11 November 2013, 07:40:10 »
Still taking orders?
Offline zenuty
« Reply #148 on: Tue, 12 November 2013, 05:00:50 »
May I increase my order ?
I wish more add order 1 Set
1 - WHITE base kit - $42
« Last Edit: Tue, 12 November 2013, 05:03:56 by zenuty »
LINE ID : zenuty
Skype ID : zenuty
Offline justnits
« Reply #149 on: Mon, 16 December 2013, 23:54:02 »
i was wondering what happen to this gb here  :eek:
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
