Author Topic: Poker (II)/Ducky Mini layout  (Read 3222 times)
Offline xandr
« on: Wed, 02 October 2013, 06:23:18 »
Would a layout like this be possible with the poker based boards or are they too "hard coded" for that?
I guess if not, the GH60 would be the only option, right?
« Last Edit: Wed, 02 October 2013, 06:31:00 by xandr »
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline spiceBar
    • ChessTiger.com
Re: Poker (II)/Ducky Mini layout
« Reply #1 on: Wed, 02 October 2013, 06:32:54 »
Not possible with the Poker II because the location of the Fn key cannot be changed. And anyway it is not available in ISO.
In theory you can remap the Fn key by soldering wires, but then you also have the Pn key that cannot be programmed, and you are still not in ISO.
I think it's safe to say that the Poker II is not an option for you.
Offline xandr
« Reply #2 on: Wed, 02 October 2013, 06:39:35 »
Yeah, I know the Poker isn't available in ISO. To my knowledge the Ducky Mini is based on it though, so if the reprogramming would be possible with either it should be possible with the other.
Offline spiceBar
    • ChessTiger.com
« Reply #3 on: Wed, 02 October 2013, 07:07:44 »
Maybe you should consider the KBT Pure Pro. It is reprogrammable and available in ISO. I own two and they are good keyboards.
  http://kbtrace.com/kbtpure/kbt-pure/kbt-pure-pro-60-white-light-qwerty-uk.html
« Reply #4 on: Wed, 02 October 2013, 17:50:30 »
who told you that? You can "move" the key with a simple PCB modification.
Offline xandr
« Reply #5 on: Wed, 02 October 2013, 18:26:13 »
The pure pro is no option due to the non-standard bottom row. I work in chat/email based customer support and I wouldn't want to switch between so different layouts all the time.
Offline spiceBar
    • ChessTiger.com
« Reply #6 on: Wed, 02 October 2013, 20:53:05 »
Yes I know, but you also have the Pn key which is a second problem. You would have to relocate two keys and in the end you would miss one key (Pn cannot be intercepted by software).
