Author Topic: Keyboard LEDs  (Read 6718 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Keyboard LEDs
« on: Wed, 02 October 2013, 17:24:13 »
Do keyboard Leds burn out if left on full brightness?
How long should they last?
Offline Photoelectric
Re: Keyboard LEDs
« Reply #1 on: Wed, 02 October 2013, 17:35:35 »
They are rated for thousands upon thousands of hours of operation, so not until they are defective or something goes wrong (like a current spike).
Re: Keyboard LEDs
« Reply #2 on: Wed, 02 October 2013, 17:35:52 »
The LED's are being driven at a fraction of their rated current and should last a few hundred thousand hours.
Offline PointyFox
Re: Keyboard LEDs
« Reply #3 on: Wed, 02 October 2013, 17:37:31 »
Even if they do manage to go out, they are fairly simple to replace.  ~$10 in tools if you don't already have them.
Offline C5Allroad
Re: Keyboard LEDs
« Reply #4 on: Wed, 02 October 2013, 17:41:11 »
Thanks guys! I have used my K90 and never thought about it. But now with my shine 3 I was wondering because of the lighting modes, how long will they last. Well I guess it's no need to worry lol.
Re: Keyboard LEDs
« Reply #5 on: Wed, 02 October 2013, 22:38:06 »
I suspect the caps lock LED in my first Ducky Shine has died :(
Re: Keyboard LEDs
« Reply #6 on: Wed, 02 October 2013, 22:39:07 »
It may be the connection (solder joints).  LEDs generally don't burn out--they fade in brightness over time.  It's accelerated by heat and humidity.
Re: Keyboard LEDs
« Reply #7 on: Thu, 03 October 2013, 05:22:46 »
Thanks - I might have to open it when have a look when I get a chance.
Offline C5Allroad
Re: Keyboard LEDs
« Reply #8 on: Thu, 03 October 2013, 05:49:05 »
How long does if usually take for them to start fading?
Offline mapple
Re: Keyboard LEDs
« Reply #9 on: Thu, 03 October 2013, 06:46:02 »
so why u scream so much?:P
In God We Trust
Re: Keyboard LEDs
« Reply #10 on: Thu, 03 October 2013, 11:39:47 »
They fade all the time--gradually.  Since they are first turned on.  The rate of brightness decay depends on many factors.  With monitor backlight, you may notice a significant decrease after about 10k hour of operation, for example (there are ~9 thousand hours in a year).  3mm LEDs with better cooling conditions--probably longer.  Have a look here:
http://www.theledlight.com/LED101.html
This all depends on initial quality and running conditions, with some LEDs dimming to half of their initial flux output in dramatically shorter times.
Offline C5Allroad
Re: Keyboard LEDs
« Reply #11 on: Thu, 03 October 2013, 16:52:33 »
Interesting. So I see why some people don't really like backlit boards... There are 104 more things that can break. I might just a buy a filco or maybe not since I usually use a board for a year and end buying another.
« Last Edit: Thu, 03 October 2013, 19:18:00 by HUNTERANGEL121 »
Re: Keyboard LEDs
« Reply #12 on: Thu, 03 October 2013, 17:02:03 »
I don't know what you mean by "you guys" :)  Some of us really like backlit keyboards!  ;D
Re: Keyboard LEDs
« Reply #13 on: Thu, 03 October 2013, 17:06:14 »
I no scream!
Interesting. So I see why you guys don't really like backlit boards... There are 104 more things that can break. I might just a buy a filco or maybe not since I usually use a board for a year and end buying another.
Over a period of years, during which the keyboard might get swapped out and thus prolong the life of the LEDs even longer.
Offline acer589
  • Gotta get out of college
Re: Keyboard LEDs
« Reply #14 on: Thu, 03 October 2013, 18:03:46 »
Yeah, it seems like something you don't really need to be worried about.
MX Blue Black Widow Ultimate    MX Black Quickfire Rapid TKL    MX Black Poker II
Offline C5Allroad
Re: Keyboard LEDs
« Reply #15 on: Thu, 03 October 2013, 19:17:38 »
Lol I fixed that now. I wasn't really thinking.
I no scream!
Lol that's a bit obvious don't you think? When I put my ducky on max brightness is that the max the led is designed to be ran at, or is it the maximum a manufacture is allowing the user to have it go up to?
« Last Edit: Thu, 03 October 2013, 19:20:16 by HUNTERANGEL121 »
Offline PointyFox
Re: Keyboard LEDs
« Reply #16 on: Thu, 03 October 2013, 21:27:27 »
I no scream!
Maybe, and yes.
Offline C5Allroad
Re: Keyboard LEDs
« Reply #17 on: Thu, 03 October 2013, 21:41:47 »
Ah ok thanks.
Re: Keyboard LEDs
« Reply #18 on: Sat, 12 October 2013, 20:09:35 »
I swapped keyboards around again, and now that the Ducky is on my Mac the Caps Lock light is working again!
The KeyCool which was on the Mac with the Caps Lock light working is now connected to my server (Ubuntu in text mode) and Caps Lock on that does not work.
So I suspect it is just something Linux is doing, or not doing, that is preventing the LED from lighting.
