Author Topic: And so it begins! QFR Plate mod.  (Read 1972 times)
Offline Reckthor
    • PC Stuff
« on: Wed, 02 October 2013, 19:41:13 »
Took a few passes with the file for each notch.
Offline esoomenona
  • Gnillort?
Re: And so it begins! QFR Plate mod.
« Reply #1 on: Wed, 02 October 2013, 19:44:11 »
Good luck! I hope you manage to finish.
Offline Neo.X
« Reply #2 on: Wed, 02 October 2013, 19:44:25 »
This will be a real time-consuming work, good luck!  :thumb:
All those keyboards will be lost in time....
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #3 on: Wed, 02 October 2013, 19:48:49 »
What is it exactly? Are you making it so that you can open the switch and change the stem and or spring?
Offline Reckthor
    • PC Stuff
« Reply #4 on: Wed, 02 October 2013, 19:49:47 »
Yes sir! I think i will use this bored to test out different switches.
Offline jonathanyu
« Reply #5 on: Wed, 02 October 2013, 20:19:16 »
how long do you take for one switch hole?
Offline C5Allroad
« Reply #6 on: Wed, 02 October 2013, 20:29:06 »
Nice! I might do this to my shine....
Offline jonathanyu
« Reply #7 on: Wed, 02 October 2013, 20:41:43 »
if you want to open the switch on the shine without desoldering anything, you need to mod the switch too
Offline gvfarns
« Reply #8 on: Sun, 06 October 2013, 17:29:17 »
Is this a better approach than using a dremel tool (or small grinding tool with a drill)?
