Author Topic: My Q-Pad 85 MX Red has arrived and...  (Read 1474 times)
Offline mini66
« on: Thu, 03 October 2013, 10:04:38 »
I have tried the Q-Pad 80 MX Blue recently and I must say the blue LED was easier on the eye than the red LED (or is that just psychological). I found with the MX Red all you need is just the slightest touch on the keys, love it just what I wanted! You all know that anyway but I new to getting a descent keyboard :) There is still a noise when you use the keys (taping) but not as much as the MX Blue. I'm not sure I like red LED but I may get used to it... Anyway that's my findings.
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: My Q-Pad 85 MX Red has arrived and...
« Reply #1 on: Thu, 03 October 2013, 19:35:35 »
Grats on the purchase!
If you want it quieter you can buy a set of o-rings that go under the keycap and depending on which you buy it will reduce the travel. They have soft ones which provide some shock absorption that will make it quieter and there is one that is stiffer I believe it's the 50A hardness(someone correct if I'm wrong :D).
Good luck :D.
Offline BliTzKiN
« Reply #2 on: Thu, 03 October 2013, 20:19:02 »
Like what hunter said, a set of orings will dampen that tapping sound, which is the sound of the keys bottoming out. I've never been a fan of red leds, but I guess if you got really distracted by it you can eventually switch them out for other colors as well. Enjoy your new keyboard!
Offline C5Allroad
« Reply #3 on: Thu, 03 October 2013, 20:34:41 »
Maybe even landing pads. But I think they would not allow the leds to shine through the keycaps.
Offline acer589
  • Gotta get out of college
« Reply #4 on: Thu, 03 October 2013, 20:36:14 »
You have any pics? I'm curious.
MX Blue Black Widow Ultimate    MX Black Quickfire Rapid TKL    MX Black Poker II
Offline C5Allroad
« Reply #5 on: Thu, 03 October 2013, 20:37:38 »
Do you mini? I would really like to see your board.
