Author Topic: Topre Confusion  (Read 31869 times)
Offline fuzzybaffy
Re: Topre Confusion
« Reply #100 on: Fri, 11 October 2013, 17:31:49 »
Just because the switch uses rubber, doesn't mean it's cheaper to make.
He's not saying it's cheaper to make, he's saying that it won't last as long. Topre recently upped their lifespan estimate to 50 million, but personally I think these numbers are all kind of bull****. I do know that rubber stiffens with age though, and there is a thread on here regarding old Topre keyboards feeling stiffer than new ones.
You should also probably start saying "Realforce," because there are a few different brands now, and they all seem to be pretty different. A lot of the qualities you're attributing to the Realforce can't be attributed to the other brands.
Well, the argument is about whether or not Topre boards are worth their money. So the point he was trying to make about the rubber, was that rubber is a cheaper material than the plastic used in Cherry MX switches (which may or may not be true; I argued on the other hand that other parts of the Topre switch probably make it more expensive to make than Cherry MX switches).
I don't know... did you look at the pictures of the Vortex PBT's? They look kinda cheap, and I've read reports of some of the space bars coming in warped
They look fine to me, other than the font. I guess we'll find out when more people get them, but I haven't heard anything negative from the few who have a set already. As for warped long keys, that's just what happens with PBT. I'd rather take a little bit of time to straighten out a PBT spacebar than not have one at all, although I understand why some people don't really care about shine that much.
As you say... it remains to be seen.
« Last Edit: Fri, 11 October 2013, 17:38:46 by fuzzybaffy »
Offline Linkbane
Re: Topre Confusion
« Reply #101 on: Fri, 11 October 2013, 21:50:44 »
Incorrect. I made a statement on the actuation mechanism, and I fail to see (as well as others) how you could take that as an insult, unless you find it personally insulting that I say what a Topre board has inside of it. I don't know when you thought that rubber was cheaper than plastic, but it was probably right about the year that plastic was first invented.
Also, about the Vortex caps, you're quite wrong also. They have very thick PBT, as can be evidenced in the picture, which are significantly thicker than that used on the Topre, and saying that they've come in is both a bald-faced lie and implausible, considering that it's stronger and higher quality than those on the Topre. Double-shot, also. By the way, it's quite obviously a lie when you talk about hearing reports of the spacebars coming in warped because very few have come in and no reviews have been posted. I know that you want to convince yourself that Topre is better, but in this aspect, it's not.
I have seen from forum posts, this being an example: "But as said Topre switches tend to get heavier over time as the rubber ages. I think there was an experiment done not too long ago... by Ripster in the name of keyboard science." that Topre become quite unpleasantly stiff as they get older. Topre housing is quite nice and its mechanism is more advanced than that of the Cherry, which neither makes it superior nor, as Topre has said before, more durable.
For weight, you compare against a single brand. The simple fact that a Topre switch is larger and heavier (x87) would probably account for a significant amount of that, but wonderful. It weighs more, that's not indicative of build quality. A Unicomp fullsize weighs 5.5 pounds, so a TKL would weigh at least 3.5, making it much heavier, and in your comparison method, much better than a Topre. Topre falls again.
You're comparing it with a Unicomp, though. Yea, maybe a Unicomp may be heavier, but maybe all the other parts are cheaper to make? From what I've read, its quality is not quite up to par as the original Model M's. So, yea, maybe the Unicomp has the Topre beat when it comes to the weight of the chassis, but all its other parts, such as the switches don't cost as much.
Oh, and when I use the argument rationally with the same comparison, you then tell me that I'm wrong. You said that they were built more solidly on account of their weight.
the increase in build quality is absolutely worth the price of a Topre board, to me.
And this is why I think it's disingenuous, or a half-lie, when people say, Topre are "just rubber dome" boards. Because when they say that, they completely ignore (perhaps on purpose) just how much better built Topre boards are.
Like I said, if someone recognizes the improved build quality of Topre boards, and yet dislike them out of subjective preference, I have absolutely no problem with that. Let's just not lie about what Topre boards are.
How exactly are Topre boards so much higher quality than a Filco, so as to justify even a $100 premium, in the case of the HHKB? Also, which Topre boards are we talking about. I can think of several well-known quality issues with the HHKB and the FC660C.
Well, do you or have you owned a Topre before? You talk as if you've owned the HHKB and FC600C... or did you merely read about the quality issues?
1. Topre boards have a stiffer, and heavier body than Filco boards.
And here is your argument, enshrined so that you might not edit it and that I can provide all of my evidence. However, if you would pay some money for a really strong keyboard and you admit that weight is not what makes a board (even though it is abundant in this one), I suggest this over a Topre: http://www.chassis-plans.com/Rackmount-Keyboard-Displays/MFT-121-Military-Full-Travel-Keyboard.htm You say here that weight and stiffness, which the Unicomp clearly has in spades over the taffee of the Realforces in comparison.
Moreover, you insult other's opinions when you yourself do the same thing. You rely on "reports" of bad vortex caps, while you slam him for reading reviews of the FC660C and other Realforce boards.
So to summarize, you made a lie, by saying "I don't know... did you look at the pictures of the Vortex PBT's? They look kinda cheap, and I've read reports of some of the space bars coming in warped", a pretty pathetic claim when they haven't come in an appreciable number and warping isn't complained about. You then assumed that I was slighting Topre "So the point he was trying to make about the rubber, was that rubber is a cheaper material than the plastic used in Cherry MX switches", embarrassingly wrong as it's quite obvious that I was not when I said "Topre switches use a rubber dome and have a shorter lifespan". These would be two independent ideas, which would be obvious to those educated in the English language.
Please stop. I have never seen a fanboy of any keyboard (Model M, F, Cherry, ALPS, Matias, whatever) continue ragging on about it with such superiority and conviction that they are correct as rabid Topre jerkers.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline Polymer
Re: Topre Confusion
« Reply #102 on: Fri, 11 October 2013, 22:36:08 »
You're right, Topre does use PBT caps. They aren't double shot, and are certainly no thicker than the Vortex PBT which can be bought for abotu $35, and are double shot in any color. So, Topre falls for the third and most resounding time.
You're getting Vortex Doubleshot PBT for 35 a set?  Where?  The GB was for dye subbed...the quality isn't as good either as I'm comparing the two right now..but to be fair, I really think a set of Topre PBTs should be in the 40-50 dollar range(And IMSTO Thick PBT should be cheaper as well).
I don't see how Topre fails w/ their stock keycaps..they're probably the best stock keycaps out there..Solid, not overly thick but dense, well made, clean, well dye subbed fonts....Maybe some would prefer the Ducky Thick PBT but Topre caps are pretty good overall.
As far as comparing it to a Filco..they're completely different boards...To me the price premium comes from the fact that there are just fewer Topre boards out there and there is going to be some sort of price premium.  That plus better stock keycaps (regardless of what you think of them, they're better than the ABS caps that Filco comes with) equals a more expensive board.  Is it better? Is it worth it?  That is all personal preference.  If you like Topre switches, you don't have too many options out there.
Offline Linkbane
Re: Topre Confusion
« Reply #103 on: Fri, 11 October 2013, 23:11:07 »
You obviously haven't been on geekhack for the last month. http://geekhack.org/index.php?topic=48932.0 for any color, and it was less on MassDrop. $33 for a 104 keyset, which is made better and which higher quality (doubleshot and thickness) than Topre. Topre PBT is worse than Vortex, and if its cost differential is $100+ (difference between Type Heaven/Realforce), that's pretty laughable. Feng's best caps aren't that expensive, and Topre PBT is nothing special. Worse than Vortex, and well over three times its price.
Offline muad
Re: Topre Confusion
« Reply #104 on: Fri, 11 October 2013, 23:57:31 »
It doesn't matter what those caps are made out of... with that font I wouldn't take them for free.
Offline Polymer
Re: Topre Confusion
« Reply #105 on: Sat, 12 October 2013, 00:12:53 »
Ok well I didn't see these but that is cool.  But if you're saying the Vortex ones are better, I don't know if you've actually seen the quality from them but it is far from great (going by previous sets).  Again, thickness is good, it isn't everything...Doubleshot PBT IS cool though..I think that is pretty damn nice that they're doing it.  But as far as which is better...Font, overall quality...I'd take the Topre set every time..by my own personal preference.
Again, it isn't just the keycaps (I see how you didn't mention the Filco ABS keycaps in this discussion or any stock keycaps), it also they're not that common which ends up adding a premium.
Which would I prefer?  Type Heaven or RF?  There isn't even a question in my mind...RF, everyday all day...
Which would I prefer?  Topre or Filco?  Depends on what it is for...gaming or typing...
« Last Edit: Sat, 12 October 2013, 00:15:55 by Polymer »
Offline Linkbane
Re: Topre Confusion
« Reply #106 on: Sat, 12 October 2013, 00:25:23 »
Yes, it's quite easy to point out what I didn't mention because I am unable to spend all of my time rebuffing fanboys from celebrating victory by default by another user astounded by their persistent irritation.
Also, any previous tests are rather worthless, because they aren't made the same way, and in fact are completely different. They were made differently, and are of different thicknesses, the newer being thicker than the dye-sub. I'm sure you would pick the Topre keycaps, because one, the MX caps wouldn't fit it, and two, it's just a support of your argument that has no basis in fact.
I don't know anything about Filco caps. I would think that they are nice, because people comment on how nice it is to type on them, but I'm hardly an expert on ABS or any kind of cap, for that matter. All I know is that the Realforce brand and caps are incredibly overpriced.
Obviously one would prefer the Realforce, it has PBT caps and comes in 999 different flavors. But most people who get it just want to try a Topre, and realize that it's not worth blowing $110 on a set of PBT keycaps at all.
It really doesn't matter what you or I prefer, because we're debating a topic, and your opinion is no better than mine. If I stated the opposite, that the Type Heaven was much better than the Realforce, and that the Topre caps are garbage, it would be the same as you singing their praises, but I won't do that, because it's obvious bias.
Offline unicomp_uc
  • Interboardal Love
Re: Topre Confusion
« Reply #107 on: Sat, 12 October 2013, 00:35:26 »
can't we all just get along.  These are all opinion based replies. Even the factual variables have subjective real world effects on people. Click in peace and clack courteously.
Realforce 87U Silent (work) | HHKB Pro 2 | Filco Minila browns | Unicomp Ultra Classic
Offline Polymer
Re: Topre Confusion
« Reply #108 on: Sat, 12 October 2013, 01:10:14 »
First off...I like Cherry MX boards..and I've stated several times, if I only have to get one keyboard, it would be Cherry because I hate Topre for gaming....but since I don't have to pick just one, I enjoy BOTH.
Secondly..I have previous Vortex PBT caps...maybe the Doubleshots are better..they look similar...So I actually do own both and can do a side by side comparison with my RF keycaps..I have no reason to prefer one over the other...So wrong on both parts..
And I agree, RF keycaps sets ARE overpriced.  They carry a premium and I hate it....Do I think they're worth more than 30 dollars?  Yes..do I think they're worth 100?  No...as I've stated, 40-50 is probably where *I* think they should be...
So why is Topre stuff more expensive?  As I said before, a lot of because it isn't as common....so it carries a premium..whereas Cherry MX is much more of a commodity.
To be honest, it sounds like you're forming an opinion based on nothing but what you're reading and making a generic statement.  As in, PBT + Doubleshot must be better..but have you seen them yet?  Have you seen ANY vortex PBT keycaps in person for that matter?  Or Topre keycaps?  No issues with opinions about stuff but half the time GHers have strong opinions about stuff they've never even tried or seen in person....and when they talk about stuff it sounds like that...so is that persons opinion even valid?  Not really...cause they're blowing it out their behind..
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: Topre Confusion
« Reply #109 on: Sat, 12 October 2013, 01:45:43 »
Topre switches use a rubber dome and have a shorter lifespan (30 vs 50 million) keystrokes than any MX switch, so you're incorrect there.
Topre is not superior to any other mechanical keyboard. I think that I'm safe in saying that anyone would rather have a mediocre board with the keyswitch that they prefer using than a strong aluminum, decorated and pimped keyboard with their most hated switch. It's about typing, not about whose keyboard stands up the best in a fight. I doubt that any keyboard warrior here would be more rough with their keyboard than slapping it in anger, and any steel-plated keyboard will take that just fine. Weight holds absolutely no weight.
Sorry but this is the post of a fanboy.  If you want to discuss something like this try not being a jerk.
Offline Linkbane
Re: Topre Confusion
« Reply #110 on: Sat, 12 October 2013, 01:59:06 »
Others agree with my opinion. I see a fanboy, and therefore wish to prove him incorrect. I'll stop if it's against the mods' wills, but it's improper for you to come down and judge fanboyism. I gave a much more unbiased view of things, so if you want to go call fanboy, do it to someone else. I can't stand having an idiotic opinion promulgated without proof over all others and not have it shut down.
Offline Michael
  • Formerly Bro Caps
Re: Topre Confusion
« Reply #111 on: Sat, 12 October 2013, 02:06:53 »
Except you contradict yourself when you say your 'opinions' are unbiased. Being YOUR opinion, it is biased. Completely. You feel your opinion is the most important in every thread I have seen you post in.
You spread your opinions all over the boards, looking for a conflict. It's a good thing I don't see anyone here really taking you seriously, because that would be scary.
Offline Polymer
Re: Topre Confusion
« Reply #112 on: Sat, 12 October 2013, 02:14:36 »
Not only that, from what I can tell he has very strong opinions about equipment he's never actually used...Maybe I'm wrong....
Offline hashbaz
  • Grand Ancient One
Re: Topre Confusion
« Reply #113 on: Sat, 12 October 2013, 02:22:32 »
I'm speaking as a forum member not a mod.  In thread after thread you are abrasive and condescending.  It's not something I'd moderate but it's something I'd call out.  Your opinions are as subjective as anyone else's, yet you state them rudely as fact.  You play fast and loose with logic and you grossly misrepresent what people say and mean.
It's ok that you don't like Topre switches.  Stop trying to demonstrate to those that prefer them that they are wrong.
Offline fuzzybaffy
Re: Topre Confusion
« Reply #114 on: Sat, 12 October 2013, 03:24:42 »
I have no idea where you're getting the idea that I was offended with what you said about Topre having rubber in their switches. Yes, Topre do indeed have rubber in their switches, it is a fact. It is not something I feel insulted by.
Reading comprehension fail #1.
I hope you remember, the whole point of our argument, is to argue whether or not Topre boards are worth the price premium. As I understand it, you're trying to argue that Topre are NOT worth the price premium, so I thought you brought up the fact that Topre boards have rubber, to make the claim that it isn't worth the price (I, on the other hand, as mentioned before, believe Topre boards are worth the price because there are other aspects of Topre switches, which I think are higher quality).
You seem to have missed the two links that I posted, where users specifically say, their Vortex PBT keycap spacebars came in warped:
http://geekhack.org/index.php?topic=37999.msg912701#msg912701
http://geekhack.org/index.php?topic=37999.msg912998#msg912998
(For some reason, my browser has a problem with going to link #2; it goes to the wrong post, for some reason, but look up reply #646 in that thread).
Reading comprehension fail #2. You are proving yourself as someone who doesn't read what he responds to carefully, and therefore has no idea what he's talking about.
They have very thick PBT, as can be evidenced in the picture, which are significantly thicker than that used on the Topre, and saying that they've come in is both a bald-faced lie and implausible.
Read the links that I posted above. People are saying they've received theirs. Is that me lying, or you completely missing on what's being said around here?
Reading comprehension fail #3.
What you're saying doesn't make sense. You admit Topre housing is quite nice, and its mechanism is more advanced than that of Cherry, but that doesn't make it more superior?
In my opinion (notice the words "in my opinion"), it does make the keyboard superior, because it provides a MUCH, MUCH smoother typing experience than Cherry MX switches. If you haven't used Topre switches before, why are you commenting on it?
As far as durability goes, the durability is going to depend on the rubber, no matter how much better quality the housing and mechanism are. Ok, so maybe Topre switches won't last longer than Cherry MX switches. But because of their superior housing and switch mechanism, Topre switches provide a smoother typing feel, so I like Topre better. And this is why I think Topre boards are worth their money.
No, if you read what I said about Topre vs. Filco boards, I specifically wrote:
I did write the word "stiffer", as an addition to "heavier", which implicates stiffness and weight as two separate characteristics, not correlated characteristics. In other words, what I wrote should tell you, that I'm open to the possibility that something may be stiffer, yet lighter, or something being heavier, yet weaker. So, my point was, yes, maybe a Unicomp is heavier, but has overall more shoddy construction, which would explain its cheaper pricing. Topre boards are BOTH stiffer and heavier than Filco boards, which would probably explain its higher price over Filco boards.
Reading comprehension fail #4.
What? I don't understand what you wrote there. Also, notice that weight and stiffness were only 1 of the 3 points I made, about Topre being of higher quality. The reasons why I like Topre boards include characteristics other than just weight and stiffness.
Reading comprehension fail #5, plus purposefully misinterpreting what I write.
No... I'm bringing up reports of bad Vortex caps, because you guys are bringing up reports of bad Topre boards, and making opinions on them without even owning them.
So you want me to stop commenting on the Vortex caps? Then stop stop commenting on Topre boards when you haven't even owned them.
Yea... this will be my third time mentioning the links, where people complain about warped Vortex spacebars:
I'm not lying here. You clearly don't read everything what people say.
I was making a point about how Topre boards are worth their money, and you respond by saying, that since Topre switches use rubber dome, they are not worth their money. I have no idea how you'd make the inference that Topre are not worth their money, by referring to parts that are more expensive. Clearly, your intention was to bring up a part that is seemingly cheaper to make (in this case, the rubber), to try to prove that Topre are not worth their money.
You don't even understand what YOU write yourself. Reading comprehension fail #6. Or you're just lying.
Plus personal attacks.
And... I've never seen someone get so offended about someone liking a Topre board before.
So, people can't talk about how much they like Topre boards, but you can talk about how you dislike Topre all you want? Not sure that's fair.
As far as I can tell, it's YOU who has a problem with people who like Topre. You can say "opinions are subjective" as much as you want, but you're only saying that to disregard other people's preferences for Topre, which is hypocrisy in and of itself.
That said, I wasn't even here trying to talk about how much "better" Topre is than other boards. I was just trying to show why Topre boards might be more expensive than others: namely, its construction, quality of keycaps, and quality of switches. If you want to argue about these, fine; it'll be an argument about facts.
I have no idea why this even turned into an argument about what's "better". That's an argument you decided to bring up, which tells us it's you who has the problem.
« Last Edit: Sat, 12 October 2013, 04:31:46 by fuzzybaffy »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Topre Confusion
« Reply #115 on: Sat, 12 October 2013, 03:24:56 »
« Last Edit: Sat, 12 October 2013, 03:27:35 by VesperSAINT »
Offline unicomp_uc
  • Interboardal Love
Re: Topre Confusion
« Reply #116 on: Sat, 12 October 2013, 14:31:19 »
Thread ender. Time of death, 3:30pm est
Offline Thimplum
  • Master of all Ponies
Re: Topre Confusion
« Reply #117 on: Sat, 12 October 2013, 16:38:33 »
This. I'd don't like Topre either, but don't be so shove-y about it. I used to do that too, but then I realized that it made me look really dumb.
TP4 FOR ADMIN 2013
Offline jmchargue
Re: Topre Confusion
« Reply #118 on: Mon, 09 December 2013, 16:15:44 »
I'm in Aurora, but all I got are ErgoDoxes with Clears.
Yeah! Colorado! And sorry to revive this thread, but relevant: found someone to trade my HH for an ergodox with clears. After all the typing I've done on the HH, I have grown to love how it feels. I'm trading it because my hands and wrists are starting to hurt, and I need these for important things, like working, playing the violin, and jacking off.
Re: Topre Confusion
« Reply #119 on: Mon, 09 December 2013, 16:21:41 »
I think those last two might be related....
Re: Topre Confusion
« Reply #120 on: Mon, 09 December 2013, 16:32:38 »
Unless he is employed as a musician, or in the film industry?
Re: Topre Confusion
« Reply #121 on: Sat, 14 December 2013, 07:56:51 »
why not both!
Offline Canious
Re: Topre Confusion
« Reply #122 on: Sat, 14 December 2013, 21:29:31 »
I didn't get it too until i got one and started *thock*thock*thock*
Not sure if i can ever go back now.
Re: Topre Confusion
« Reply #123 on: Sat, 14 December 2013, 22:04:58 »
Offline reziak
  • Topre/60% Enthusiast
Re: Topre Confusion
« Reply #124 on: Sun, 15 December 2013, 02:09:39 »
If you can't tell the difference in feel between a Macbook's scissor switches and Topre switches (I'm not talking about quality or making a value judgment about which is better, I'm talking about how they physically feel different), then I'm not sure anyone here can help you :(
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline tbc
Re: Topre Confusion
« Reply #125 on: Sun, 15 December 2013, 02:41:08 »
That's actually most of the population.
People hammer their keys completely murdering any tactility and force requirement differences.
You need a typewriter ala clears and greens weights before people notice something.
Offline Canious
Re: Topre Confusion
« Reply #126 on: Sun, 15 December 2013, 05:21:57 »
