Author Topic: Apple Extended Keyboard - Mods ? - Is it Worth at All ?  (Read 56705 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« on: Sun, 06 October 2013, 19:51:00 »
Apple Ext. Mods -  Post Yours !
*  Let The Skull Return  -  Oldies Mods, TransAnimation, CPR    >  https://geekhack.org/index.php?topic=49408.0
37985-0
37989-1
37987-2
37991-3
« Last Edit: Tue, 05 May 2015, 07:29:31 by sprit »
Offline Sniping
Re: Apple Ext. Mod's
« Reply #1 on: Sun, 06 October 2013, 20:00:41 »
Wow, that's very nice. Thinking of adding those colored keycaps to the new board?
Re: Apple Ext. Mod's ~
« Reply #2 on: Sun, 06 October 2013, 20:18:50 »
Interesting.
And these still function as Apple keyboards?
Have they USB connection?
Offline sprit
« Reply #3 on: Sun, 06 October 2013, 20:34:11 »
Hello!   Yes, USB mod.  :)
Offline Michael
  • Formerly Bro Caps
« Reply #4 on: Sun, 06 October 2013, 20:47:04 »
Can you condense your plethora of posts in here to one place?....
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #5 on: Sun, 06 October 2013, 21:42:31 »
beautiful! love the colors! on the AEK2!
Offline mkawa
« Reply #6 on: Sun, 06 October 2013, 21:42:39 »
is that RIT dye?
Offline Steven
  • Formerly lowyatguy
« Reply #7 on: Sun, 06 October 2013, 22:24:40 »
Those Apple keyboards in the first 3 pics, I have nv seen them before. I like the third one most, what is that keyboard called?
LF: Duck Mini V1 aka Duck Poker Case
http://geekhack.org/index.php?topic=49840.0
KMAC Happy | Hammer Poker Titanium & Silver | Leopold FC660M | FILCO TKL White | Ducky 9008S2 Pink | Ducky 9008G2 Pro Dye Sub | Ducky YOTD
Offline sprit
« Reply #8 on: Mon, 07 October 2013, 01:11:16 »
is that RIT dye?
Hello~  dylon dye.
Offline sprit
« Reply #9 on: Mon, 07 October 2013, 01:12:14 »
Sure, I'd love to
Offline sprit
« Reply #10 on: Mon, 07 October 2013, 01:13:51 »
Hello!! Nice to Meet You~  Sorry for That.  Newbie's fault
Offline Dubsgalore
« Reply #11 on: Mon, 07 October 2013, 01:14:46 »
Everyone is a newbie at one point  :)) :)) :cool:
Offline sprit
« Reply #12 on: Mon, 07 October 2013, 01:16:30 »
Cut and mod the apple PCB and Case.  Put some LED's backside.
« Reply #13 on: Mon, 07 October 2013, 06:49:22 »
That's beautiful! I like the dyed number keys for showing the function key groups.
BTW, that is the AEKII, not the AEK, right? If it was the AEK, then the rainbow Apple logo would still be on the left side of the keyboard.
Offline sprit
« Reply #14 on: Mon, 07 October 2013, 07:03:44 »
Allo !  Gut to see You!  Yes Right!   It is II,  a little bit  modified to Alps White Click  SW.
« Last Edit: Sat, 12 October 2013, 06:27:26 by sprit »
Offline lewi
« Reply #15 on: Mon, 07 October 2013, 07:54:54 »
와우 이츠 리알리 뷰리뽀으
하어빳 마 잉글리시 마 푸렌?
Offline Grimey
« Reply #16 on: Mon, 07 October 2013, 11:21:41 »
I would very much appreciate some photographs of the modified PCBs if possible, thanks.
Erlang your pants off
« Reply #17 on: Mon, 07 October 2013, 11:46:11 »
I would like this as well. I have an AEK just itching to be transformed into one of these beauties.
Offline sprit
« Reply #18 on: Mon, 07 October 2013, 21:41:25 »
updated some  Apple Ext photos.
I will post PCB wiring and case rebuilding soon.  Thanks a lot !!
« Last Edit: Tue, 08 October 2013, 07:43:55 by sprit »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #19 on: Tue, 08 October 2013, 10:42:35 »
What 60% keyboard are you using to get that layout?
Offline sprit
« Reply #20 on: Tue, 08 October 2013, 10:48:01 »
Hello !   Apple Ext II  PCB  cut as  Apple Mini - 39.jpg   and wired to a USB controller.
Working on now, I'll post quite soon !
Here is a little bit different example, wired to an internal USB controller,  saving ADB ports,  ADB-USB terminated cable, LED lighting.
« Last Edit: Sat, 12 October 2013, 06:15:03 by sprit »
Offline mashby
    • Mashby
« Reply #21 on: Tue, 08 October 2013, 12:22:05 »
So this keyboard is a cut down Apple PCB?
Offline sprit
« Reply #22 on: Tue, 08 October 2013, 12:29:25 »
Yes Right!   Cut down the Apple PCB, put it into a Poker case.  = Both are the standard layout.
As you know, keycaps  for the Apple Ext 1 and 2 are identical. Here are another working PCB's.
38268-0
« Last Edit: Tue, 15 October 2013, 05:40:36 by sprit »
Offline mashby
    • Mashby
Re: Apple Ext. Mod's - Is It Worth ?
« Reply #23 on: Wed, 09 October 2013, 07:39:04 »
Offline sprit
« Reply #24 on: Thu, 10 October 2013, 01:04:15 »
Working on more simple wiring, and trying another USB controller. Now post a rough wiring concept.
Can I post the detail later?   I need some more.
38462-0
A Rough Wiring Schema.
« Last Edit: Wed, 16 October 2013, 20:40:12 by sprit »
Offline sprit
Re: Apple Ext. Mods - Is It Worth At All?
« Reply #25 on: Fri, 11 October 2013, 08:04:37 »
         Another Apple to bite !    internal USB Controller. LED mod control.
38630-0
« Last Edit: Wed, 16 October 2013, 05:08:30 by sprit »
Offline mashby
    • Mashby
« Reply #26 on: Fri, 11 October 2013, 09:06:11 »
How do you mount the PCB into the case?
Offline sprit
« Reply #27 on: Fri, 11 October 2013, 09:25:49 »
Hello!  How are You?  :)  Need a little drilling .    A whole New PCB is being prepared as I replied up there.
« Last Edit: Fri, 11 October 2013, 12:18:21 by sprit »
Offline sprit
Born in 87 and 07
« Reply #28 on: Fri, 11 October 2013, 13:35:47 »
 38688-0
 38690-1
                        I loved You then, my blood was ......
« Last Edit: Sun, 20 October 2013, 05:13:45 by sprit »
Offline sprit
« Reply #29 on: Sat, 12 October 2013, 14:14:31 »
와우 이츠 리알리 뷰리뽀으       = Wow she's really Beautiful
하어빳 마 잉글리시 마 푸렌?         = How about ma English, ma Friend?  Kangnam style~
I love You my bro,  Lewi   :-*       You are The Maximus Ultimus Lingusticus!    :thumb:
« Last Edit: Mon, 14 October 2013, 23:51:25 by sprit »
Offline sprit
Re: Apple Extended Keyboard II - Mods ? - Is It Worth At All?
« Reply #30 on: Mon, 14 October 2013, 23:46:57 »
   Another Mod  by 다리  Dari,  a korean keyboard lover.   Dell, Omnikey with LZ usb controller.
      bottom is Apple standard 0116.   http://commons.wikimedia.org/wiki/File:Apple_(Standard)_Keyboard_M0116.jpg
        http://www1.kbdmania.net/xe/photo/7500491
39397-0          39146-1
« Last Edit: Wed, 16 October 2013, 20:20:57 by sprit »
Offline mashby
    • Mashby
« Reply #31 on: Tue, 15 October 2013, 11:08:09 »
Looking good!
« Reply #32 on: Tue, 15 October 2013, 18:58:55 »
Oh.. you cut away a part of the main PCB to make the controller fit!
Offline sprit
« Reply #33 on: Wed, 16 October 2013, 20:13:04 »
LED mod by Dari 다리,  a committed  ALPS Lover.
        http://www1.kbdmania.net/xe/photo/7510321
39533-0   39535-1
« Last Edit: Thu, 17 October 2013, 01:28:57 by sprit »
Re: Apple Extended Keyboard II - Mods ? - Is it Worth at All?
« Reply #34 on: Sat, 19 October 2013, 22:06:25 »
I am not really a fan of multicoloured keys or of backlighting... but the multicoloured numerical keys gave me an idea:
If you have a compact keyboard, you could make the number keys light up with red, green and blue LEDs when you press the Fn key.
Not easy if you have other backlighting also, because while White/Red 3mm bicolor LEDs seem to be available, White/Blue and White/Green are not.
« Last Edit: Sun, 20 October 2013, 03:39:14 by Findecanor »
Offline sprit
« Reply #35 on: Sun, 20 October 2013, 05:17:24 »
tack så mycket !!   I will try it definitely !    :)
« Last Edit: Sun, 20 October 2013, 22:48:55 by sprit »
Offline BakaPhoenix
Re: Apple Extended Keyboard II - Mods ? - Is it Worth at All ?
« Reply #36 on: Sat, 26 October 2013, 09:28:33 »
Wow nice work, i really like it  :thumb:
Offline sprit
« Reply #37 on: Wed, 30 October 2013, 19:20:20 »
Apple Extended  Back View!     Am I  pretty?
41811-0
« Last Edit: Fri, 01 May 2015, 02:12:43 by sprit »
Offline sprit
« Reply #38 on: Fri, 01 May 2015, 02:14:17 »
Alps custom springs IC is ON  :   https://geekhack.org/index.php?topic=71357.0
A Groupbuy for the Simplified Alps switches may open in June after enough discussion and mind sharing.
ALPS  Custom Springs  IC  >    http://goo.gl/forms/tSoTFlM3hB
99041-0
« Last Edit: Fri, 01 May 2015, 02:16:38 by sprit »
Offline Yoe
  • Alps & ISO <3
« Reply #39 on: Fri, 01 May 2015, 05:09:35 »
Just finished my AEKII - Orange mod - yesterday. Replaced the dampened white Alps with orange alps. Replaced the green leds with orange ones with a bit more oomph. Finally dyed keycaps in those lovely orange/yellow colors from my previous board. Ta-daa! :)
« Last Edit: Fri, 01 May 2015, 05:23:00 by Yoe »
Offline Hzza
« Reply #40 on: Fri, 01 May 2015, 05:25:49 »
Great mods guys.
I've had an idea for an Apple Adjustable mod I've been kicking around for a while, it'll probably be a good while before I get a chance to do anything with it though.
I'll keep popping back in here for inspiration :D.
Offline wakko
Re: Apple Extended Keyboard - Mods ? - Is it Worth at All ?
« Reply #41 on: Wed, 06 May 2015, 19:02:30 »
For Apple mini, when you cut the pcb, what did you do about broken connections? Pics? Thanks.
NOOB
KUL ES-87
Offline Paranoid
« Reply #42 on: Sat, 16 May 2015, 14:55:59 »
Anyone have a good guide for dying with Dylon? Or is it pretty similar as RIT dye?
Offline Hzza
« Reply #43 on: Sat, 16 May 2015, 15:03:53 »
http://deskthority.net/workshop-f7/how-to-dye-your-keycaps-a-visual-guide-t10672.html
Seems like a pretty good one, not tried it myself though so couldn't really say...
Offline Yoe
  • Alps & ISO <3
« Reply #44 on: Sun, 17 May 2015, 01:43:03 »
I've used these threads for reference:
http://deskthority.net/workshop-f7/dyeing-pbt-caps-with-dylon-some-experiments-t2059.html
http://deskthority.net/workshop-f7/dylon-dyeing-of-pbt-caps-more-experiments-t5433.html
My own experiences:
At first I was very careful with temperatures and used a thermometer, but I later found that keeping the dye boiling or near boiling makes the dye take well and the caps won't be damaged as long as you keep stirring. I don't use a strainer, just a small pot (disposable.. you don't want to use it for food afterwards) and a spoon. You can use other peoples experiments or your own when it comes to estimated times, but you pretty much want to watch it all the time anyway, and when you see change in color you take out a cap to check every minute or so. Just rinse real quick in cold water, check the color and put it back into the dye bath. When you are pleased with the color, take them all out, rinse in cold water and carefully wipe them. You don't want any splotches of dye left on them. (This seems to be a problem with some colors, especially the faster ones like the emerald green). Then just let them dry properly before use.
Offline Paranoid
« Reply #45 on: Sun, 17 May 2015, 04:16:05 »
Cool, thanks guys! :) I have some dylon dye colors laying around since two years or so. Saw Kirks first dye post then as well but never got around to it heh. Those newer ones have some good info as well.
And thanks for your own experience Yoe! Sure it will be useful for other people as well.
Offline njbair
    • nickbair.net
« Reply #46 on: Sun, 17 May 2015, 05:59:37 »
Is it possible/advisable to use less dye in the water to achieve a lighter color result?
My boards:
Offline Yoe
  • Alps & ISO <3
« Reply #47 on: Sun, 17 May 2015, 07:23:28 »
No problem! :) Oh, and I forgot two reminders: it has to be the Dylon Multi-Purpose Dye and this only works on PBT caps, not ABS.
Yeh! I totally forgot to mention that! I usually put in just half of a 4.5g (or 5g) package in I don't know.. perhaps 5-7 deciliters of water.. enough to cover the caps properly and like.. twice that amount. Maybe 4-5 cm depth of water in a small pan. Works fine. You could probably use even less dye per amount of water than that with good results.
Edit: I didn't read your post properly. For a lighter result, less time in the dye is the easiest way to control the color saturation.
« Last Edit: Sun, 17 May 2015, 07:26:32 by Yoe »
Offline Yoe
  • Alps & ISO <3
« Reply #48 on: Sun, 17 May 2015, 07:48:53 »
Example: I've used the same dye (02 Golden Glow) for the modifiers on the top and the middle keyboard in the picture below. About 45 minutes for the darker, almost orange, color and about 20 minutes (or 30… don't quite remember) for the mustard yellow. (In the top keyboard I also used the Tangerine dye for enter, backspace and tab keys. Just thought I'd mention that..)
100993-0
Offline sprit
« Reply #49 on: Sun, 17 May 2015, 08:55:56 »
Maestro  Yoeda !     :o :thumb: :thumb:
« Last Edit: Sun, 17 May 2015, 09:00:23 by sprit »
