Author Topic: Does "Bottoming out" key hurt anything?  (Read 5547 times)
Offline Dongulator
« on: Sun, 06 October 2013, 23:31:59 »
I'm just asking, I have been using linear reds and am constantly bottoming out the keys... just making sure.
Offline IMHB
Re: Does "Bottoming out" key hurt anything?
« Reply #1 on: Sun, 06 October 2013, 23:42:09 »
I really do not think so.....unless you push really, really hard.
Offline Belfong
« Reply #2 on: Sun, 06 October 2013, 23:43:18 »
The better keyboard has a steel plate where the switch is attached to, so bottoming out would just make a nice sound of hitting steel. Should not harm it or anything.
Offline SNF
« Reply #3 on: Sun, 06 October 2013, 23:48:11 »
fingers ;D
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Sun, 06 October 2013, 23:54:06 »
For the most part I'd say don't worry about it.
However if you're reallyyyyyyyy picky, I'd say it will damage your finger joint and make tiny dents on the inside of your keycap from hitting the corner of switch housing.
Though the damage is so subtle it probably wouldn't matter.
Offline bazemk1979
« Reply #5 on: Sun, 06 October 2013, 23:57:31 »
looking at your question, then looking at your avatar.... What are you?!?!?! a cry baby in BL body?
Offline Tony
« Reply #6 on: Sun, 06 October 2013, 23:58:18 »
That does not hurt much, but why punching on the keys if you can dance on the keyboard? Remember that you only have to go half way to make a key registered.
Be sophisticated with such wonderful peripheral. Keyboard God has sent you a missionary.
« Last Edit: Mon, 07 October 2013, 00:02:37 by Tony »
Offline Dongulator
« Reply #7 on: Mon, 07 October 2013, 00:05:09 »
cool.. thanks for the quick response fella's. I guess I was asking since reds seem to have such a light touch that its hard for me not to bottom out all the time. Maybe I will look into something that takes a little more force.
Offline Dongulator
« Reply #8 on: Mon, 07 October 2013, 00:07:16 »
What makes you think I'm being a "cry baby in BL body"    :'(
Offline Linkbane
« Reply #9 on: Mon, 07 October 2013, 00:27:14 »
It only hurts your typing speed.
 :D
Seriously though, learning not to bottom out brought me from 110-120 to over 140.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline bazemk1979
« Reply #10 on: Mon, 07 October 2013, 00:29:51 »
For the love of the keyboard community don't break a nail bottoming out  :rolleyes:
Offline Dongulator
« Reply #11 on: Mon, 07 October 2013, 08:16:04 »
 ;D yeah yeah
Offline terran5992
  • One With The Cup Rubber
« Reply #12 on: Mon, 07 October 2013, 08:28:49 »
Keyboards are meant to be able to bottom out
Offline Hyde
« Reply #13 on: Mon, 07 October 2013, 08:33:35 »
Agreed.  Though I bottom out on mechanical keyboards because it sounds nice and it's more fun lol.
And obviously I don't bottom out with the force of 1000 fury.
Offline davkol
  •  Post Editing Timeout
« Reply #14 on: Mon, 07 October 2013, 17:02:08 »
 :D
* davkol is waiting for tp4tissue to chime in.
« Reply #15 on: Mon, 07 October 2013, 17:05:00 »
 :D
I think he still got a few days left at camp :P
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #16 on: Mon, 07 October 2013, 17:07:49 »
Typing speed isn't everything.  Bottoming out is fun and clacktastic.
Offline T0ken
« Reply #17 on: Mon, 07 October 2013, 20:38:12 »
My initial interpretation as well was that bottoming out was hurting your fingers...I was imagining a guy fighting off imaginary bad guys with a toy nunchaku and then complaining about keyboards hurting his fingers...Not the case I guess; and your keyboard is designed to handle the bottoming out.
Offline Thimplum
  • Master of all Ponies
« Reply #18 on: Mon, 07 October 2013, 20:40:55 »
It's won't break stuff. People say that they can type faster without, but I do it anyways.
TP4 FOR ADMIN 2013
Offline Linkbane
« Reply #19 on: Mon, 07 October 2013, 21:58:45 »
I honestly type quite a bit faster typing more lightly, because if you type for speed and you bottom out, you deserve to use a rubber dome. It's the exact same, overcompensating force and pressing all the way down. If you didn't want to have an actuation at the bottom, you should actually use the damn switch like it's supposed to be, by actuating it near the center.
Offline 1391406
« Reply #20 on: Mon, 07 October 2013, 23:28:42 »
I could truly care less whether I bottom out. I've never damaged a keyboard as a result.
Offline davkol
« Reply #21 on: Tue, 08 October 2013, 01:06:52 »
 :D
* davkol waits for TotalChaos to chime in, although that won't happen either.
Offline Linkbane
« Reply #22 on: Tue, 08 October 2013, 01:42:40 »
 :D
Waits for someone to inform davkol that TP was been, yet again apparently, banned for another week.
« Reply #23 on: Tue, 08 October 2013, 02:00:46 »
Botteming out is about as much of a circlejerk as stickering your board is.
It may look good, but ultimately it does nothing.
Bottom out to your hearts content.
