Author Topic: 0 Rings??  (Read 1561 times)
Offline mini66
0 Rings??
« on: Mon, 07 October 2013, 11:21:19 »
Where can I buy O rings in the UK, plus what size do I need for my Q-Pad 85 Cherry MX Red...or does it now matter? Is there just one kit for any keyboard...how does it work Thanks!
« Last Edit: Mon, 07 October 2013, 11:22:52 by mini66 »
  • Live long and prosper
Re: 0 Rings??
« Reply #1 on: Mon, 07 October 2013, 11:50:04 »
Not to sound insensitive, but you should really try to do more research before making a whole new thread to ask one question. And if you can't find what you're looking for, then I'd post in this thread: Simple Questions, Simple Answers (FAQ in the OP)
To answer your question: WASD sells o-rings and ships internationally. Maybe this is what you're looking for: http://www.wasdkeyboards.com/index.php/cherry-mx-rubber-switch-dampeners.html
tp thread is tp thread
Offline ch_123
Re: 0 Rings??
« Reply #2 on: Mon, 07 October 2013, 11:53:24 »
One size fits all for Cherry MX keyboards, as far as I know.
Offline mini66
Re: 0 Rings??
« Reply #3 on: Mon, 07 October 2013, 13:11:25 »
Ok get your point :)
WASD sells o-rings
Anyone used them, are they durable?
Re: 0 Rings??
« Reply #4 on: Mon, 07 October 2013, 13:12:35 »
WASD sells o-rings
I have. You can find my impressions here.
Offline Tarzan
  • formerly known as Greystoke
Re: 0 Rings??
« Reply #5 on: Mon, 07 October 2013, 13:13:50 »
WASD sells o-rings
I believe there are actually some threads related to o-ring reviews.  I've installed both the 40a red rings from WASD, and the 50a black rings from Amazon, no issues with either.
