Author Topic: Aluminum/Wood Poker case idea - opinions?  (Read 4631 times)
Offline Thimplum
  • Master of all Ponies
« on: Tue, 08 October 2013, 10:28:27 »
5 mins in blender
Would prolly make the wrist rest part shorter.
« Last Edit: Tue, 08 October 2013, 10:42:58 by Thimplum »
TP4 FOR ADMIN 2013
Re: Poker case idea - opinions?
« Reply #1 on: Tue, 08 October 2013, 10:29:33 »
Wood this be different, YES!
Wood I buy it, NO!
I have no poker's left ;)
Interesting idea you've got there.
Offline Thimplum
« Reply #2 on: Tue, 08 October 2013, 10:39:32 »
Wood I buy it, NO!
GH60's? haha
TP4 FOR ADMIN 2013
« Reply #3 on: Tue, 08 October 2013, 10:43:10 »
« Reply #4 on: Tue, 08 October 2013, 10:43:47 »
Why not a metal tray to sit under the keyboard, with the wooden wrist rest out front? That way, you can use it with any Poker case you have.
I wouldn't separate the wrists, though.
Offline Thimplum
« Reply #5 on: Tue, 08 October 2013, 10:45:32 »
Because I thought it would look cooler! The current model of it that I have is pretty bad and sometime I'll get around to making a better one that better conveys what I have in mind.
TP4 FOR ADMIN 2013
Offline esoomenona
  • Gnillort?
Re: Aluminum/Wood Poker case idea - opinions?
« Reply #6 on: Tue, 08 October 2013, 10:46:22 »
How about instead of having an aluminum case, essentially, you just have a layer of aluminum plate with holes in it for standoffs. Then the PCB sits on the standoffs, and there is a wooden rest in front of it. Saves on cost, and you can look at your PCB.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #7 on: Tue, 08 October 2013, 10:51:52 »
Integrate a cupholder!
A Ghost From The Past
« Reply #8 on: Tue, 08 October 2013, 10:55:17 »
So you want a compact board with 2 massive piece of wood attached to it? :))
This would be better ^
« Reply #9 on: Tue, 08 October 2013, 10:57:18 »
 :o blasphemy!
then you might spill your drink on your keyboard
  • ~ BOOO ~
« Reply #10 on: Tue, 08 October 2013, 12:13:58 »
I actually knocked a cup of coffee on a Poker, wouldn't have happened if it had a cupholder!
Offline JonasDK
  • Let me poo on you
« Reply #11 on: Tue, 08 October 2013, 12:23:57 »
Well, i find the idea with a big wrist wrest pretty bad. It's a cool design, don't get me wrong! But isn't the idea with a 60% to be small?
