Author Topic: Has anyone removed the rubber damper on their Matias Quiet Pro yet?  (Read 4868 times)
Offline Hyde
  • White Tofu Extraordinaire
I haven't personally tried Cherry Clear, but according to most that the Matias Quiet Pro actually feels similar to Ergo Clear.
So now I wonder if we removed the rubber damper, will it feel even closer to Clear?
Though yes granted it won't be quiet anymore, but I'd assume it should feel better.  I thought about trying it before but after swapping switches for my girlfriend's Tactile ALPS to Quiet ALPS, I got sick and tired of looking at switches LOL.
Maybe I'll give it a shot one day when I'm brave enough to open 108 switches again.  :P
Offline Hyde
Re: Has anyone removed the rubber damper on their Matias Quiet Pro yet?
« Reply #1 on: Thu, 10 October 2013, 12:03:50 »
I guess no one have tried this yet?  Looks like I might have to try this later myself lol.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #2 on: Thu, 10 October 2013, 12:05:36 »
Never **** without rubber! :D
  • Live long and prosper
« Reply #3 on: Thu, 10 October 2013, 12:08:01 »
tp thread is tp thread
Offline Hyde
« Reply #5 on: Thu, 10 October 2013, 16:13:42 »
Removing the rubber dampers should not change the force curve.
Offline Hyde
« Reply #6 on: Thu, 10 October 2013, 16:47:59 »
Yeah it won't, but it will free up the bottom out distance, which is a common annoyance in using o-ring (similar idea).
Hopefully it will give an overall more "clean" and crispier feeling.
Offline Polymer
« Reply #7 on: Fri, 11 October 2013, 00:01:19 »
Maybe this isn't accurate but I always assumed w/o the dampener it would feel a lot like a normal Alps switch..
Offline Hyde
« Reply #8 on: Fri, 11 October 2013, 01:11:52 »
lol I'd say this is pretty much accurate.  While Tactile Pro is kinda like MX Blue equivalent.  Quiet Pro I'd say is more like MX Brown/Clear + o-ring equivalent.
So yeah probably just feel like regular ALPS.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #9 on: Fri, 11 October 2013, 16:09:55 »
Matias quiet is a lot nicer than Alps black or salmon — substantially lighter and far more tactile. Orange is the only switch that has any hope of competing with Matias, but I've not got an Alps orange keyboard.
Bore Awards
Offline Polymer
« Reply #10 on: Fri, 11 October 2013, 20:25:55 »
Are you talking without the dampener or with?  We do know that they're basically alps switches modded w/ a dampener and also to, apparently, fix some of the reliability issues regular Alps switches had...
« Reply #11 on: Fri, 11 October 2013, 23:19:49 »
The difference in key travel will be smaller than with Cherry MX with O-rings. I find unmodified Cream Alps to already be crisper than Cherry MX with O-rings.
I have been tempted to put Matias Quiet switches in one of my vintage Apple keyboards ... but there isn't really any of them that I think has any good layout. (for Swedish)
Offline Hyde
« Reply #12 on: Sat, 12 October 2013, 01:05:03 »
Yeah Matias did say they had to reinvent the switch.  Even though they kind of copied the original design but things really aren't that simple so they had to do a lot of adjustments.
Yeah I'm still on the fence about this.  Though considering the damper dampens down and upstroke, I'd think it should still free up a little bit of travel distance.  But consider the difference I wonder if it's worth the effort.
Offline Polymer
« Reply #13 on: Sat, 12 October 2013, 01:16:09 »
I dunno...the way I read it, they basically said they had to make some minor adjustments which helped on the reliability side..but the switch itself is basically an Alps switch.
I haven't pulled the rubber dampener out of the switch and I'm not really planning to...and it has been many years since I've used an Alps keyboard..but even the tactile pro seemed familiar..maybe there are a lot more subtle differences...I haven't actually tried them side by side..
Offline ch_123
« Reply #14 on: Sat, 12 October 2013, 05:39:27 »
I can't comment on the Matias switches specifically, but I did make a hybrid Blue-Cream Alps switch before, and I found that the dampeners made the switch feel mushy, perhaps because I tend to bottom out on Alps switches. But aside from that, the dampener should have no effect on the feel of the switch.
