Author Topic: [IC] mx clear cover round 2  (Read 24104 times)
Re: [IC] mx clear cover round 2
« Reply #50 on: Sun, 01 December 2013, 20:14:11 »
Ill take clear please! Or if you color any transparent!
Offline quake4mhg
« Reply #51 on: Sun, 01 December 2013, 22:40:32 »
Still the non LED version?
Offline AlexJP
« Reply #52 on: Sun, 01 December 2013, 23:31:49 »
Any updates on this round 2?
« Reply #53 on: Sun, 01 December 2013, 23:38:17 »
I'm not sure R1 is completed yet.
Offline oneproduct
  • @Ubisoft
« Reply #54 on: Wed, 04 December 2013, 15:05:35 »
I'd be interested in white.
Layout: Colemak
Offline keymaster
  • Topre Revolution Theorist
« Reply #55 on: Wed, 04 December 2013, 15:08:12 »
Interested.
By the way, is there a reason why the entire switch housing isn't sold? (instead of just top cover)
« Reply #56 on: Wed, 04 December 2013, 15:09:20 »
Seems like there are quite a few from R1 who have not received their tops yet
Offline Photoelectric
« Reply #57 on: Wed, 04 December 2013, 16:04:45 »
Interested.
That has a lot more components, including metal parts that are fixed.  Are you asking them to make those parts too?  Also, they still need to correct the inner dimensions of the existing tops--designing and executing the bottoms would need to have even lower tolerances for error.
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« Reply #58 on: Thu, 05 December 2013, 07:02:43 »
interested 4 transparent definitely plus any other color.
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #59 on: Thu, 05 December 2013, 08:28:39 »
im interested too
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline Fritz
« Reply #60 on: Sun, 08 December 2013, 08:29:51 »
 Would love some transparent orange :)
Offline JayKthnx
« Reply #61 on: Sun, 08 December 2013, 19:48:59 »
is there any word on led switch covers yet? I would be willing to pick up at least 300 if you decide to make those.
Offline mousesony
« Reply #62 on: Fri, 13 December 2013, 13:56:41 »
Very interested in clear transparent.
Offline Stevenator21
« Reply #63 on: Sun, 15 December 2013, 18:14:08 »
So no space for LEDs? Bummer.
I think a cool color would be a transparent graphite.
Ducky Shine 3 TKL w/ Browns + White LEDs
« Reply #64 on: Sun, 15 December 2013, 18:20:23 »
These allow for an LED like normal cherry tops, however what was discussed before was the possibility of having a different mold made to allow for switch top removal while leaving LED's intact.
Offline HPE1000
  • Keycap Paparazzo
« Reply #65 on: Sun, 15 December 2013, 18:21:59 »
What? I thought the only issue what that the tops couldn't be removed with leds in, which is an issue with all mx tops that aren't modified.
Unless I am wrong and these don't support leds for some reason and I missed that.
Offline Pacifist
  • on hiatus
« Reply #66 on: Mon, 16 December 2013, 16:05:45 »
Just do the socket mod and you can keep the stock case
« Reply #67 on: Tue, 17 December 2013, 02:58:14 »
See the post above yours?
What are you even talking about?
Offline HPE1000
  • Keycap Paparazzo
« Reply #68 on: Tue, 17 December 2013, 06:55:49 »
You posted that while I was typing mine and I didn't go back and check :P
Notice the time stamp.
« Reply #69 on: Tue, 17 December 2013, 10:59:12 »
I think he means the not-at-all-easy-or-clean mod where you cut out that chunk of plastic that holds the LED into the top part of a cherry switch "case".  So that allows you to keep the stock "case" (switch enclosure) that you started with.
But that is so tedious and I can't imagine it would be very clean or consistent, and is hardly comparable to buying a custom top.
Offline domoaligato
« Reply #70 on: Tue, 17 December 2013, 14:12:38 »
Over 9000 +
the ones I have now have orange stickers under them.
Offline JayKthnx
« Reply #71 on: Sat, 28 December 2013, 12:21:08 »
Would love to purchase around 300 clear covers now. Also adding interest for purple covers.
Offline avtar
« Reply #72 on: Fri, 03 January 2014, 15:13:19 »
I would be interested in clear ones.
Offline drumflavah
« Reply #73 on: Sat, 04 January 2014, 06:18:42 »
interested!!!
« Reply #74 on: Sat, 04 January 2014, 09:50:30 »
Sounds like R1 Canadian orders were never shipped.
Offline JayKthnx
« Reply #75 on: Sat, 04 January 2014, 18:12:03 »
I saw that as well. Hopefully, that doesn't mean we won't have a second round.
Offline avtar
« Reply #76 on: Sat, 04 January 2014, 20:46:19 »
Well that's definitely troubling if the first round wasn't sucessfully completed :/
« Reply #77 on: Sat, 04 January 2014, 20:50:32 »
That doesn't appear to be the fault of the GB organizer but the US distributor from what I've seen.
« Reply #78 on: Sun, 05 January 2014, 04:43:44 »
True but the organizer isn't doing anything to help in the process.
Offline RESPRiT
  • HHKB = ❤
« Reply #79 on: Sun, 05 January 2014, 06:10:06 »
Hopefully a second round can go smoothly, a lot of people definitely seem to be interested.
Offline tbc
« Reply #80 on: Sun, 05 January 2014, 06:45:33 »
what does the switch look like with the 'removable-without-removing-LED' feature?
« Reply #81 on: Sun, 05 January 2014, 07:58:49 »
The part around the led would simply not be there.
« Reply #82 on: Sun, 05 January 2014, 13:14:16 »
What exactly can they do?  They don't have extras (or enough extras) and I doubt their talking to the proxy will be any more effective than the people who haven't gotten theirs yet.
Offline daerid
    • Rossipedia
« Reply #83 on: Sun, 05 January 2014, 13:28:39 »
I'm in for a couple of straight clear sets (non-colored).
Aluminum top plate, white PCB, clear switch tops and clear key caps on my ErgoDoxen... yummmmmmm
« Reply #84 on: Sun, 05 January 2014, 13:55:35 »
The GB organizer is still responsible when people have paid and there items are not shipped.
So your saying if you run a GB a group buy and have someone help with shipping and they don't shop or just don't respond the people who have purchased are SOL?
« Reply #85 on: Sun, 05 January 2014, 14:02:29 »
I'm saying that they can't force the proxy to ship it.  I don't know that anyone has contacted the group buy organizer yet to see if they can find some kind of solution, so I can only comment that they don't have any extras based on what they've said in the past and that they can't get the proxy to ship any more than the people who participated and are waiting on shipment.
Offline do_Og@n
« Reply #86 on: Sun, 05 January 2014, 14:16:55 »
I would still love red cover tops and clear. If they come out eventually I would also love some green.
