Advanced search
it just clicks
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Projects
Making Stuff Together!
(Moderator:
Soarer
DIY Switch Keychain?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: DIY Switch Keychain? (Read 7070 times)
Pacifist
Report me *again* if there are gifs in my sig
Elevated Elder
Thread Starter
on hiatus
on:
Mon, 14 October 2013, 20:57:13 »
I want to do more DIY projects. One that I would like to do is a switch keychain. How would I go by it? Are there any commonplace objects that can work as the case for the switchchain?
Logged
FS-Pretty much everything:
http://geekhack.org/index.php?topic=58087
Tempiz
Buckling Springs <3
Re: DIY Switch Keychain?
Reply #1 on:
Mon, 14 October 2013, 21:28:48 »
What do you mean by case for the switch keychain? Are you asking for suggestions for a nice box to put it in? Im abit confused. But, As for making a switch keychain, If you have any keychains laying around that you can use, start from there. Take that off. If its a keychain your going to most likely need some kind of chain to hold the switches of course, so start looking! You'll also need to buy or get the key loop thing. Its pretty simple, you'll just need to start looking. Good luck to you! I am planning to make a bracelet out of keycaps! Some what similar to your idea.
Logged
I cant be separated from my Model M
Pacifist
Elevated Elder
Thread Starter
on hiatus
Reply #2 on:
Mon, 14 October 2013, 21:42:24 »
Sorry for lack of pics
What I want to make:
Something along the lines of these
Logged
mojo3120
Reply #3 on:
Sat, 30 November 2013, 04:07:28 »
Some type of mold, and clear casting resin maybe? That's what the bottom picture looks like.
Logged
regack
Reply #4 on:
Sun, 01 December 2013, 08:09:30 »
You should jam a couple of CR927 button cells in there and have the switch turn on an LED when depressed...
Logged
Oobly
Esteemed Elder
Reply #5 on:
Mon, 02 December 2013, 02:58:42 »
Perhaps a 19mm size D6 dice and use a dremel to grind out a hole for the switch?
16mm may work, too, but leaves very little margin for error. Hmmm, new ideas for number key keycaps, but not sure how to do 7, 8, 9 and 0..
Logged
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Pacifist
Elevated Elder
Thread Starter
on hiatus
Reply #6 on:
Mon, 02 December 2013, 18:12:38 »
0.0 someone bumped this thread....
Don't need these anymore, getting a premade one from jcrouse in the mail
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Projects
(Moderator:
Soarer
