Author Topic: Are there smaller version of standard (Cherry MX type) key switches?  (Read 2108 times)
Offline Piotr Dobrogost
I'm working on adding extra, smaller keys to the keyboard (see http://geekhack.org/index.php?topic=48615.0;topicseen) and thus I need smaller version of standard key switches (by standard I mean Cherry MX type of switches).
Do you know any such smaller version?
Re: Are there smaller version of standard (Cherry MX type) key switches?
« Reply #1 on: Fri, 18 October 2013, 06:32:37 »
All cherry mx switches have the same size footprint as far as I know.
Offline BlueBär
« Reply #2 on: Fri, 18 October 2013, 06:49:14 »
Spamray is correct, all Cherry MX switches have the same size. You could maybe use some Cherry microswitches though.
« Reply #3 on: Fri, 18 October 2013, 06:52:17 »
Cherry MX switches can not be smaller. But they can be larger. There are some rare types with longer key stems
Offline BlueBär
« Reply #4 on: Fri, 18 October 2013, 07:09:40 »
Hmm if you are referring to the MX-M8 adapters, I think the stem is only about a millimeter larger, but yes, those exist.
« Reply #5 on: Fri, 25 October 2013, 17:12:16 »
Well, microswitches is what I used in the first prototype but they have totally different characteristics from "standard" keyboard switches - they are much stiffer and have very short travel distance.
Offline davkol
  •  Post Editing Timeout
« Reply #6 on: Fri, 25 October 2013, 17:39:10 »
Just a crazy idea... what if you put a membrane over the PCB with MX switches? You could get another layer this way... with say spring-over-membrane "switches".
Offline epiphany
« Reply #7 on: Fri, 25 October 2013, 20:10:35 »
What about Cherry ML switches? Those are a little smaller. I'm not sure that they are small enough for what you're working on, however.
