Author Topic: i'm not panda  (Read 2730 times)
Offline minho
  • i'm kind of back
i'm not panda
« on: Sat, 19 October 2013, 13:51:58 »
i'm not panda
« Last Edit: Sun, 09 November 2014, 01:20:41 by minho »
Offline Linkbane
Re: Howdy from Texas
« Reply #1 on: Sun, 20 October 2013, 22:13:14 »
QFR has a limited edition white, and is a classical 87-key TKL keyboard.
Also, the TK is a TKL in terms of size (it's only a centimeter or so larger than my Rapid) and here's the link to the limited edition white, if needed: http://www.cmstore-usa.com/cm-storm-quickfire-tk-white-body-mid-size-led-mechanical-gaming-keyboard/. Other than that, you're better versed in the field of white TKL than I.
Threads like this should probably go in keyboards, because that is what you're looking for.
By the way, considering your picture and location, do you happen to be a certain UchihaScar?
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #2 on: Sun, 20 October 2013, 22:20:46 »
White Leopold TKLs exist, but looks like elitekeyboards.com isn't stocking them right now.  There is also a white Rosewill, but it is full-size (like all Rosewills). :-/
Questions about keyboards would generally be posted in the Keyboards subforum, but here is fine too.
Offline minho
  • i'm kind of back
« Reply #3 on: Mon, 21 October 2013, 01:43:34 »
Wow, I'm actually not, but I'm a pretty good friend of his. I sit next to him in Macroeconomics class and was in some of his other classes :P
How do you know him?
Thanks for the help, I might just get the white Quickfire TK.
Offline minho
  • i'm kind of back
« Reply #4 on: Mon, 21 October 2013, 01:44:59 »
Is there another place where you can buy Leopold's? (Preferably not from eBay other than trusted or popular vendors)
Offline Linkbane
« Reply #5 on: Mon, 21 October 2013, 09:33:22 »
You could get the FC660C from Amazon, they have three left in stock, but it's from EK anyways. They seem to be the main supplier, unless you want to get a proxy from Korea.
