Author Topic: HHKB Pro 2 for Gaming  (Read 6925 times)
Offline Angelwork
    • Angelwork Tech
« on: Sat, 19 October 2013, 14:05:00 »
I just bought one of these to replace my Razer BlackWidow Ultimate.  I have no experience using Topre switches, but I'm hoping that I really like them.  I never use the number pad and extremely seldom use the directional keys (never for gaming), so I figured that I'd take the plunge with the rave reviews that everyone gives it.  I'm just wondering if there are any people out there that use the thing for gaming and if there are any obvious strengths or weaknesses with this keyboard.  Thanks!
Razer BlackWidow Ultimate | HHKB Pro 2
Offline Sniping
Re: HHKB Pro 2 for Gaming
« Reply #1 on: Sat, 19 October 2013, 14:14:28 »
I just like the feel of Topre, so I like gaming with Topre. I would say that a downside is that there's no dedicated F-row if you happen to need it for RTS and such. Other than that, I think 60% is great for gaming, more ergonomic by keeping your hands closer together which can arguably help with aim for FPS.
« Reply #2 on: Sat, 19 October 2013, 14:17:34 »
I actually dislike my HHKB for gaming.
It's not super easy to spam keys, and I use my F keys very frequently.
For something like LoL it might be OK though.
« Reply #3 on: Sat, 19 October 2013, 14:19:21 »
Then again you can play LoL with anything
Offline Rayne
  • For Science!
« Reply #4 on: Sat, 19 October 2013, 14:37:12 »
this is spot on imo
Offline ctbear
« Reply #5 on: Sat, 19 October 2013, 15:08:29 »
Nothing wrong with gaming with Topre switches, but the layout is the problem.
« Reply #6 on: Sat, 19 October 2013, 16:07:24 »
I play FPS with mine - no problems, other than having to look at the keyboard to press 2 keys for function keys, like F5 for quick save becomes Fn-5.
The weight is fine, double-tapping is fine.  Holding down 2 or 3 keys at the same time is fine.
Offline Angelwork
    • Angelwork Tech
« Reply #7 on: Sat, 19 October 2013, 16:28:57 »
No dedicated F-row is okay for me.  The only thing I really use it for are quicksaves and screenshots.  Nothing I can't live without.  There are imbedded F-keys though, correct?
« Reply #8 on: Sat, 19 October 2013, 16:36:12 »
Oh yes, just press Fn + w number key, 3 = F3, 5 = F5 and so on.  '-' = F11 and '=' = F12.
Offline zoolzoo
« Reply #9 on: Tue, 22 October 2013, 04:49:51 »
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline Emospence
« Reply #10 on: Tue, 22 October 2013, 04:56:01 »
Very personal, methinks. Do you use any of the missing keys? If not, I say go for it ;)
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
« Reply #11 on: Tue, 22 October 2013, 08:58:28 »
You should be able to remap the F# keys you like to something else. Gaming usually uses few enough keys that there should be some left over.
I know the HHKB is a "special case" but lots of people (myself included) have gamed with a 60% without too much difficulty.
Offline Cafeine
    • GeekZone
« Reply #12 on: Wed, 23 October 2013, 06:03:25 »
I game on the FC660(C and M) layout so shouldn't be a problem with the HHKB. I even find that gaming on a classic TKL is LESS efficient since the F row is too far anyway. And Topre are perfect for gaming. <3
Own : HHKB Type-S | Leopold FC660C (x2 - 1st Gen & 2014 silenced) | RealForce 87U TKL (55g uniform) | RF 23U | Minila Air MX Blue
Sold : RealForce 88UB 45g | Leopold FC660M (MX Clear) | Filco MJ2 TKL (MX Brown) |  KeyCool 84 (MX Black) | CodeKeyboard TKL (MX Clear)
Offline flaming_june
« Reply #13 on: Wed, 23 October 2013, 06:35:29 »
Terrible keyboard for most games, other than your average fps, the lack of keys really hinders your performance.
Offline goobus
  • HHKB Elite
« Reply #14 on: Wed, 23 October 2013, 06:38:20 »
If you play a very spammy RTS like SC2 topre is probably not the best. When I played on my 45g Realforce I had a lot of difficulty rapidly double tapping numbers and performing quick repetitive actions.
Offline goobus
  • HHKB Elite
« Reply #15 on: Wed, 23 October 2013, 06:44:53 »
That being said, if you suck at all games you play you will probably be fine with a HHKB.
Offline PadawanGeek
« Reply #16 on: Wed, 23 October 2013, 08:21:29 »
I play mainly FPS games like Serious Sam TFE/TSE, Serious Sam 3 and UT3.....and some Dead Space 3 and Lost Planet 3, no problem with it. My score/kills with my HHKB 2's is about the same as when I use MX switch keyboards....
Offline Polymer
« Reply #17 on: Wed, 23 October 2013, 09:13:53 »
Yeah..I'm not sure what it is but I just don't like using Topre boards as much for gaming...whether that is double taps or anything..just doesn't feel right?  If I was forced to use it I could but I'd prefer not to.  Variable for sure is worse cause the light keys are too sensitive....
I love Topre boards...but just not for gaming...
Offline ZeodoHokill
« Reply #18 on: Wed, 23 October 2013, 09:45:52 »
I don't have one instead, the only think I would worry about is the location of ctrl key, it is not located at far left bottom of the keyboard, may not very easy to press for FPS, you know, most of the time ctrl is crouching and extreme important.
Offline AuRinBei
« Reply #19 on: Wed, 23 October 2013, 10:08:32 »
Having control where caps lock is doesn’t make it harder to reach. It’s literally right next to the WASD cluster. The only problem I’ve experienced with FPSs is that it’s not easy to ride the actuation point. So making tiny adjustments is difficult, but not really all that much harder than with browns. Probably easier than with blues.
87u || Poker 2
