Author Topic: [deleted]  (Read 5074 times)
Offline xanoku
[deleted]
« on: Sun, 20 October 2013, 15:58:18 »
[deleted]
« Last Edit: Wed, 07 June 2017, 21:45:03 by xanoku »
Offline mindoculus
Re: /r/ Black engraved PBT cherry profile keycaps
« Reply #1 on: Sun, 20 October 2013, 16:10:02 »
WASD keyboards ? check their site. they sell keycap sets, engraved or laser printed, all black or any color, with or without logos.
Offline Jocelyn
  • 조셀린
« Reply #2 on: Sun, 20 October 2013, 16:12:35 »
OP said cherry profile. Anyway, what you're looking for does not currently exist :(
Offline xanoku
« Reply #3 on: Sun, 20 October 2013, 16:16:02 »
Yeah I was looking at them, but apparently their quality isn't great, and they use thin ABS plastic.
If all else fails though, I'll probably have to settle for them, or get the Vortex set
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=287
and live with the fact that the "|\"  legend is wrong.
Can you think of anything similar I might settle for?
Offline Jocelyn
  • 조셀린
« Reply #4 on: Sun, 20 October 2013, 16:24:53 »
A LOT of people on GH want what you want and have been asking for it for quite some time (A year+ lol). Ivan mentioned something about a possible Dark gray or black R3 PBT GB, but I'm not sure if/when that will happen. Outside of that, your current options are limited to thin OEM profile PBT in black w/ engraving or Imsto Thick Cherry PBT blanks. Here's my Imsto Thick PBT along with CMYK, but keep in mind the photo was taken out in the sun and the caps don't look quite as dark indoors :)
« Last Edit: Sun, 20 October 2013, 16:26:35 by Jocelyn »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sun, 20 October 2013, 17:16:25 »
Oh I still want to try to get that done but it will still be a little bit. Going to do some novelty caps and then I will tackle some gigantic possibly hopeless high MOQ full sets again :))
If you want Cherry NOW, this is what I would do. Get a Cherry PBT white blank set. Take them to a local engraving service, places that make awards or what have you. Get the legends engraved. Assuming it came out nice then make sure they are nice and clean and dye those suckers.
« Last Edit: Sun, 20 October 2013, 17:17:58 by IvanIvanovich »
