Author Topic: Noppoo Mid 87 + Filco case?  (Read 1526 times)
Offline Reomero
  • Manual breather
« on: Wed, 23 October 2013, 04:11:05 »
I'm just wondering if this board can fit a case designed for a Filco considering the construction/design of the Noppoo is so similar (at least to my eyes).
So basically I just want to know if the position of screws and size of the PCB/plate match up (yes, the edge of the plate does bend down). If you have a Filco TKL can you do some quick measurements like I did below?
Here's the rough measurements I made:
Thanks in advance :)
Re: Noppoo Mid 87 + Filco case?
« Reply #1 on: Wed, 23 October 2013, 11:50:56 »
I'm pretty sure they do not match up, especially the one on the left.
Offline Reomero
  • Manual breather
« Reply #2 on: Thu, 24 October 2013, 04:44:52 »
That's pretty much why I made this thread. I'd just like someone to confirm so my curiosity can go away. :rolleyes:
(Cmon, I know there are many here with a Filco TKL)
