Author Topic: Kinesis, swapping @ and " using mapping?  (Read 2633 times)
Offline ElectronicFur
« on: Mon, 28 October 2013, 10:17:12 »
I've been using my Kinesis using the Colemak.com layout installation. But now I have to use PC's where I dont have the ability to install that, so I've started using the hardware remapping instead.
But how do I remap a shifted key? I seem to only be able to map a whole key including the shift. For example I'd like to switch the " and @ around without moving the 2 and '. Is this possible?
Cheers,
EF
Kinesis Advantage Pro (silver) | Kinesis Advantage (black) | Microsoft Natural Elite | Ergodox (on order)
Offline natas206
  • * Commercial Vendor
Re: Kinesis, swapping @ and " using mapping?
« Reply #1 on: Mon, 28 October 2013, 12:17:21 »
You could create macro's.
For example, create a macro for Shift+2 that equals the quote sign ".
1). Press and Hold Progrm & tap F11.
2). Press and Hold Shift, then tap "2" and relaese.
3). Type the Macro (Shift+')
4). Exit by repeating step one.
Now every time you press Shift + 2 you'll get the quote sign.
« Reply #2 on: Mon, 28 October 2013, 13:30:48 »
Thanks Natas, that works great.
Although shouldn't it say 'create a macro for Shift+2 that equals the at sign @.' ?
I knew what you meant though.
Cheers,
EF
