Author Topic: Need Help- Popped a Switch  (Read 1777 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Mon, 28 October 2013, 10:55:32 »
i know this a dumb question to most here, but i need some help and don't want to screw the pooch
just picked up an omnikey 101 cheap, nothing special- white alps, other than being a little dirty it is a really nice board
for whatever reason the caps on this thing were real tight.........probably never been off before
so when taking apart, yanking the caps to clean i yanked the cap and switch off the plate, pcb.
the prongs are fine, push back without breaking, bending anything, but the switch is dead i guess because 1 of the solders broke off and i am probably not making contact with the other?
just so i don't screw up or melt anything do i just re solder the prongs back so the switch will work again?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline esoomenona
  • Gnillort?
Re: Need Help- Popped a Switch
« Reply #1 on: Mon, 28 October 2013, 10:57:29 »
Can you take a picture of it? It's possible you ripped the trace from the PCB and might have to use some wire to fix it.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Mon, 28 October 2013, 11:22:02 »
here you go.........
Offline esoomenona
  • Gnillort?
« Reply #3 on: Mon, 28 October 2013, 11:23:30 »
Yes, you see all that white under the green? That's the trace. And you ripped a portion of it out on both sides. I don't know why it runs in that grid pattern though, so I can't really direct you from here... But someone else will be able to, I'm sure. But that's why it's not working anymore.
« Reply #4 on: Mon, 28 October 2013, 11:26:57 »
Usually it's to save on PCB production time (and cost), as all copper that's not used has to be removed, so the less copper that has to be removed, the less chemicals the use and the less time it takes. You also see it on ground planes for a number of different reasons.
You have two options here: either scrape off some of the green soldermask, exposing the copper and solder a bridge to there (perhaps with some wire) or solder a wire from the switch to another location, "replacing" the trace. I prefer option #2 and have done it a few times.
Just follow where the trace goes and solder the wire from the switch to that.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Mon, 28 October 2013, 11:28:57 »
i should have just left the tight ones and cleaned in place.
i understand and where you are talking
the trace is still in place on the one side, but do not know if it is enough to send the signal with one side being gone?
at least it is just the key to the left of the !/1, but still..........
  • Live long and prosper
« Reply #6 on: Mon, 28 October 2013, 11:31:32 »
What dorkvader said.  I used option 1 on my Genius M1 when I improperly removed a switch, and that fixed it quite nicely.
tp thread is tp thread
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Mon, 28 October 2013, 11:36:34 »
that makes sense.............i would assume i could pick up some copper or other small wire from radio shack, do a light scrape exposing the copper underneath and like you said solder a connection on that end back to the switch
i was able to save the trace on the one side and actually tried pushing the trace with solder back on to the switch prong on the 1 side, but no dice
so i am assuming that both sides require the connect for the signal to work?
