Since there never was a EU switch tester tour from Geekhack (at least that I know of), I want to change that. Here are my plans so far:
Switches that are going to be used in the tester:Linear: Red, Black, Vintage Black
Tactile: Brown, Clear, Ergo Clear 62g, Panda Clear, Matias Quiet
Clicky: Blue, Green, White, Matias Clicky
Buckling Spring and Topre would need some special stuff so I won't be able to offer them.
Build:I want to do a case similar to GONs cases, a metal plate on top with an acrylic layer below. The tester should not be opened by the users, so I chose to use cutouts that don't allow to open the switch. Since the case itself should not be opened either and to keep the design clean, I thought about just glueing each layer on top of the other with some epoxy. I am not sure about this yet, if something breaks inside it would be extremly hard to fix it. On the other hand, I don't plan on putting much inside.
Another thing I thought about was putting some LEDs in the acrylic layer, and maybe on the switches as well. The LEDs would be powered by USB (the USB connection would just serve as a power source). The LEDs would light up the outside of the acrylic layer and also a Geekhack logo. The metal and acrylic plates will look something like this (there would also be a third layer to close it off):
CAD stuff:Just as a disclaimer, I never did anything with CAD before so don't murder me if I did somehting wrong. The original CAD files were done in QCad on my netbook. I then found out that AutoCAD is free for students and use that now, but tbh I liked QCad a bit better. In AutoCAD its seems that some of the lines aren't properly connected anymore and off by some tiny tiny bits. I will fix that soon.
The files are attached, feel free to play around with them.
Execution:I'm currently trying to get in contact with somebody at my Uni that knows if students can use the laser cutter for private stuff and I don't know how much it will cost me yet. The people participating will probably have to pay a small fee to get some of the costs back. If I get any extra money that will go to other GH projects or get donated to Geekhack. Please tell me what you think of this!
Next step:-> 1. Get acces to the laser cutter2. Fix any problems with the design
3. Get it cut
4. Get some missing switches (Red, 3 Clears, Green)
5. Assembly
Any suggestions and criticism is appreciated!Oh crap, almost forgot,Thanks to JDCarpe for helping me with the CAD!
