Author Topic: Poker II Remap Caps/Ctrl  (Read 4736 times)
Offline reziak
  • Topre/60% Enthusiast
« on: Wed, 30 October 2013, 15:45:21 »
Hey all,
I tried to find other topics about this - because I'm sure it's been talked about - but I was wondering what the best way to switch Caps Lock and Control on my Poker II. If it's a software, are there any that can save and switch profiles? The reason I ask is that I'm thinking of getting an HHKB soon and wanted to be able to switch to my Poker II with reds for some gaming, but would like to retain Ctrl in the HHKB position all the time. Thanks for your help!
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline BlueBär
Re: Poker II Remap Caps/Ctrl
« Reply #1 on: Wed, 30 October 2013, 17:43:19 »
The Poker 2 is fully programmable so you can easily change it, here is a translated version of the user manual: http://geekhack.org/index.php?action=dlattach;topic=42554.0;attach=19145
Offline laffindude
« Reply #2 on: Wed, 30 October 2013, 21:56:50 »
Stop calling it fully programmable, because it isn't.
Offline PointyFox
« Reply #3 on: Wed, 30 October 2013, 22:09:04 »
Maybe you can do it with AutoHotKey software.  You can't do it with just the Poker II hardware.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Wed, 30 October 2013, 22:39:56 »
Just throw away the poker and buy a hhkb :3
Offline reziak
« Reply #5 on: Thu, 31 October 2013, 04:20:50 »
Fantastic idea! By the way, can I borrow some cash?  ;D
But seriously, it's going to happen at some point....
Offline reziak
« Reply #6 on: Thu, 31 October 2013, 04:21:32 »
I wish it were that easy! Thanks for the input though.
Offline BlueBär
« Reply #7 on: Thu, 31 October 2013, 05:35:13 »
Shouldn't it be possible to program it on the pn layer and then use the dip switch to permanently enable the pn layer?
Offline PointyFox
« Reply #8 on: Thu, 31 October 2013, 05:42:22 »
There is no DIP switch that does that on the Poker 2.
Offline terran5992
« Reply #9 on: Thu, 31 October 2013, 05:58:22 »
Oh wow , i always thought that there were
Offline BlueBär
« Reply #10 on: Thu, 31 October 2013, 07:27:36 »
Oh you're right, I misunderstood something I have read. So yeah I would recommend AHK too then.
« Reply #11 on: Thu, 31 October 2013, 07:40:01 »
Another option you might try is keytweak
