Author Topic: console controller usb adapters  (Read 1815 times)
Offline jinxedx84
« on: Thu, 31 October 2013, 04:44:34 »
anyone have any experience with nes/snes/n64/gc to usb adapters. trying to relive my child hood here and about to pick up some. Mainly just seeing if anyone knows of things to stay away from. I have actual controllers here for all the systems so i would like to use them.
http://www.mayflash.com/Index.html
I cant pick them up on amazon all but an NES adapter for around 37 dollars, thoughts? I dont want to mod the controllers i currently have, just saying
thanks for any imput
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
Offline terran5992
  • One With The Cup Rubber
Re: console controller usb adapters
« Reply #1 on: Thu, 31 October 2013, 06:05:34 »
Dayumm , that explains how people get so good at Call of Duty
Offline Latin00032
« Reply #2 on: Thu, 31 October 2013, 07:04:33 »
Most of my experience with regards to many adapters that I have used is that they introduce input lag. I notice it more because the original nes connected to a crt.
You have to mod the controller internally to reduce the input lag created by the adapter taking so long to process and converter the input commands.
« Last Edit: Thu, 31 October 2013, 07:06:28 by Latin00032 »
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #3 on: Thu, 31 October 2013, 20:37:09 »
you can always build an nes adapter yourself if you have a spare half hour or so
http://www.bidouille.org/elec/usbnesadapter
iirc i think sega and such will work the same way. just need to adjust code slightly for the extra buttons
"Obviously, windows are central to Windows. But what is a window?"
