Author Topic: HHKB 3?  (Read 5115 times)
Offline ValerieV
HHKB 3?
« on: Thu, 31 October 2013, 20:37:58 »
Do you think, or has anyone heard, anything about a new model of the HHKB? I would love it if the space bar was reduced, dedicated arrow keys and bluetooth. Thanks.  ;D
Offline Michael
  • Formerly Bro Caps
Re: HHKB 3?
« Reply #1 on: Thu, 31 October 2013, 20:39:29 »
You are asking for an HHKB Pro2 JP, basically. You could always do a bluetooth mod yourself, but I don't foresee that happening with their official products.
http://www.pfu.fujitsu.com/hhkeyboard/lineup/pdkb420w.html
But there is no HHKB 3, officially
« Last Edit: Thu, 31 October 2013, 20:42:27 by Bro Caps »
Offline Sniping
Re: HHKB 3?
« Reply #2 on: Thu, 31 October 2013, 21:09:40 »
Not an HHKB but I Realforce is considering making a Bluetooth board.
Re: HHKB 3?
« Reply #3 on: Thu, 31 October 2013, 21:11:45 »
Hasu's chipset for HHKB has potential for wireless, assuming that's still a work in progress.
Offline redskull
Re: HHKB 3?
« Reply #4 on: Thu, 31 October 2013, 21:39:45 »
DAT SPACEBAR...  :confused:
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: HHKB 3?
« Reply #5 on: Thu, 31 October 2013, 21:42:46 »
JIS HHKBs are just some PFU marketing bull**** for Japanese buyers... it isn't the layout that Dr.Wada had in mind when he helped create it and the function layer really ceases to make as much sense as it does on the HHKB Pro2
Re: HHKB 3?
« Reply #6 on: Thu, 31 October 2013, 21:43:43 »
My R-Shift key is bigger than your space bar :p
Offline AKIMbO
  • HHKBro
Re: HHKB 3?
« Reply #7 on: Thu, 31 October 2013, 21:49:48 »
And it's programmable!
| KBD75 (box reds)
