Author Topic: Where can I find green unprinted/blank thick pbt caps?  (Read 2506 times)
Offline platypus
  • dongerino adventures
« on: Sun, 03 November 2013, 17:58:42 »
Pretty much ITT. :)
The caps are going to be for a Poker II, so cherry caps with standard ANSI layout iirc
« Last Edit: Sun, 03 November 2013, 18:01:03 by platypus »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Where can I find green unprinted/blank thick pbt caps?
« Reply #1 on: Mon, 04 November 2013, 10:44:04 »
Closest thing to what you want that may be available at times is DSA keycap from Signature Plastics. Otherwise Cherry profile best bet would be to buy white set and dye.
Offline platypus
« Reply #2 on: Mon, 04 November 2013, 13:55:21 »
The DSA ones look like thin PBT caps to me, thanks for the help though.
Where would I buy a white set, and how hard is dyeing them?
« Reply #3 on: Mon, 04 November 2013, 15:03:15 »
True, DSA is not superthick but they are better than say KBC, Ducky regular...
For thick Cherry profiles try message imsto and/or feng and see if they have any left. Dye is not too hard, I dyed this ones purple with RIT
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #4 on: Tue, 05 November 2013, 15:39:05 »
elite keyboards has them. And blue, and red.
« Reply #5 on: Tue, 05 November 2013, 15:44:32 »
?? Thick PBT?
Offline C5Allroad
« Reply #6 on: Tue, 05 November 2013, 15:53:03 »
Oops. Didn't see that it's ABS… Last I looked at them it was about 2 months ago. Well that leaves you and I looking for some…
Offline gh_pp
« Reply #7 on: Tue, 05 November 2013, 16:52:07 »
I ordered this and it arrived yesterday
http://www.banggood.com/PBT-87-Set-Blank-White-Key-Caps-For-Cherry-MX-Keyboard-p-84084.html
Free shipping worldwide. Took 2 weeks to arrive at US.
There are 2 good reviews on that site.
From what I'm told they are medium thickness. Not imsto thick but not thin either.
I'll do a review when I got it this weekend or next
« Last Edit: Tue, 05 November 2013, 16:53:39 by gh_pp »
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
