Author Topic: spray painting a filco  (Read 2834 times)
Offline rekanise
« on: Mon, 04 November 2013, 10:05:58 »
Hi I apologize if this is a stupid question, but I've been toying with the idea of spray painting my filco, I'm guessing that I would have to take it apart and this would cause a void in warranty? I was wondering if there was ways that people have found how to avoid doing this,
Re: spray painting a filco
« Reply #1 on: Mon, 04 November 2013, 16:18:28 »
You can definitely spray paint your Filco, if you wish to do so. I know that user Photoelectric had done that to at least one of hers.
But yeah, you will want to disassemble it before attempting to paint it, so that you can paint only the case (and only the outside of the case at that). You will probably want to sand it first, to prepare the surface for the paint.
Around here, most people aren't too concerned with warranty issues. If something breaks, they either fix it themselves, or find someone who can fix it for them. :)
Edit: Be sure to check this out.
« Last Edit: Mon, 04 November 2013, 16:20:29 by jdcarpe »
« Reply #2 on: Mon, 04 November 2013, 16:19:30 »
But it WILL void your warranty.  There is a warranty sticker on the back and you have to break the sticker to remove the screw that will allow you to remove the top cover.
« Reply #3 on: Mon, 04 November 2013, 16:20:22 »
If and when you decide to paint you can check some good tips here
http://geekhack.org/index.php?topic=44191.0
« Reply #4 on: Mon, 04 November 2013, 16:21:00 »
Edited that link into my post above, haha.
« Reply #5 on: Mon, 04 November 2013, 16:21:41 »
:thumb: It's good enough info to be posted twice haha
Offline rekanise
« Reply #6 on: Thu, 07 November 2013, 10:05:38 »
hey thanks guys so much for all the helpful feedback, will review and post pictures when i m done
