Author Topic: The Geekhack Glossary  (Read 218598 times)
Offline BlueBär
Re: The Geekhack Glossary
« Reply #150 on: Mon, 30 March 2015, 07:31:08 »
I don't think adding something that barely even is a thing would be useful. I mean the thread is only 2 pages long, and there are no pictures apart from 3D renders of it yet. If it becomes more popular, sure.
Offline bcredbottle
« Reply #151 on: Fri, 10 July 2015, 14:57:43 »
What is OG? For example, "OG Cherry" or "OG Dolch"
« Reply #152 on: Fri, 10 July 2015, 15:10:35 »
Original.  It really stands for original gangster. One of the first people in a gang. In this context it means original though.
Offline bcredbottle
« Reply #153 on: Fri, 10 July 2015, 18:36:40 »
Ah. Ty
Offline iFreilicht
« Reply #154 on: Wed, 08 June 2016, 04:18:44 »
5. Scoops are just better than bars.
What are Scoops/Bars? Those aren't mentioned in the glossary.
Sentraq S60-X, dyed blank PBT keycaps, Gateron Browns
« Reply #155 on: Wed, 08 June 2016, 05:41:18 »
Welcome to Geekhack!
They are differences on the F and J keys to help touch-typists find the home keys.
Bars are short raised sections along the lower edge of the keycap.
Scoops are where the keycaps are dished slightly more than the other keys.
There are also nubs - small raised pimples usually in the centre of the keycap, although you're more likely to find those on the 5 key on a numeric keypad.
Bars are, of course, the best option out of these :p
Offline iFreilicht
« Reply #156 on: Wed, 08 June 2016, 08:26:47 »
I see, thank you very much!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #157 on: Fri, 10 June 2016, 17:02:55 »
So far for me, bars have been the only option haha. Seems like the other two are unique to keyboard hobbyist shops or vintage keyboards. IDK about the raised dots, maybe for the older cellphone keypads?
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #158 on: Thu, 27 October 2016, 14:01:39 »
Two terms I keep seeing are 'Alps' which I think is a switch manufacturer?? and  '1800' and that's one that I'm not sure of, might be worth adding...
« Last Edit: Thu, 27 October 2016, 14:30:56 by dead_pixel_design »
Offline Crapbag
« Reply #159 on: Fri, 28 October 2016, 10:00:39 »
Alps is a switch manufacturer and 1800 refers to a compressed keyboard layout that includes a Numpad.
« Reply #160 on: Fri, 28 October 2016, 11:43:05 »
Awesome thanks! That helps. Would be a good addition to the list
Offline iFreilicht
« Reply #161 on: Sat, 29 October 2016, 12:35:27 »
Alps can also refer to a stem/mount design for keycaps. The Alps mount is used by Alps switches and by Matias switches and looks like this:
« Reply #162 on: Wed, 02 November 2016, 15:02:31 »
ANSI should be in this glossary as well
Offline keykaiser
« Reply #163 on: Thu, 10 November 2016, 18:50:30 »
Also BigAss.
« Reply #164 on: Sun, 20 November 2016, 01:40:02 »
Also BigAss.
Just means extra large super big.  Not really a keyboard-specific term.
Often used in reference to Enter keys that are abnormally large.
« Reply #165 on: Thu, 05 January 2017, 17:15:15 »
Can't wait for the rest.
« Reply #166 on: Thu, 05 January 2017, 19:05:47 »
Does OP ever get updated on this?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #167 on: Thu, 05 January 2017, 20:46:44 »
OP is still an abbrev for original post or poster ;)
« Reply #168 on: Thu, 05 January 2017, 23:25:50 »
oh no
not another romevi dadposter
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #169 on: Fri, 06 January 2017, 09:23:19 »
oh no
Did you hear about the guy who invented Lifesavers? They say he made a mint.
« Reply #170 on: Fri, 06 January 2017, 09:38:49 »
oh no
oh no
Hue-izard.
Offline BlueBär
« Reply #171 on: Sun, 15 January 2017, 10:36:10 »
Yeah just update it!
Offline paecific.jr
« Reply #172 on: Thu, 23 February 2017, 13:01:01 »
Alps need some love.
First Mechanical Keyboard: IBM Model F 122
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #173 on: Sun, 10 December 2017, 13:02:53 »
Will Windows 98 be added to the Geek Hack Glossary?
Offline JP
« Reply #174 on: Wed, 13 December 2017, 10:24:57 »
Since Windows 98 is so ubiquitous it would be redundant to add this to the glossary.
About Me | The Collection
Offline BlueBär
« Reply #175 on: Tue, 02 January 2018, 12:51:55 »
Thank you for your suggestion! I've added it to the glossary.
« Reply #176 on: Tue, 02 January 2018, 13:01:50 »
Wow.....who is this guy?? :eek:
« Reply #177 on: Thu, 25 January 2018, 16:11:12 »
People do come back, you know...
:P
Offline proto
« Reply #178 on: Sat, 27 January 2018, 12:28:06 »
Thanks for this topic!
« Reply #179 on: Sun, 28 January 2018, 04:12:18 »
Hopefully it helps.
If there's any other terms you're (or anyone's) not sure about, feel free to ask :)
Offline cyber5am
« Reply #180 on: Fri, 02 March 2018, 08:37:34 »
Being a relative newcomer to the wonderfully obsessive world of keyboards i think the Glossary is an excellent way for the noobs like me to get acquainted with the terminology used by the community.
« Last Edit: Fri, 02 March 2018, 09:07:43 by cyber5am »
Offline cyber5am
« Reply #181 on: Fri, 02 March 2018, 08:57:45 »
I think it would be useful to have reference to the new and hybrid switches available ie:zealios,Tealios,zealiostotle,cherrystotle,zilents,hako,halo...etc this may have been done elsewhere on GH but i think the Glossary should be a one stop shop for terms and abbreviations that aren't immediately recognised.
Offline BlueBär
« Reply #182 on: Fri, 02 March 2018, 12:56:55 »
There definitely should be a summary somewhere how they differ, in what variations they're available and which ones are great, good or trash. I don't think that fits in here though, and I don't have enough knowledge about them to create anything like that.
« Reply #183 on: Sun, 04 March 2018, 03:36:46 »
Terms and abbreviations, yes, but not necessarily a technical discussion of the differences between all the various switches.
Perhaps noting that X, Y and Z switches are compatible with Cherry switches would suffice.  And maybe noting one particular aspect of those switches that differentiate them from vanilla Cherry switches.  Zealios - switches designed by Zeal with a distinctive purple slider.  Something like that.
Offline Cptspok
« Reply #184 on: Mon, 30 December 2019, 08:40:59 »
HI, thanks for the glossary!
I'm absolutly new to this so I thought I'd read the glossary first.
It's great but some word can be odd for a newbie. You describe DSA and SA as "DSA: The short spherical keycap profile used by Signature Plastics." "SA: The tall spherical keycap profile used by Signature Plastics."
I thought they were typewriter style keycaps. Isn't the word "Concave" more fitting for the definition? Again, I just discovered the keyboard world, maybe it makes sense to describe them as "spherical".
« Reply #185 on: Mon, 30 December 2019, 10:09:24 »
Generally, the concave surface of old (pre-1980s) keys tended to be "spherical" (that is, a high edge all the way around) and modern ones are usually "cylindrical" (with high edges on the sides but not top and bottom).
My guess is that since manual typewriters took a firm solid strike to actuate, there needed to be a well-defined depression for your fingertip to press and not slide out of.
- D Trump 2026-10-24
