Author Topic: Gateway 2000 not anykey programable doh'  (Read 5458 times)
Offline lam47
« on: Mon, 05 January 2009, 03:37:39 »
Yeah so I thought I was getting the anykey programable model and I didnt.
So what do you think? Worth a clean up or straight in the bin :) its a harsh world.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline cchan
« Reply #1 on: Mon, 05 January 2009, 20:24:54 »
I think it's worth a cleanup. Those are some of the better rubber dome boards imo. Could you also edify my curiosity by checking if the keycaps fit on Cherry MX? I know Cherry MY keycaps work on MX boards, I have about half the keycaps on my MX11800 from a semi-dead black MY8000 board.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline D-EJ915
« Reply #2 on: Mon, 05 January 2009, 22:37:45 »
you can always keep it as a spare keyboard, believe me you can never have enough of those.
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Tue, 06 January 2009, 00:20:14 »
Not if you have a couple durable boards in the first place. ;)
Offline lam47
« Reply #4 on: Tue, 06 January 2009, 03:50:08 »
Hey. They do fit MX switches yeah. Also it feels like there might be springs in the switches which is interesting.
Will try and get a better look :)
