Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2127706 times)
Offline Zeal
    • Zeal Generation Inc.
Re: < SPRIT Model 1 > PCB + Case + Parts ... (Preparing to Ship 1st Round)
« Reply #2100 on: Thu, 01 May 2014, 23:57:37 »
does anyone have a picture of what the "frosty" color option looks like for the plate or case?
Frosty raw acrylic plate/case before being laser cut:
http://geekhack.org/index.php?action=dlattach;topic=50580.0;attach=56776;image
Offline archer
« Reply #2101 on: Fri, 02 May 2014, 07:39:26 »
Shouldn't frosty be white in color, not blue? If you look in the OP, Sprit posted a pic called "1A 60% mini White 23 .jpg".. I think that top layer is frosty.
I'd link the pic, but i have no clue how :[
Offline Defect
« Reply #2102 on: Fri, 02 May 2014, 08:09:18 »
http://geekhack.org/index.php?topic=50580.msg1266826#msg1266826
I'm still searching through for clear frosty vs white frosty.  Or is there only one frosty?
Offline TheMoonUnderWater
Does the plate allow for switch removal without desoldering? Could I use another 60% plate with this PCB?
According to pictures sprit has provided it looks like its switch removable. You should also be able to use another plate for the 60% such as a beast plate! Just remember if you use leds in your switches you cant remove them either way.
Unless you use SIP sockets, which I will be using on this board and would recommend.
Excuse my extreme ignorance but is there a particular type/spec of SIP socket to use?
Of course not all sip sockets are made to fit keyboards but many do like these ones: http://www.ebay.com/itm/3Pcs-Single-Row-40Pin-2-54mm-Round-Female-Pin-Header/140910386490?_trksid=p2052191.m2067&_trkparms=aid%3D555003%26algo%3DPW.CAT%26ao%3D2%26asc%3D23%26meid%3D3295674393841359663%26pid%3D100028%26prg%3D1009%26rk%3D4%26rkt%3D15%26sd%3D221186042943%26 They are confirmed to work!
Thank you!  :thumb:
Offline fatchoi
« Reply #2104 on: Sat, 03 May 2014, 01:40:42 »
I've bought some from Taobao in China.
http://img01.taobaocdn.com/imgextra/i1/1652639502/T2S3FWXC4XXXXXXXXX_!!1652639502.jpg
Cheap and convenient to use.
Offline minho
  • i'm kind of back
« Reply #2105 on: Sat, 03 May 2014, 23:06:35 »
Does anyone know when Round 2 orders will end?
And just to double check, will the 60% PCB/metal plate fit a case made for the Poker II? (I read that it does for round 1, but I'm not sure if any changes have been made since then).
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2106 on: Sun, 04 May 2014, 08:42:14 »
Yes it does fit!
Offline minho
  • i'm kind of back
« Reply #2107 on: Sun, 04 May 2014, 13:40:03 »
Yes it does fit!
I just had another thought - does the teensy alignment on the PCB line up with the hole on the Poker II case? And what kind of teensy should I order for this anyways for that matter? (Model number)
Sorry first time ever building a board, and I have an extra Poker case lying around that I want to use but no experience whatsoever :p
Offline BlueBär
« Reply #2108 on: Sun, 04 May 2014, 13:46:52 »
You don't need a Teensy for this, the ATMega is already on the board.
Offline minho
  • i'm kind of back
« Reply #2109 on: Sun, 04 May 2014, 14:28:52 »
Oh. So then all I would have to do is
1. solder in diodes
2. put a few switches in the plate and solder those to the pcb
3. put rest of switches in, soldering as a go
and if I wanted to make the whole keyboard backlit, I would solder switches in first, and then the LEDs?
Offline yicaoyimu
« Reply #2110 on: Sun, 04 May 2014, 14:32:15 »
1. solder in diodes
EDIT: ignore whatever I said.
« Last Edit: Sun, 04 May 2014, 14:38:25 by yicaoyimu »
Offline HPE1000
  • Keycap Paparazzo
« Reply #2111 on: Sun, 04 May 2014, 14:34:30 »
1. solder in diodes
Yes. Switch first, then LEDs. But if you want LED, you will have to solder resistors before you solder switches.
You don't need to solder resistors before switches. Why do you say that?
Offline yicaoyimu
« Reply #2112 on: Sun, 04 May 2014, 14:37:57 »
1. solder in diodes
Because... I'm dumb? Because that's the order I usually do it. And after a second thought I realize the resistors are on the back of PCB and there's nothing to prevent you from soldering resistors even if you have plate and switches in place. My bad.
Offline minho
  • i'm kind of back
« Reply #2113 on: Sun, 04 May 2014, 14:59:38 »
1. solder in diodes
Still more knowledgeable than me, thanks!
Offline HPE1000
  • Keycap Paparazzo
« Reply #2114 on: Sun, 04 May 2014, 15:09:59 »
1. solder in diodes
It's all good, I just didn't know if there was a reason that I didn't know   :p
Offline minho
  • i'm kind of back
« Reply #2115 on: Sun, 04 May 2014, 22:46:15 »
Can't seem to find this in the OP, does anyone know how much an aluminum plate for 60% costs?
Offline nuclearsandwich
« Reply #2116 on: Sun, 04 May 2014, 22:49:51 »
Prices are in the order form.
Offline minho
  • i'm kind of back
« Reply #2117 on: Sun, 04 May 2014, 22:59:34 »
Whoops, didn't see that. Thanks!
Also, does anyone know an approximate date these will be produced/shipped?
Offline Zeal
« Reply #2118 on: Sun, 04 May 2014, 23:08:39 »
Quite a while. Sprit and his friends are handling this gigantic GB. Sorting, packing & soldering up diodes/resistors on PCBs take A LOT of time.
Most people are still waiting for their first round of orders.
Offline minho
  • i'm kind of back
« Reply #2119 on: Sun, 04 May 2014, 23:27:54 »
Oh I see. So it will take at least about a year to a year and a half reasonably before the parts would arrive at my door?
Offline Zeal
« Reply #2120 on: Sun, 04 May 2014, 23:33:40 »
Haha, hopefully not! Second round PCBs are supposedly factory pre-soldered, so it should help speed things up.
Offline minho
  • i'm kind of back
« Reply #2121 on: Sun, 04 May 2014, 23:57:55 »
And I'm guessing that the deadline to order is just until the MOQ is met?
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2122 on: Mon, 05 May 2014, 00:45:31 »
Oh I thought round 1 had it too :(
« Reply #2123 on: Mon, 05 May 2014, 00:48:53 »
If you've already paid, you might have round 1.  I'm still waiting on mine.  Hopefully it will be soon.
Offline Zeal
« Reply #2124 on: Mon, 05 May 2014, 01:09:02 »
Round 1 is being hand soldered, due to not hitting MOQ req for factory pre-sodlered boards.
Offline minho
  • i'm kind of back
« Reply #2125 on: Tue, 06 May 2014, 21:12:26 »
Are invoices for Round 2 going to be sent out after MOQ has been met?
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #2126 on: Tue, 06 May 2014, 22:20:50 »
Yes!   when the most of the Round 1 shipped out.
I am trying all shippiments to be nice and clean.
Now doing PCB + Case + Parts Shipping.   - Soldering PCBs,  Assemble Cases, ...
It takes so much time, I feel Terribly Sorry for everyone  :(
« Last Edit: Tue, 06 May 2014, 22:25:47 by sprit »
Offline bakteria
I don't know if mine had been sent out yet but no need to solder mine. I'll sort that out :)
SS 7G black - Pure red - poker blue (MKC Tray)
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
I guess yours' is round 2 so you he haven't started
Offline bakteria
No, I'm round 1 actually.
Offline ckywylee
« Reply #2130 on: Wed, 07 May 2014, 04:59:04 »
I want to buy 60% PCB only. Is it pre-soldered all diode, resistance and controller?
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
« Reply #2131 on: Wed, 07 May 2014, 11:10:01 »
Does the 60% pcb support HHKB layout? Are there any blockers?
« Reply #2132 on: Wed, 07 May 2014, 15:14:30 »
Round 2 will be. Round 1 was supposed to be but didn't meet MOQ for factory soldering so Sprit and his team are doing the SMD soldering by hand. That's part of the reason round 1 has stretched so long.
Offline minho
  • i'm kind of back
« Reply #2133 on: Wed, 07 May 2014, 15:55:28 »
Are there resistors for all the switches? Or just caps lock/numlock, etc.
Offline DamienG
    • DamienG
« Reply #2134 on: Wed, 07 May 2014, 15:57:29 »
Are the aluminum plates in round 1 now available?
Offline sprit
« Reply #2135 on: Thu, 08 May 2014, 19:36:08 »
Hello!  DamienG!  ;)
I will check the factory,  tell You soon!
« Last Edit: Thu, 08 May 2014, 19:45:04 by sprit »
Offline sprit
« Reply #2136 on: Thu, 08 May 2014, 19:44:07 »
Hello!  Dear Guys!   ;)
When I am ready to ship each box,  I usually send PM and recheck the orders and address.
So there will be No surprise EMS at your door.
I am focusing on ship the orders as much as I can this month.  ;)
*  I have recovered from sickness and exhausted last month.    >:D >:D
« Last Edit: Thu, 08 May 2014, 19:57:54 by sprit »
Offline tjweir
« Reply #2137 on: Thu, 08 May 2014, 19:47:27 »
Nice!  Go Sprit!
Offline swill
  • builder & enabler
    • swillkb.com
Looking forward to these builds. Keep up the good work sprit. Make sure you get factory soldered next round. :P
Offline fatchoi
Great. Fighting. Sprit. ;D
Offline Zeal
« Reply #2140 on: Thu, 08 May 2014, 20:37:17 »
Keep up the good work! Looking forward to see these boards ship out!
Offline sprit
Looking forward to these builds. Keep up the good work sprit. Make sure you get factory soldered next round. :p
Sure,  I will !   Thanks !!!    >:D
The PCB only orders will ship more next week.
Offline sprit
« Reply #2142 on: Fri, 09 May 2014, 18:57:19 »
Case Inspection almost done  -  I will post the Results.
-  It's Laser cut & CNC machined - Not perfect at all, but tried to get better within limits.
-  Cases will be shipped out full assembled -  I found it's much harder to pack unassembled.
-  The PCB only Orders will be shipped first,  then PCB +Case shipping.
64234-0   64230-1   64232-2   64236-3
« Last Edit: Mon, 09 June 2014, 20:16:41 by sprit »
Offline fuus
  • All Year Christmas!
« Reply #2143 on: Sat, 10 May 2014, 08:06:09 »
Nice work Sprit!  :cool: they look great
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline Lubed Up Slug
« Reply #2144 on: Sat, 10 May 2014, 17:25:04 »
What sort of layouts does the 60% PCB support? Will it support a Pure layout, with a shortened right shift, and alt, super, fn, and ctrl all on the bottom row right of the spacebar?  Also around when should we expect to see the round 2 PCBs shipping?
Here are some pictures someone posted on reddit a few days ago of a completed board
and another one
« Last Edit: Sat, 10 May 2014, 17:26:50 by Lubed Up Slug »
Offline Pacifist
  • on hiatus
« Reply #2145 on: Sat, 10 May 2014, 17:27:47 »
and another one
lol pretty sure that 2nd board is a spirt board posted here on gh
Offline yicaoyimu
« Reply #2146 on: Sat, 10 May 2014, 17:29:02 »
The bottom row layout could be either 1.25 1.25 1.25 6.25 1.25 1.25 1.25 1.25 or 1.5 1 1.5 7 1.5 1 1.5. So basically winkey layout and winkeyless layout. The right shift could either be 1.75 + 1 or 2.75.
Offline yicaoyimu
« Reply #2147 on: Sat, 10 May 2014, 17:30:19 »
and another one
Riotonthebay.
Offline cphead
« Reply #2148 on: Sat, 10 May 2014, 17:32:46 »
and another one
Riotonthebay.
Those are actually the same board as I bought it from riot. LOL
« Reply #2149 on: Sat, 10 May 2014, 17:36:19 »
and another one
Riotonthebay.
Well great looking board, singular.   :thumb:
