Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2174799 times)
Offline hermith
Isn't 45 USD for 90 MX switches really cheap? I'm relatively new to the scene but that seems very cheap, don't they usually go for 1.25-2 USD per switch? :)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
I get it From Hongkong.
Offline hermith
Okay cool. Is it the same PCB for ISO as for ANSI, not special I have to note on the order form?
Offline kenmai9
  • Unicornforce
  • Skrrr
Is anyone offering switches and assembly service for this group buy?
Unless you are looking for uncommon switches like whites, they are usually less than that.
Sprit's price of $45 for 90 switches is a good deal, similar to MK's listing of clears.
Offline Kit-Bar
What benefits does the 4mm plate vrs the 2mm plate have? And what are the difference between the poly acrylic and acrylic plates? Sorry im new to this. I want to make one of these :D
Also does this come with the LEDs or do we have to buy the LEDs separately? reread the original post
Offline sprit
4mm plates sounds really thick.  Is anyone getting those as well?  What's the difference between PolyAcry and PolyCarb?  I know they are different materials, but has anyone used both?
Edit: Ordered!
http://www1.kbdmania.net/xe/freeboard/7302594
The Maximum thickness for MX is 5mm.    In this GB,
1. Acryl Plate : 5mm (5T) thick :  In My Opinion :  Strong and Soft, Rigid enough ...
2. PolyCarbon : 1.6mm thick :  In My Opinion : quite Strong and flexible, ...
3. Alu Metal  :  1.6mm thick :  In My Opinion : Noisy, Not Strong enough, we know its pros and cons.
4. Alu Metal  :   4mm + 1mm PolyAcryl  : In My Opinion :   Armour itself.
« Last Edit: Sun, 17 November 2013, 13:52:48 by sprit »
Offline Zeal
    • Zeal Generation Inc.
I have a question Sprit. How does a multi colour LED fit in a MX switch? Or does it go somewhere else?
Offline elllit
Ok, ordered 2x60%with keys (clears and browns), leds (red and blue) and plates (5mm acryl red, 4 mm alu gun metal).
Now to the cases... this is gonna be expensive.
Offline xandr
Are the plates universal for ANSI and ISO?
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline longweight
  • philanthropist
New order submitted :D
Ordered :D
Offline longweight
  • philanthropist
If we get multicolour LEDs can we control the colour output from them with the PCB?
Offline pasph
On Nov.19 you open payments only for layouts that hit the MOQ right?
Offline fuus
  • All Year Christmas!
Order resubmitted! This looks AMAZING Sprit!
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline tjweir
Order resubmitted!
Sweet.
  • Live long and prosper
Welcome to Geekhack! (or should I say Wallethack) :))
tp thread is tp thread
Offline sprit
Yes!  Sir !
And the Multicolour LEDs  Control ItSelf !!
Reference !
http://geekhack.org/index.php?topic=35864.msg1118856#msg1118856
http://www1.kbdmania.net/xe/photo/7647437
A.87 PCB    by Bro. Lewi     (aka  써러써러 시로씨로 베리 하드 막씸 쎈횽니무스) = A Notorious Korean Stand Up Comedian.
« Last Edit: Sun, 17 November 2013, 20:17:14 by sprit »
Offline sprit
« Last Edit: Sun, 17 November 2013, 22:24:53 by sprit »
Offline Kit-Bar
I think im going to go for the 87. I have never made one of these before but I think it will be fun! I hope this isnt too crazy haha I was initially going to get a 60 as well but I think I should try 1 first then decide if I want to make another at a later date if you have another GB. :D or maybe ill get both... not sure lol
« Last Edit: Sun, 17 November 2013, 20:41:43 by Kit-Bar »
Offline swill
  • builder & enabler
    • swillkb.com
Sprit, I have a question about the plates.  In some of the previous comments you have mentioned that the plates are 'like the phantom', which I understood to include cutouts so the switch tops can be removed.
None of the plates I have seen you link images to have cutouts for the switches to be removed.  I would like to verify that the plates have cutouts so the switch tops can be removed without having to desolder from the PCB.
Thanks...
Offline sprit
Thanks...
Please Bet On Me !  :thumb:     I prefer the plates have cutouts so the switch tops can be removed without having to de-solder from the PCB,  As You Beautifully Pointed Out !  :-*
« Last Edit: Sun, 17 November 2013, 21:33:17 by sprit »
Offline sprit
For Your Reference
44571-0
Offline Kit-Bar
dont we have to remove the plate if we insert LEDs though? ie desolder everything
Offline sprit
KryTox 103  104  105       http://www1.kbdmania.net/xe/photo/7639160
44581-0
« Last Edit: Sun, 17 November 2013, 21:32:12 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
Same as Normal LEDs.
https://www.google.co.kr/search?q=multicolor+Led&newwindow=1&espv=210&es_sm=122&source=lnms&tbm=isch&sa=X&ei=-XiJUvWuCMnFkgXJjYHABQ&ved=0CAkQ_AUoAQ&biw=1429&bih=891
(Attachment Link)     (Attachment Link)   M = Multi LEDs
What plate is this?  It is like a 75% but with an extra row of 1x1 keys on the left.  And it doesn't have cutouts.  :(
Offline Zeal
I thought multi LEDs have 4 legs? A cherry MX switch only has 2 cutout holes...Did someone invent a 2 leg multi-LED?
Offline sprit
Offline mickd
The order form is missing a line in the address for the building name.
Should I just write it into the street line?
Offline keymaster
  • Topre Revolution Theorist
Maybe I'm not looking carefully enough, but can someone point me to pictures of the different types of plates? I see pictures of cases and PCBs but no plates.
Offline sprit
OK  Sure !  Mr!
As we know, the Address Form differ in Every Country.
Offline sprit
Terribly Sorry for that!
When it meets the MOQ, and Produced and Anodized well, I will Show You Guys.   It's Phantom Style!   We know well what it is.
« Last Edit: Mon, 18 November 2013, 00:12:18 by sprit »
Offline keymaster
Doesn't matter. I ordered anyway. 87 is glorious  :cool:
Edit: I might have to change some things since the format is a little confusing
« Last Edit: Mon, 18 November 2013, 00:27:45 by keymaster »
Offline phatdood9
Any way you can split the cherry mx switches to 45 qty? I only need a few reds for modifiers and clear for the rest :(
Also, are cherry mx switches plate mount or pcb mount?
Thanks for organizing this :D
Offline keymaster
I'm such a noob when it comes to this.
What plates do I order to replicate this? I want to have black top, clear middle, and black bottom.
Offline sprit
Not a problem at All !!  ;)    Please Write down on your Order Form ~   Cherry mx switches are Both plate mount And pcb mount.   I will check this option and again when I send Invoice to You.
« Last Edit: Mon, 18 November 2013, 00:58:25 by sprit »
Offline sprit
And  You will get a Black H-Beam separating the Function Row,  Num Pad, and Arrows. This inclued in Your Case Price  80 USD.
THe Plate...  IF I Should recommend a Plate for Your Black match,
1.   Black PCB + Clear Plate
2.   White PCB + Clear Plate   /    White PCB + White Plate
3.   Red PCB + Clear Plate  ?  Your favorite?
4.  Blue PCB + Clear Plate
5.   Black PCB + Clear Plate  /Black PCB + Black Plate
« Last Edit: Mon, 18 November 2013, 04:49:54 by sprit »
Offline Fritz
Can you order just switches and springs?
Offline sprit
Sure!   :)
Offline Fritz
Offline kektr0city
Are you offering 60% plates?
Offline sprit
Sure !  Mr.!   and three different materials : PolyAcryl 4.5~5mm, PolyCarbonate 1.6mm, Alu metal 1.6~2.0mm,  Alu 4mm.
Offline sprit
OK.  Osxoep  I got Your Order!
Offline xandr
Okay, maybe I'm missing it somewhere, but are the plates universal to support ANSI and ISO at the same time, or do we have to specify the layout in the order somewhere, Sprit?
Offline kektr0city
What are the 60% layout options?
Offline fatchoi
Edit: Ordered!
Oops, after reading your post, I've changed my mind in which plate to order...
And I'm thinking about ordering a few more switches.
How do I change my order please?
Offline roadblock2thesun
Are there different plates for 87 key, 86 key, 84 key layouts?
Offline osxoep
nice. I hope it was all okay :)
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline keymaster
What is 'Black H-Beam'?
Offline Grendel
Ordered  60% and 110% PCB + Al plates, 110 red LEDs, 110 white LEDs.
- I'm game !
