Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2224188 times)
Offline fuus
  • All Year Christmas!
Re: SPRIT Model 1 : Poker, 60% 75% 87% 110% : ANSI + ISO (Full LED + HW Macro)
« Reply #900 on: Mon, 09 December 2013, 11:07:26 »
Thanks again for running this Sprit! You're a great guy  :cool:
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline YongJK
« Reply #901 on: Mon, 09 December 2013, 12:17:57 »
I have a trik v6.2 pcb coming.
I just want to ask your metal casing will fit it or not ?
Keyboard: PLU ML87 Mx Blue
Offline Permeability
« Reply #902 on: Mon, 09 December 2013, 12:23:15 »
Hi sprit,
Received the LEDs today, thanks! is there anything I need to do?
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline taylordcraig
« Reply #903 on: Mon, 09 December 2013, 14:16:30 »
Thanks a lot for the info, I'll be placing my metal case preorder today.
I would love a couple plates that I can open switches with, are there all the sizes for these?
Forgive me as I seem to have overlooked this somehow.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #904 on: Mon, 09 December 2013, 20:30:24 »
Hi sprit,
Good News !   When You get EMS,  Please reply to Paypal for Delivery Status!  :thumb:
« Last Edit: Tue, 10 December 2013, 00:15:53 by sprit »
Offline sprit
« Reply #905 on: Mon, 09 December 2013, 20:32:23 »
Korean Team Redline TriK PCB follows  the A.87  87% Standards, So No Problem at all, I guess!    :thumb:
« Last Edit: Tue, 10 December 2013, 17:29:09 by sprit »
Offline sprit
« Reply #906 on: Mon, 09 December 2013, 20:34:23 »
Hello!  taylordcraig !  How Are You?
The plates You can open switches  !
There are  all the sizes for these : 60% 75%  87% 110%  :thumb:
Offline Cottonsox
« Reply #907 on: Mon, 09 December 2013, 20:45:23 »
Trying to find the post regarding what each switch is suitable for pcb/plate mount but cannot se to find it on my phone. Anybpdy have the information available.
Offline sprit
« Reply #908 on: Mon, 09 December 2013, 20:47:41 »
Hello  Cottonsox!
All The PCBs support Both pcb/plate mount.    the Swich will be mainly PCB mount Type ! :thumb:
Offline sprit
« Reply #909 on: Mon, 09 December 2013, 20:49:06 »
Thanks again for running this Sprit! You're a great guy  8)
Cheers!  Mate!   fuus  :thumb:
Thank you for the warm support!!
« Last Edit: Tue, 10 December 2013, 00:51:43 by sprit »
Offline Cottonsox
« Reply #910 on: Mon, 09 December 2013, 20:54:15 »
So which switches will support plate mount, I may have to edit order as I am planning on plates for my builds.
Offline sprit
« Reply #911 on: Mon, 09 December 2013, 21:07:37 »
OK!  If You want  the Plate mount SWs,  Please make  remarks!   Cottonsox!   ;)
I got ordered enough SWs for each Type!
Offline Cottonsox
« Reply #912 on: Mon, 09 December 2013, 21:11:44 »
Do I need to do a new order or should I pm you?
Offline Latin00032
« Reply #913 on: Mon, 09 December 2013, 21:27:56 »
Does this case support the hhkb layout of the gh60?
I think it does. I was looking at the order form. I can't see an option for it.
Offline sprit
« Reply #914 on: Mon, 09 December 2013, 21:28:24 »
Ok!  PM please Mate!   I will correct Your Order Form!     :thumb:
Done !!  :thumb:
« Last Edit: Mon, 09 December 2013, 21:35:57 by sprit »
Offline sprit
« Reply #915 on: Mon, 09 December 2013, 21:30:19 »
OK!  It Supports HHKB!   Please make Remarks on Your Order Form!
GH60 PCB is Great! I love it,  My Favorite!    :thumb:
« Last Edit: Mon, 09 December 2013, 22:47:57 by sprit »
Offline jorgenslee
« Reply #916 on: Mon, 09 December 2013, 23:22:59 »
Hi Sprit,
Does the firmware for the pcb supports using spacebar as fn key? More info here: http://geekhack.org/index.php?topic=51069.0
Thanks
Offline sprit
« Reply #917 on: Mon, 09 December 2013, 23:48:46 »
Hi Sprit,
Thanks
Basically Possiblee!    :)
  47456-1 47459-2 47461-3
« Last Edit: Tue, 10 December 2013, 00:01:07 by sprit »
Offline jorgenslee
« Reply #918 on: Tue, 10 December 2013, 00:34:10 »
Hi Sprit,
Thanks
(Attachment Link)   (Attachment Link) (Attachment Link) (Attachment Link)
wow, that just made my day. Thanks.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #919 on: Tue, 10 December 2013, 03:32:07 »
Done !!  :thumb:
Could you do that to my order too? I ordered 90 clear switches I got invoice number 1284! :)
Offline cookiesowns
« Reply #920 on: Tue, 10 December 2013, 04:44:24 »
Sprit, do you recommend Plate or PCB switches?
I don't plan on using the switches on any other PCB, and I like having a more "solid" switch too !
Offline Elias Camber
« Reply #921 on: Tue, 10 December 2013, 05:15:19 »
good call... I would also need plate mounted switches.
Didn't think about it since I ordered one PCB, one Plate, I assumed it would be logical.
Sorry for any inconvenience.
Offline Jinryuixi
« Reply #922 on: Tue, 10 December 2013, 07:09:02 »
Hi sprit! First of all I want to thank you everything you do.
I've some questions:
-I've got the new Ducky Shine 3 TKL edition, and when I did the order of the case I chose the option: "87% Filco, Leopold, Ducky, CM Case : How many You want?" and I just writted "1", I didn't especified that I wanted one for the Ducky. Does this matter?
- The other thing I want to know is if this case is compatible with my ducky.
Thank you very much!
Offline sprit
« Reply #923 on: Tue, 10 December 2013, 17:41:51 »
Muchas Gracias!
I made a Note on Your Order  : For Ducky...   I will prepare Cases for Ducky  and I will show You soon!  :)
47589-0
« Last Edit: Tue, 10 December 2013, 20:04:09 by sprit »
Offline sprit
« Reply #924 on: Tue, 10 December 2013, 17:46:37 »
Das ist Gut!    Elias Camber !  :)
I prepared both,  and I will Ask Again before Shipping!
But Usually PCB mount Type is Good for Both PCB/Plate Mount!
Guten Tag!
« Last Edit: Tue, 10 December 2013, 19:22:53 by sprit »
Offline sprit
« Reply #925 on: Tue, 10 December 2013, 17:56:45 »
Hello! Signature!  OK  1 min !   :)
I checked the Invoice 1284  and the Order  Form, I sent PM      :)
« Last Edit: Tue, 10 December 2013, 18:09:52 by sprit »
« Reply #926 on: Tue, 10 December 2013, 18:18:46 »
I didn't realize there were switches being sold here as well... How do I order switches, can I combine them with a metal case order when they come around?
Sorry for all the questions.
Offline AKmalamute
  • HHKB Scrub
« Reply #927 on: Tue, 10 December 2013, 18:58:36 »
The switches are mentioned the same place you order the PCBs. So I guess if all you want are switches, you can specify 0 PCBs and the requisite number of switches to go with your case.
HHKB-lite2, Dvorak user
Offline bazh
« Reply #928 on: Tue, 10 December 2013, 23:14:29 »
anyone in batch 2 get invoice ? just wondering
HHKB Pro2 white
Newbie again
Offline SigLogical
  • 5 prototypes built
« Reply #929 on: Wed, 11 December 2013, 01:48:29 »
Just sent a order  :D looking forward for everything  :cool:
HHKB Pro Hybrid Type-S
Offline bakteria
« Reply #930 on: Wed, 11 December 2013, 03:23:13 »
Ripstertip: I generally buy PCB mount switches and use a Xacto knife to shave off the pins if I need to.
SS 7G black - Pure red - poker blue (MKC Tray)
Offline IMHB
« Reply #931 on: Wed, 11 December 2013, 04:40:49 »
Hey Sprit!
I want to add a 87% acryl case to my order...but you've already sent me invoice for my 60% case order so....do I just fill in another form for it?
Hank
Offline sprit
« Reply #932 on: Wed, 11 December 2013, 04:49:49 »
Hey Sprit!
Hank
Hey IMHB!    New Order will be nice, Because I will send the Shipping Invoice Soon, with the rest things People get and New orders.
The Shipping Cost will be different to the each weight as We know.   I 'd EMS!    :)
Offline Jinryuixi
« Reply #933 on: Wed, 11 December 2013, 04:51:43 »
do we recieve the invoice in our paypal account... right? Me still not  :p
Offline sprit
« Reply #934 on: Wed, 11 December 2013, 07:43:21 »
Dony Worry!  Senor!    I  need time to check all orders and to write the New Invoices  :)
http://www.youtube.com/watch?v=oFRbZJXjWIA
« Last Edit: Wed, 11 December 2013, 07:56:22 by sprit »
Offline IMHB
« Reply #935 on: Wed, 11 December 2013, 07:45:41 »
Hey Sprit!
Hank
alright, I'll submit a new order with one 87% case~
thanks!
Offline jorgenslee
« Reply #936 on: Wed, 11 December 2013, 08:32:33 »
Hi Sprit,
Just submitted a new order to update my old order.
Thanks
Offline aaronz8
« Reply #937 on: Wed, 11 December 2013, 13:50:12 »
Do these pcbs/plates fit in any case designed for 60% 75% 87% 110%? I wasn't sure if there is a standard for case fitment. Thanks!
Offline Melanic
« Reply #938 on: Wed, 11 December 2013, 13:59:20 »
47674-0
Hello.
Just received the LED's today. I should really get a soldering iron soon...
Offline AKmalamute
  • HHKB Scrub
« Reply #939 on: Wed, 11 December 2013, 14:33:22 »
Standard of fitment has been one of the big things Spirit is striving for, to judge by how often he says any combination will work. While I haven't seen a good shot of his PCBs yet, I assume he's got holes everywhere so all the "standard" cases for boards of that size can accept his PCBs.
He should correct me, though, if there are some combinations that just won't work because that's silly. Let's see what he says.  :cool:
Offline sprit
« Reply #940 on: Wed, 11 December 2013, 17:04:10 »
Hello.
HELLO!     :)    !    Would Please  Send Feedback with Your Invoice or Papal, You got it delivered~
« Last Edit: Wed, 11 December 2013, 18:53:14 by sprit »
Offline sprit
« Reply #941 on: Wed, 11 December 2013, 17:10:30 »
Hello!  This is the most Serious Subject !  :)
As Mr. AKmalamute beautifully Pointed Out,   SPRIT  Model 1 (2,3) PCBs will fit well  :
For 60% Poker compatible cases  : Yes! 100%
For 75% MX-mini  compatible cases  : Yes!  100%
For 87% TKL compatible cases  :  Yes! for the Plate mount(But need to check the position of USB connector),  No! for the PCB direct mount to the case (No cases are Ready for that by Now, but mine)  For Philco, Leopold, Ducky, I prepared extra Fitting Holes.
« Last Edit: Wed, 11 December 2013, 18:45:28 by sprit »
Offline sprit
« Reply #942 on: Wed, 11 December 2013, 17:20:15 »
PayPal Renewal SetUp Complete!
Thanks for Everyone!   I Love You Guys !    ;)      Muchas Gracias!
Anyone already got the proper Invoices, may Pay Now Slowly.
The Invoices Not sent Yet, will be Send Soon in this week!
47683-0
« Last Edit: Wed, 11 December 2013, 18:52:18 by sprit »
Offline HPE1000
  • Keycap Paparazzo
« Reply #943 on: Wed, 11 December 2013, 17:24:54 »
 :thumb:
Offline tjweir
Awesome!!
Offline Zeal
    • Zeal Generation Inc.
Re: SPRIT Model 1 : Poker, 60% 75% 87% 110% ANSI+ISO (Full LED+HW Macro) - Payment
« Reply #945 on: Wed, 11 December 2013, 18:27:10 »
Awesome!  :D
Offline xandr
« Reply #946 on: Wed, 11 December 2013, 18:58:16 »
I just paid!
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline sprit
« Reply #947 on: Wed, 11 December 2013, 19:00:28 »
I just paid!
I got Yours!  5 min ago !   Cork  Guy !!    Is It OK there?   here Freezing cold.
« Last Edit: Wed, 11 December 2013, 19:50:28 by sprit »
Offline sprit
« Reply #948 on: Wed, 11 December 2013, 19:51:18 »
Hi Sprit,
Thanks
I got it  and will send Your Invoice soon!
« Last Edit: Wed, 11 December 2013, 20:01:30 by sprit »
Offline sprit
« Reply #949 on: Wed, 11 December 2013, 20:23:28 »
What is Your Color ?   (Just for a Break)   :)
47718-0   47720-1   47716-2
« Last Edit: Wed, 11 December 2013, 20:33:06 by sprit »
