Author Topic: GMK Mini packs (completed)  (Read 297268 times)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: GMK Mini packs (payments due!!!)
« Reply #750 on: Thu, 30 January 2014, 23:02:55 »
I've made some assumptions based off your clues and a lot of maths. Can you look below and confirm or deny?
  • There are 6 colors in the code (going off your "4 rows have 1 color, 1 has 2, 1 has none. 2 columns have 2 colors, 2 have 1" comment). 7 colors total but one is unknown so we'll ignore that.
  • One of them has 6 characters in it's original color code and 5 of them have 2 characters in the original color codes (ie. XXXXXX; XX; XX; XX; XX; XX). This took a bit of maths, I'll explain how I got there if I'm right. If I'm wrong then I'm officially tapped out for ideas.
Offline domoaligato
« Reply #751 on: Thu, 30 January 2014, 23:06:20 »
Offline bueller
  • MX baller
« Reply #752 on: Thu, 30 January 2014, 23:14:00 »
http://www.random.org/ ? :D
It's killing me man! I've been into crazy puzzles ever since my first playthrough of Myst when I was like 10 years old :D
Offline bueller
  • MX baller
« Reply #753 on: Fri, 31 January 2014, 09:10:50 »
Iiiiiiiiiiivaaaaaaan. Put me out of my misery man :P
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #754 on: Fri, 31 January 2014, 11:51:41 »
You've done some good work there. You are indeed on the correct path. There are 2 colors with a color code longer than 2 characters.
Confirmation of buellers work will serve as the most recent clue.
« Reply #755 on: Fri, 31 January 2014, 12:52:11 »
Given past info, I think we can also assume that the layout for the rows & columns is the following:
_______________________________________
|UN0001   | CP           | 3K             | 2M |
|L9            | U9           | 2B            | CC |
|N9           | CR           | 3B             | AE|
|N7           | UN6037  | N5            | V4 |
|UN5046  | 3C           | UN33656  |V1  |
|V2           | N6           | CV             | ?
« Reply #756 on: Fri, 31 January 2014, 12:58:02 »
Yes that is correct, might be useful for those that can't see all the color codes in the photo very well.
« Reply #757 on: Fri, 31 January 2014, 13:20:04 »
I'm also making a semantic assumption based on the confirmation of longer than 2 , but not confirmation of 6 that one of the two longer ones confirmed is magenta since it's the only one with seven alphanumeric characters.  That could also be in line with the one word clue of seven.
« Last Edit: Fri, 31 January 2014, 16:59:05 by nubbinator »
« Reply #758 on: Fri, 31 January 2014, 16:30:31 »
The number seven refers to the number of different colors that spacebars will be made for this order.
Offline GeeNDL82
« Reply #759 on: Mon, 03 February 2014, 05:15:21 »
paid :D
Vietnam Mechanical Keyboard Club: http://vietnammechkey.com/
« Reply #760 on: Tue, 04 February 2014, 06:53:07 »
Will you be cancelling unpaid invoices today or tomorrow? I'll be paying late today (EST), so I just want to be sure.
Offline asura
  • not a duck
« Reply #761 on: Tue, 04 February 2014, 07:11:53 »
Payment sent - apologies for not getting it out sooner, simply hadn't noticed the invoice and don't check here perhaps as often as I should.
« Reply #762 on: Tue, 04 February 2014, 09:09:49 »
Payments on your orders are due today. Please try your best to make payment as soon as possible.
Offline GeorgeK
« Reply #763 on: Tue, 04 February 2014, 13:56:42 »
If you need it I'll pick up another esc pack or two - are there many unpaid?
Offline bueller
  • MX baller
« Reply #764 on: Tue, 04 February 2014, 14:03:48 »
Ditto, I'd like another couple of Esc packs if there are any free.
« Last Edit: Tue, 04 February 2014, 14:12:48 by bueller »
Offline padath
« Reply #765 on: Tue, 04 February 2014, 14:17:44 »
I'd like to add an escape pack to my order as well if there are any unpaid remaining.
« Reply #766 on: Tue, 04 February 2014, 17:15:09 »
As of now there are still about 25 unpaid orders... including a couple of really BIG ones for 50+ :(
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #767 on: Tue, 04 February 2014, 17:16:14 »
50+ items, or 50+ dollars?
That would be a huge bummer if the former :(
Edit: I'm hoping to be able to pick up a fairly large order…
Edit2: nvm :(
« Last Edit: Tue, 04 February 2014, 20:33:39 by riotonthebay »
« Reply #768 on: Tue, 04 February 2014, 17:17:24 »
make that 24
50+ items I assume
Offline redeye
« Reply #769 on: Tue, 04 February 2014, 17:25:05 »
Sherry's not up to his old tricks is he?  :p
« Reply #770 on: Tue, 04 February 2014, 17:27:54 »
Yeah big order for more than 50 item is what I meant. Even if they don't pay it I am pretty sure we are still in MOQ range, or close enough it shouldn't be impossible to recover if not all picked up.
  • Cherry Peasant
  • keycult.com
« Reply #771 on: Tue, 04 February 2014, 17:29:25 »
Got it. Well, that's good news at least. When I said I'd be interested in picking up a big order, I meant $50+, not 50+ items ;).
Offline jufa
« Reply #772 on: Tue, 04 February 2014, 18:15:17 »
kinda late here, do you still accept order ?
1 esc pack
about the space bar if i order 5, i'll get 5 different color right ? or ?
sorry about my ignorance  :-[
« Reply #773 on: Tue, 04 February 2014, 18:26:07 »
jufa, check back on the 6th. I will have posted what will be available for pick up then and will allow new orders to be placed for what is available. For those that order multiple spacebars, I will do my best to give you more colors but there is no promise... it all depends on the ratio those colors are made and delivered to me in. The earliest and first paid orders will get the most diversity as I tend to pack those orders first. Once colors run out later orders will get less colors probably.
Offline jufa
« Reply #774 on: Tue, 04 February 2014, 18:37:05 »
ok
2 esc pack
6 space bar
i'll wait
« Last Edit: Tue, 04 February 2014, 18:45:27 by jufa »
Offline slinky23
« Reply #775 on: Tue, 04 February 2014, 23:20:23 »
Sorry for the late payment, was on a holiday. Have just paid the invoice 5 minutes ago! Thanks.
« Reply #776 on: Wed, 05 February 2014, 15:00:15 »
I'm not sure I ever got invoiced for this. I know I revised my order once or twice before and after the MOQ's changed, can you confirm payment please Ivan?
Offline redskull
« Reply #777 on: Thu, 06 February 2014, 08:58:37 »
late again to the party, but..
if anyone is willing to let go his/her 7x white spacebar, do let me know. im looking for 1.  :D
« Reply #778 on: Thu, 06 February 2014, 09:03:21 »
I would say there will be a LOT of space bars for sale....
Offline redskull
« Reply #779 on: Thu, 06 February 2014, 09:24:02 »
« Reply #780 on: Thu, 06 February 2014, 09:37:22 »
Available for pick up:
0x spacebar
0x CMY Esc
Please PM me with what you would like, your paypal email, real name and mailing address and I will get you invoiced. Payment is due immediately. First come first served.
« Last Edit: Sun, 09 February 2014, 11:02:41 by IvanIvanovich »
Offline bueller
  • MX baller
« Reply #781 on: Thu, 06 February 2014, 09:41:28 »
PM'ed for 2 more Esc packs!
Offline shadewolf
  • ಠ_ಠ
« Reply #782 on: Thu, 06 February 2014, 09:49:17 »
PM'd!
Offline padath
« Reply #783 on: Thu, 06 February 2014, 11:19:34 »
PM'd. Hope I'm not too late.
Offline redskull
« Reply #784 on: Thu, 06 February 2014, 11:22:36 »
PM'd Ivan. please check.  :)
Offline gh_pp
« Reply #785 on: Thu, 06 February 2014, 16:06:44 »
4x spacebar
6x CMY Esc
noisyturtle, I had an order for you but I guess I missed sending your invoice. It has been sent now. Looks like I should check again to make sure I didn't miss sending anyone else.
I posted earlier but just to confirm, I'd like 1x esc and 2 more spacebar pack if available.
« Last Edit: Thu, 06 February 2014, 19:00:52 by gh_pp »
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
« Reply #786 on: Thu, 06 February 2014, 18:41:29 »
I missed marking a non paid big order earlier... so there is LOT of spacebar available. If they can't all be picked up it is fine, I only have to contact for invoice adjust.
Offline Photoelectric
« Reply #787 on: Thu, 06 February 2014, 22:15:47 »
:( Could add that to the title of the thread to attract more attention, perhaps?  Hope we can get all the orders needed.
Offline bueller
  • MX baller
« Reply #788 on: Thu, 06 February 2014, 23:00:37 »
If I understand Ivan correctly they shouldn't affect our MOQ being met, probably just need to reduce number invoiced by GMK.
Offline tbc
« Reply #789 on: Thu, 06 February 2014, 23:04:17 »
i'll take an order of spacebars! :D
are both the 7x and 6.25x going to be same color?  I'm assuming random.
« Reply #790 on: Fri, 07 February 2014, 08:16:59 »
Yes that's right. No worries about effect MOQ... spacebar is over 600 anyway. It won't be any big deal if the rest of the 20 spacebar isn't picked up... well at least I hope it change nothing, but it possible one less color. They might not want to change out color for smaller amount.
I try to give as many different color as I can in each spacebar order.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #791 on: Fri, 07 February 2014, 20:33:24 »
Ivan, how far along are you with collecting payments on these?
« Reply #792 on: Sat, 08 February 2014, 08:08:20 »
Only waiting on one person that had a very large order. Giving them some slack since they made arrangement with me prior. Assuming they pay as agreed I will make the order payment to GMK on Monday.
Offline tjweir
« Reply #793 on: Sat, 08 February 2014, 08:21:43 »
Nice!
Offline rainb1ood
  • so pretty so plastic
« Reply #794 on: Sat, 08 February 2014, 08:32:46 »
If someone is abandoning their x1 of each Esc, I'm willing to take their spot! :D
Re: GMK Mini packs (In production)
« Reply #795 on: Tue, 18 February 2014, 10:55:27 »
Order is in production, expected delivery in 4-6 weeks.
Offline tjweir
« Reply #796 on: Tue, 18 February 2014, 13:40:48 »
Woop!
« Reply #797 on: Tue, 18 February 2014, 15:49:10 »
HYPE
I'm very excited for this GB
Offline Pacifist
  • on hiatus
« Reply #798 on: Tue, 18 February 2014, 16:28:41 »
YAYAYAYAYAYy
Offline TheMoonUnderWater
« Reply #799 on: Tue, 18 February 2014, 17:08:30 »
Great news! Very excited
