Author Topic: Noppoo Choc Mini problem  (Read 1209 times)
Offline lazerzz
« on: Thu, 07 November 2013, 15:45:14 »
It is not typing when I turn on my computer, I have to plug it out of the USB port and plug it back in for it to work. However, when I turn on the Numlock, the numbers work fine. The problem is with the letters.
I tested the USB port with the mouse and it is working fine.
I have had the Noppoo Choc Mini Brown for a year now, this is the first problem I have with it.
I also tried uninstalling and re-installing the keyboard driver and that didn't seem to solve the problem either.  :confused:
Offline Linkas
Re: Noppoo Choc Mini problem
« Reply #1 on: Fri, 08 November 2013, 11:11:58 »
Try to enable IOMMU option in BIOS/UEFI. I had similar issue with my G80 and this helped.
G80-3000
