Author Topic: [WTB] 200 65g / brown / blue / red Springs ( CONUS )  (Read 1995 times)
Offline Thechemist
  • Trade Count: (0)
« on: Sat, 09 November 2013, 14:18:27 »
Looking for about 200 65g, brown, blue or red springs that you may have laying around and want to sell; prefer Conus.
« Last Edit: Wed, 13 November 2013, 09:06:46 by Thechemist »
  • Trade Count: (0)
Re: [WTB] 200 65g Springs ( CONUS )
« Reply #1 on: Sat, 09 November 2013, 14:57:49 »
YGPM momentarily
Offline Thechemist
  • Trade Count: (0)
« Reply #2 on: Sat, 09 November 2013, 15:05:00 »
Offline Thechemist
  • Trade Count: (0)
« Reply #3 on: Wed, 13 November 2013, 08:57:57 »
Bump
Offline berserkfan
  • Trade Count: (0)
Re: [WTB] 200 65g / brown / blue / red Springs ( CONUS )
« Reply #4 on: Wed, 13 November 2013, 09:21:13 »
Hey Chemist
I can sell you springs, no prob. But you don't want the switch stems too? I have like 200 browns, mostly new, from two Cherry G80s.
Also I thought these were 45g springs. Or are you not referring to Cherry MX?
BTW I followed your advice and got the TG3 BL82 to have red backlighting, but found I couldn't control the backlight intensity. Also, the backlight would turn off if I don't use the keyboard for a while (good) but I notice it makes a weird little humming noise when backlight is turned off. Do you have any advice for that?
Thanks once again. I loved that mod. It's a cute little keyboard.
Offline Thechemist
  • Trade Count: (0)
« Reply #5 on: Wed, 13 November 2013, 09:27:51 »
Can you post what you did to the bl82, what did you use for the 12v mod and how did you wired it?
« Last Edit: Wed, 13 November 2013, 10:28:00 by Thechemist »
Offline berserkfan
  • Trade Count: (0)
« Reply #6 on: Wed, 13 November 2013, 11:10:06 »
Um, you kidding me, right? You were the guy who taught me everything I knew, and I did everything here http://geekhack.org/index.php?topic=42981.0 except change the LEDs (so they are still red). So yup, I also followed your link to get the same voltage converter. There isn't anything I can add except ugly pictures of my incompetent soldering.
In fact, if you have any advice for changing select LEDs to other colors, I'm up for it. But I don't know much about these things. Just hoping to turn the keyboard into something like one of those Duckys with multiple colors on the same board.
Offline Thechemist
  • Trade Count: (0)
« Reply #7 on: Wed, 13 November 2013, 13:45:29 »
Let's continue this conversation in that thread, but from what i can see you did not specify which direction you were going and how you wired it. If you kept the red leds and used the converter like I have listed, there should not be a problem with turning the leds on and off or the dimmer function. If you replace the leds, keep them around same voltage value 2-2.4v so that you do not have to modify the resistors on the pcb.
« Last Edit: Mon, 18 November 2013, 12:03:35 by Thechemist »
Offline Thechemist
  • Trade Count: (0)
« Reply #8 on: Mon, 18 November 2013, 12:03:51 »
Bump
