Author Topic: Crude spacebar fix for my Model M  (Read 2788 times)
Offline FreeCopy
« on: Thu, 14 November 2013, 02:32:30 »
This was my solution at the time to fix the spacebar on my Model M. It was originally supposed to be a temp fix but it's been holding together for over 2 years now.
It's a 6/32(1/8" diam) screw with a 5/64" hole drilled through for the stabilizer bar.
4 pic album how it turned out.
http://imgur.com/a/wLlg6
In the 4th pic you can see a very slight bump on the front face where I just about ran the screw through.
This was a store room find that started with this and turned into a bolt mod.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Re: Crude spacebar fix for my Model M
« Reply #1 on: Thu, 14 November 2013, 03:14:48 »
Wow - neat!
I just sourced a replacement space bar for mine.
« Reply #2 on: Thu, 14 November 2013, 06:17:40 »
That is just Bad-Ass
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
« Reply #3 on: Thu, 14 November 2013, 15:58:36 »
I still have my old broken space bar - have to try to remember this in case one of the good ones also breaks.
You try doing that with the modern thin keycaps you get these days!
Offline FreeCopy
« Reply #4 on: Thu, 14 November 2013, 19:19:31 »
This was my main thought when going through the process.
Also, I was lucky it was this end. I'm still not sure how I would've worked around the other end being broken.
I still should look into a proper replacement. This fix added a lot of metallic noise. It is noticeably louder than the other keys. Not like it really matters with this board anyway. Just added one more trumpet to the marching band I suppose.
Keyboards
Offline 0100010
  • Not Sure
« Reply #5 on: Fri, 15 November 2013, 17:48:25 »
Very nice.  Could probaby use nylon machine screws to quiet it.
