Author Topic: Tight Cherry MX Clear  (Read 16402 times)
Offline jeffgran
Re: Tight Cherry MX Clear
« Reply #50 on: Sun, 17 November 2013, 16:57:01 »
Glad to know it's not just me. I had this problem with my clears on my ergodox and the blank black DSAs. On a couple of them I ripped off the whole top of the switch with the cap still on there, using the WASD key puller. I started wiggling back and forth while removing them and that seemed to help. But man, they really get stuck on there.
Offline terran5992
  • One With The Cup Rubber
« Reply #51 on: Sun, 17 November 2013, 19:24:17 »
Really? Wiggling seems to make it worse
« Reply #52 on: Sun, 17 November 2013, 19:31:26 »
The DSA are known to fit tighter anyways, it is part of their design. However there were some runs of DSA caps that had stem issues that made them even tighter, but that tooling was fixed a while ago.
Offline TheSoulhunter
  • ~ GHOST ~
Offline Dreamre
    • kbdlife
« Reply #54 on: Mon, 18 November 2013, 12:56:23 »
I find that once the clears have keycaps that are removed at least once, it gets easier to remove afterwards.
Offline Oobly
« Reply #55 on: Tue, 19 November 2013, 01:24:23 »
http://geekhack.org/index.php?topic=49752.msg1081987#msg1081987
This is a nice concept, but I just use a loose clear switch to do this. On and off a few times and voila!
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline terran5992
« Reply #56 on: Tue, 19 November 2013, 01:28:31 »
But what if the first time you put the caps on they get stuck
Offline Photoelectric
« Reply #57 on: Tue, 19 November 2013, 01:33:48 »
I'd test on one-two switches.   If too tight... probably wouldn't use those keycaps and save them for another keyboard with something other than Clears.  Or try some lubricant maybe.
Offline Oobly
« Reply #58 on: Tue, 19 November 2013, 03:21:12 »
It's easier to pull a stuck cap off a loose switch than one in a board. Wiggle while you pull. May feel like it isn't helping, but it does come off more easily. I have a set of really tight POM caps (Bangood ones) and a few times on and off again (3 or 4 per keycap) with the loose switch makes them loose enough to not worry about putting them on a board. A little tighter than stock ABS caps, but not so tight that they'd pull a stem out!
Offline terran5992
« Reply #59 on: Tue, 19 November 2013, 04:13:42 »
I managed to remove the stuck keycaps by using a pair of tweezers like this
« Reply #60 on: Tue, 19 November 2013, 11:22:39 »
This thread:  Giggity.
« Reply #61 on: Tue, 19 November 2013, 11:23:30 »
I'm seriously considering attempting to do something like that just for the heck of it.
Offline Oobly
« Reply #62 on: Tue, 19 November 2013, 11:27:08 »
Great! Congrats. Let us know if you come right with the one where the stem came out.
Offline Mikey Mo
« Reply #63 on: Tue, 19 November 2013, 14:06:22 »
Oh,...some keycaps is very hard to pull....need carefully , you can polish l think ,,just a suggestion
  • ~ GHOST ~
« Reply #64 on: Tue, 19 November 2013, 14:26:10 »
Me too, but as with most other projects I lack the time to actually do it... ^^;
« Reply #65 on: Tue, 19 November 2013, 14:54:57 »
Yes I know that all too well :(
