Author Topic: Spilled water on Poker :(  (Read 3805 times)
Offline Defying
  • (suffer on)
« on: Sun, 17 November 2013, 21:13:40 »
My friend was over playing League at my house and he accidentally spilled half a glass of water into my poker 2. He quickly unplugged it and poured out all the water and let it dry upside down for a few minutes.. and then plugged it in (even though I told him I was gonna use my QFR until it dries).
At first it seemed like it was working, then I opened up Aqua's key test. Whenever you press b, it puts b5. Press n, puts n6. And when you press U it activates the entire row...
Not sure what to do, would love to get this working again but I believe it's gone :(
edit: works fine now, locking topic
« Last Edit: Mon, 18 November 2013, 14:49:11 by Defying »
Offline Turkishrambo
Re: Spilled water on Poker :(
« Reply #1 on: Sun, 17 November 2013, 21:19:37 »
swithes should be okay, salvage for a gh60 :)
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Sun, 17 November 2013, 21:23:13 »
Should have let it dried for at least a few days
Offline Defying
  • (suffer on)
« Reply #3 on: Sun, 17 November 2013, 21:24:45 »
that's what I was gonna do but he apparently didn't get the drift :(
« Reply #4 on: Sun, 17 November 2013, 21:27:49 »
That sounds like a short between rows (or columns).
Maybe let it completely dry for a few days, and see if the situation improves.
If not, can you open it and see if there is a short?
Offline divito
« Reply #5 on: Sun, 17 November 2013, 21:29:31 »
Bury it in rice for awhile, lol.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline PointyFox
« Reply #6 on: Sun, 17 November 2013, 21:54:18 »
Yeah, I heard it attracts Asians whom will fix it for you.  :rolleyes:
« Reply #7 on: Sun, 17 November 2013, 22:13:35 »
This its actually legit. +1
Offline ithinkimkorean
« Reply #8 on: Sun, 17 November 2013, 22:15:45 »
Need to give him the wireless rubber domes as punishment for a while.
Offline WhiteFireDragon
    • youtube
« Reply #9 on: Sun, 17 November 2013, 22:26:26 »
There's your problem.
If you're impatient, the very least you could have done is take off all the caps and put a hair dryer on it. Try letting it completely dry now and test again. If it's still acting up, fixing anything except the actual controller is doable.
« Last Edit: Sun, 17 November 2013, 22:27:57 by WhiteFireDragon »
Offline Defying
  • (suffer on)
« Reply #10 on: Sun, 17 November 2013, 22:29:34 »
Yeah I know that's my problem. Except I wasn't the one that did that. :(
Oh well.. I'm probably just salvage the ergoclears and buy a GH60 kit from classifieds when they're out.
Offline missalaire
  • Great Finder of Great Finds
« Reply #11 on: Sun, 17 November 2013, 22:42:49 »
Make him buy you another one.
Offline Awful
  • Don't Topre.
« Reply #12 on: Sun, 17 November 2013, 22:54:32 »
:( Sorry for your loss, hopefully it can dry all the way out, but I agree with missalaire
I hate everything.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #13 on: Mon, 18 November 2013, 02:24:52 »
The bold part of the statement is where I think the sorting out with the mess has gone terribly wrong. With virtually any electronics, you never let the soaked device (especially if the liquid is not something like methylated spirits) sit for a few minutes in order to dry. You need to try the affected electronic thoroughly with things like microfibre cloths and maybe hair dryer. After you manage to get as much liquid out of the affected component you put the electronics in silica gel (where possible). Otherwise rice will do. This process requires plenty of time and patience in order to minimise the damage done to electronics.
Plugging the keyboard straight back into the computer after it has been dried for a few minutes is a huge no no. There would be traces of liquid still visible on the PCB itself but not clearly evident to the naked eye. If there were enough traces of liquid on the PCB and that it is being plugged in to some power source it will start shorting out areas of the board. In addition to all this, depending on the nature of the liquid that the electronic has been exposed to. A huge concern regarding things like rust that will eventually start infesting the affected component.
There's definitely a fair few information as well as videos out there telling how one should go about treating affected electronics. Clearly your friend here was panicking big time and making most of the wrong moves when it comes to affected electronics.
+1
I also agree there, if you don't have access to large amounts of silica gel, rice is the poor man's method of drying electronics after they have taken all the necessary steps in drying the said component. Rice is not as efficient as silica gel but is doable for most circumstances.
There isn't all that much other alternatives available, apart from it has never happened rice is by far the cheapest and mostly the reasonable option.
+1
I actually would like to say the same thing considering how your friend has treated your mechanical keyboard. Sure friends are nice but that whatever your friend did to your poor keyboard was both clueless and hesitant.
Maybe I am quite merciless but I believe it is justifiable. Mechanical keyboards aren't cheap generally.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline Defying
  • (suffer on)
« Reply #14 on: Mon, 18 November 2013, 14:48:39 »
just got bored and plugged it in to see if it was working... and it's alive! no issues with any keys, thankfully.
