Author Topic: FILCO Majestouch 2 vs FILCO Majestouch NINJA  (Read 8021 times)
Offline Luda
« on: Wed, 20 November 2013, 11:50:27 »
Are this models same with only different keycaps printing?
Or have some other changes?
Thanks
Offline Dreamre
    • kbdlife
Re: FILCO Majestouch 2 vs FILCO Majestouch NINJA
« Reply #1 on: Wed, 20 November 2013, 12:05:13 »
Same thing except the differences are with the keycaps.
The Ninja has a black logo (MJ2 has a silver logo) and it does not have the "Scroll/Caps Lock" text.
Offline Luda
« Reply #2 on: Wed, 20 November 2013, 15:24:01 »
Thanks.
I read somewhere about materials of keycaps. Majestouch 2 has ABS and Ninja has something other, is it true?
« Reply #3 on: Wed, 20 November 2013, 23:55:22 »
Thanks.
According to the reviewer from Nov 17th: http://www.amazon.com/Filco-Majestouch-2-Keyboard-FKBN104MRL-EFB2/dp/B007VAFWPA
"This is the second Filco board I've owned.
The build quality is amazing as usual, and the red switches are glorious.
The keycaps are kind of thin and the ABS caps go shiny pretty quick for me, but I always put some custom PBT caps on all my boards so this is a non-issue for most keyboard enthusiasts."
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #4 on: Wed, 20 November 2013, 23:58:54 »
Thanks.
same keycap material sir between ninja and MJ2 normal version
one side printing and one top printing ;)
Offline terran5992
  • One With The Cup Rubber
« Reply #5 on: Thu, 21 November 2013, 01:21:33 »
The filco logo on ninja is black in color
Offline AuRinBei
« Reply #6 on: Fri, 22 November 2013, 16:01:59 »
I was under the impression that the MJ2 has some UV coating to "protect" the printing, whereas the Ninja does not, for obvious reasons. I remember seeing a thread about it, specifically about the coating wearing off too easily, but I can't find it.
87u || Poker 2
Offline atlas3686
  • HHKB Elite
« Reply #7 on: Fri, 22 November 2013, 16:16:53 »
I've got both they exactly the same except for the printing.
From left to right: MJ2 ninja, MJ2, Ducky PBT
Offline terran5992
« Reply #8 on: Fri, 22 November 2013, 21:51:35 »
I dont think that they have a coating. Probably only coated on Backlit keycaps
