Author Topic: My Pimped Cherry G80-3000  (Read 6612 times)
Offline Justblair
    • Justblairs Audio and Electronics Pages
« on: Wed, 20 November 2013, 14:53:21 »
I finally got this project not only working, but written up somewhat on my website... I think this may be unique, though probably for good reason...
http://www.justblair.co.uk/pimped-robotic-cherry-g80-3000-keyboard.html
Offline MTManiac
Re: My Pimped Cherry G80-3000
« Reply #1 on: Wed, 20 November 2013, 14:55:28 »
say what???
Offline Neal
  • Skype: iNewbcake
« Reply #2 on: Wed, 20 November 2013, 14:57:55 »
That RFID reader is extremely cool!
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #3 on: Wed, 20 November 2013, 15:02:40 »
Lowrider!
« Reply #4 on: Wed, 20 November 2013, 15:03:25 »
But what switches does it have??
« Reply #5 on: Wed, 20 November 2013, 15:03:37 »
Wait, didn't you do this on another keyboard as well? I swear I've seen this elsewhere.
Regardless, that's awesome
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #6 on: Wed, 20 November 2013, 15:05:23 »
game changer
Offline tipo33
  • "Ski"
« Reply #7 on: Wed, 20 November 2013, 15:06:02 »
Wow, I love the sound with it too.  lol.
KM4COL    R.I.P.  SmallFry
Offline Justblair
« Reply #8 on: Wed, 20 November 2013, 15:06:26 »
You have seen one of the early tests of this keyboard. At that point I had not yet installed the capacitive sensing or RFID features
« Reply #9 on: Wed, 20 November 2013, 15:07:02 »
I thought someone did it with a model F?
Offline Justblair
« Reply #10 on: Wed, 20 November 2013, 15:09:06 »
Nooooooooooooooooooooooooooooooooooooo  :mad:
Offline Dubsgalore
« Reply #11 on: Wed, 20 November 2013, 15:10:00 »
woah..badass
nice work!
« Reply #12 on: Wed, 20 November 2013, 15:10:21 »
YES, It was you!!. That is amazing that you followed through and improved the design! :D
Also on a slightly off-topic note. I click on the link under your profile to go to your website. Your link doesn't work. It points to:
Code: [Select]
http://geekhack.org/www.justblair.co.uk
And I think it needs to point to:
Code: [Select]
www.justblair.co.uk
Offline Justblair
« Reply #13 on: Wed, 20 November 2013, 15:13:51 »
Code: [Select]
Code: [Select]
www.justblair.co.uk
thanks, I think I have fixed that now
« Reply #14 on: Wed, 20 November 2013, 15:14:26 »
Awesome :)
« Reply #15 on: Wed, 20 November 2013, 15:18:21 »
Code: [Select]
Code: [Select]
www.justblair.co.uk
Ok so hey at least I almost remembered correctly :P
Offline Justblair
« Reply #16 on: Wed, 20 November 2013, 15:20:03 »
So there was not an IBM?  Phew...
Offline Justblair
« Reply #17 on: Wed, 20 November 2013, 15:25:57 »
Cherry Blues... Seems to be the only choice for this keyboard and a UK layout
« Reply #18 on: Wed, 20 November 2013, 15:29:38 »
Ok so hey at least I almost remembered correctly :p
Just the terminal M you restored ;)
But seriously....I distinctly remember someone posting a model F with feet that actuated, because they had the gray tabs that stuck out on the sides.
Well it is PCB Mount so easy enough to swap stems/springs  :thumb:
Offline Justblair
« Reply #19 on: Wed, 20 November 2013, 15:33:09 »
Yep I have been looking at the thread where you can make ghetto blues by gluing the two part stem together.  I am not that keen on the noise.  The click is two high pitched, I prefer my Filco with browns over the Cherry with blues.
The Model M has a better sound altogether!
« Reply #20 on: Wed, 20 November 2013, 15:38:11 »
You mean jailhouse blues? You can also use an oring or small piece of plastic.
