Author Topic: Easy AVR USB Keyboard Firmware and Keymapper  (Read 2211582 times)
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
Re: Easy AVR USB Keyboard Firmware and Keymapper
« Reply #2250 on: Tue, 12 December 2017, 14:23:57 »
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
« Reply #2251 on: Tue, 12 December 2017, 14:39:44 »
https://kbdfans.myshopify.com/products/kbd75-keyboard-set
Does this help? :)
Yeah that should be good enough. If it's an AVR and code is on github then I can work it out. I'll need you to help me test, though.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #2252 on: Tue, 12 December 2017, 16:19:13 »
Does this help? :)
Absolutely :)
Am I out of luck for AVR & my Southpaw 65 based on TMK
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #2254 on: Wed, 13 December 2017, 09:11:26 »
Thanks man! I'm going to test it today after work :)
Edit: How did you want me to test it? By simply compiling it and testing the stock firmware you put on here?
« Last Edit: Wed, 13 December 2017, 09:13:26 by bmilcs »
« Reply #2255 on: Wed, 13 December 2017, 09:49:37 »
Just use it as you normally would. Create a layout and program it. KBD75 is very similar to the GH60 so I think it will work, but I'm not sure that I have the bottom row mapped right, especially the space.
You never have to compile anything with EasyAVR, just build and burn. I should note, though, that if they have installed a different bootloader then it won't work.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #2256 on: Wed, 13 December 2017, 18:57:54 »
You nailed it minus one key -- top right corner "Pause".
Thanks again for your hard work :)
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #2257 on: Wed, 13 December 2017, 18:59:08 »
NEVERMIND. I forgot I set that hotkey as "Boot". Works flawlessly!
« Reply #2258 on: Wed, 13 December 2017, 19:01:25 »
Cool. Now, does that board have any Lock LEDs? Also, what does it have for backlights? Is there RGB?
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #2259 on: Wed, 13 December 2017, 19:04:32 »
It has under PCB LED's built in. I believe you can add switch LED's as well.
« Reply #2260 on: Wed, 13 December 2017, 19:05:19 »
Do they work?
Offline jacob.stadtfeld
« Reply #2261 on: Fri, 15 December 2017, 00:16:08 »
Don't suppose this is the place to make a request for a new keyboard layout? I'm working with a Cherry SPOS G86-63401.
« Reply #2262 on: Fri, 15 December 2017, 08:28:13 »
EasyAVR only works on custom keyboards with AVR microcontrollers.
To program that Cherry SPOS you would use the tools provided by the manufacturer.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #2263 on: Sun, 17 December 2017, 15:08:15 »
Do they work?
Sorry just got around to recreating my layout within EasyAVR. But I'm having trouble figuring out how to create these keys:
LT(1, TAB)
So, holding it down is FN1 and tap = TAB key.
Is this possible in EasyAvr?
I tried setting the GUI Tab to FN1 and then Mode: Tap Key - TAB
« Reply #2264 on: Sun, 17 December 2017, 17:09:35 »
Do they work?
LT(1, TAB)
Yes it's possible and that should work. What part of the mapping isn't working for you?
« Reply #2265 on: Wed, 20 December 2017, 20:36:13 »
A new feature is coming to EasyAVR.  I have added a simple tool that can help you add support for new boards using input from keyboard-layout-editor.com.
It still takes some work with a text editor, because the data from keyboard-layout-editor.com doesn't contain any information about the IO pins that are used for the row/column matrix or LEDs.  However it's still a good shortcut.
Offline JustCallMeCrash
  • ErgoDox Lover
« Reply #2266 on: Thu, 21 December 2017, 06:07:45 »
I haven't read through the whole thread (shoot me), but is there any chance Preonic support may be added?  It would sure be nice to have a good gui for programming my flatboard of choice (I spend 95% of my time on ErgoDoxen).
ErgoDoxen 6 total: Cherry MX Browns, Cherry MX Clears, NovelKeys Box Royal, 80g Gateron Yellows, NovelKeys Pale Blues, NovelKeys Box Navy.
Preonic 2 total: OG Gateron Yellows (GMK silencer clips), TBD (unassembled v2).
XD-75 (mixed Gateron Yellows, MX Blacks, MX Clears on layer toggles).
Das S Professional (was MX Blues, now Ghetto Reds).
G80-11900.
ML-4400 (2x) Cherry MY boards.
« Reply #2267 on: Thu, 21 December 2017, 08:17:44 »
According to this page, the new Preonic boards come with the QMK bootloader.  I'm pretty sure it won't load my firmware.  If the rev1 pcb uses the standard USB bootloader, then that could work.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #2268 on: Thu, 21 December 2017, 19:55:30 »
Update - The KBD75 firmware seems to work great but the LED options don't seem to do anything. For whatever reason, only the top left LED is lit up (underneath the PCB).
Can you fix this by any chance?
« Reply #2269 on: Fri, 22 December 2017, 09:47:22 »
Probably because the KBD75 has RGB backlighting.  I don't own any keyboards with RGB backlighting, so it isn't supported.
I copied the hardware definition from the QMK firmware: https://github.com/qmk/qmk_firmware/blob/master/keyboards/kbd75/config.h
From that, I included pin B6 as a backlight, though I have no idea what purpose it serves on the KBD75.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #2270 on: Thu, 28 December 2017, 10:45:19 »
I'm interested in playing with this as i'd like to add first the JD40 MkII layout with the 6.25 space (i figure this is an easy place for a noob to start) but then i'd love to add in the QMK port for the Duck Lightsaver v3 once i have a better understanding of how.
So yeah, i'd love some more info on this and i'll get started.
-Dana
« Reply #2271 on: Thu, 28 December 2017, 10:46:56 »
It's in the readme on Github. It's still takes some hacking, but it a  bit quicker
Offline OfTheWild
« Reply #2272 on: Thu, 28 December 2017, 11:02:49 »
Ok i'll see if i can figure it out - the section about "supporting custom boards" i assume? I'd love to get more involved with this project.
-Dana
« Reply #2273 on: Thu, 11 January 2018, 04:30:13 »
Just returned from hiatus and tried this - very impressed, it even chose the appropriate sixty/tkl firmware base in case anyone's brave enough to handwire a big board :thumb:
How are you getting on with your customising OfTheWild?
« Reply #2274 on: Thu, 11 January 2018, 07:34:58 »
Thanks.  My next step will be to record a video of me adding support start to finish when something is requested.  The hope is that users can start to do it on their own.
« Reply #2275 on: Fri, 12 January 2018, 04:06:25 »
^ Sounds good, though it seems pretty self explanatory - maybe I'm biased having played with it manually.
I've just tested adding a new board on a fresh Linux install and got an error about encoding using python 2.7.13 (the one used by default) but it worked when I switched to 3.4.6 - no idea what else I've broken by manually switching though, so please don't add it to the readme...
« Reply #2276 on: Fri, 12 January 2018, 06:53:32 »
That bug has already been submitted on Github and fixed.
Also, use 3.6 dude.  2.7 is old and busted.
« Reply #2277 on: Fri, 12 January 2018, 10:18:29 »
Good to know, was only packaged recently so you've been busy :)
It's a fresh install of Open Suse so surprised it's so out of date - 3.4.6 is the latest (stable?) version available so that will do for now.
« Reply #2278 on: Fri, 12 January 2018, 10:25:34 »
Really? Wow. Python 3.7 is already in alpha. I guess OS moves slowly.
« Reply #2279 on: Fri, 12 January 2018, 10:42:28 »
Hmm, that makes me wonder what else is out of date... Time for a change of distro!
Offline deacon
« Reply #2280 on: Mon, 22 January 2018, 08:19:38 »
Jack Humbert says that his new bootloader should be DFU compatible, unfortunately I don't have the new bootloader on anything to test.
https://www.reddit.com/r/olkb/comments/7qht0f/jacks_weekly_update_question_thread_for_2018w03/dsytfd6/
« Reply #2281 on: Tue, 23 January 2018, 11:46:17 »
That's good - the firmware is available so you can see the pins to use the built in 'Define new keyboard' and add it, you'll also need a KLE export.  Metalliqaz was looking for someone to test this, well volunteered  ;)
Unrelated - is anyone using this in Linux?  I just tried to build and flash and I'm getting the error below on two GH60 boards - one works and the other I've just unwrapped ready to build so it should work.  I probably broke my python but no idea how to check, changing debug to a different number changes it at the top but no useful output :confused:
Code: [Select]
sudo dfu-programmer atmega32u4 flash --debug 10 Keyboards/EasyAVR-2.05.11/keymapper/GH60.hex
     target: atmega32u4
    chip_id: 0x2ff4
  vendor_id: 0x03eb
    command: flash
      quiet: false
      debug: 10
device_type: AVR
------ command specific below ------
   validate: true
   hex file: Keyboards/EasyAVR-2.05.11/keymapper/GH60.hex
Checking memory from 0x0 to 0x6E7F...  Empty.
0%                            100%  Programming 0x6E80 bytes...
[ X  ERROR
Memory write error, use debug for more info
Will have to try in Windows.
Edit:  The hex from Windows is indeed different, but it fails to flash  (in Linux) with the same error.  Probably a flasher problem...
« Last Edit: Tue, 23 January 2018, 12:01:11 by suicidal_orange »
« Reply #2282 on: Tue, 23 January 2018, 13:10:13 »
Eh, that should not be the case.  The build should be identical regardless of platform, as long as you are using the same version of the software and the same map.
I have never programmed with linux so I can't be much help.  If you are able to program a file with Windows then that would clear the keymapper of any wrongdoing.
The error message doesn't give us much to work with.   Are you sure that the board is staying in bootloader mode?
« Reply #2283 on: Tue, 23 January 2018, 13:28:32 »
Thinking about it the Windows version has the UTF8 fix so it would be different.  Linux has always just worked in the past and I've tried an old hex as well and that doesn't flash either - the finger of blame is definitely pointing at the flasher.  Need a new distro with up to date Python as well...
« Reply #2284 on: Tue, 23 January 2018, 13:30:30 »
Okay, good luck, and let me know if you find anything wrong with my stuff.  I'm always eager to squish bugs.
« Reply #2285 on: Tue, 23 January 2018, 16:14:17 »
All good - after upgrading dfu-programmer (which did nothing) force erasing the already erased board made it flash happily.  Strange that the unused board behaved exactly the same...
As for bugs can I just check how layers are supposed to work?  I thought the FN to return to the default layer was supposed to match the current layer, but putting a Toggle FN3 on layer 3 which is accessed using a Normal FN3 locks the board on layer 3, while FN2 returns to the default layer.  As-is there is no way to reliably return to the default layer from a layer that is accessed from two different toggled layers.
Not sure that makes any sense written out but it could be a problem if you're looking for something to fix, I've added pics below which might help explain it.
« Reply #2286 on: Tue, 23 January 2018, 19:46:46 »
i'm having trouble following.  Let's take it one step at a time.
  • Start on default layer (L0)
  • Press Fn to activate Fn Layer (L1)
  • Press Fn2 to activate and lock L2
  • Release Fn2
  • Release Fn
  • Press Fn3 to activate L3
  • Press Fn2 to activate and unlock L2
  • Release Fn2
  • Release Fn3
  • L0 should now be active
Is that right?
« Reply #2287 on: Wed, 24 January 2018, 04:39:37 »
Yes that's how it works and when you put it like that it sounds like it's by sensible design.  I guess I misunderstood long ago - hopefully I didn't pass the bad knowledge on!  I thought it was:
7. Press Fn3 (current layer) to unlock all and return to L0
The 'problem' is that L1 and L3 are the same and only duplicated so the 'swap layer' button works.  I was going to add two number pad layers for the same reason - 'back' needs to go to L0 or L2.  This seems such a waste of layers, literally halving what's available.
I don't suppose the firmware knows the layer that was locked before the current one so you could add a 'previous layer' keycode?  Not sure how many people would use it...
The more I think the more it sounds like I should just make the jump to Colemak, adding the qwerty layer as a backup with no helpful layers so I can enter passwords using keycap legends when drunk rather than locking myself out :))
« Reply #2288 on: Wed, 24 January 2018, 08:34:00 »
In EasyAVR, there are only three layers in memory:
default_layer (usually L0 but can be changed with the config menu)
locked_layer (set when you use toggle or lockable Fn keys)
selected_layer (set when you use momentary Fn keys)
If you lock a layer and then lock a different layer, locked_layer is replaced and the previous locked layer is lost.  If you lock a layer that is already locked, it falls back on the default layer.
This all works great for the way I use keyboards, but if you are used to the Up/Down concept or 'swap layer', it can get confusing.  Basically what you want to do when you permanently select a layer is just use a toggle Fn key for the layer you want.
In your case, the main problem seems to be that there is no Fn0 key and it's hard to picture how to get back to Default.  I really should add that.  People really expect it when moving between permanant layers.
Another unfortunate issue is that the original firmware only had 2 layers: default and Fn.  I wish I could go back and rename them to L0 and L1.  If I remember correctly, I can't just rename them now because saved layouts would break.  I'll look into that too.
« Reply #2289 on: Wed, 24 January 2018, 09:07:15 »
Fair enough - I'm not used to anything as such but now I understand I'll make it work.
If you can change the default layer you really should have an Fn0 though, otherwise you can't use that layer at all - you've found your own bug!
As to the change of layer names couldn't they be substituted during load?  Wouldn't want to do lots of hard coded substitutions but there are only two so could be an option.
« Last Edit: Wed, 24 January 2018, 09:19:46 by suicidal_orange »
« Reply #2290 on: Wed, 24 January 2018, 23:16:59 »
I've made the changes but I still have to test it.
Programming is a good excuse to sit down and listen to some retrowave.  Love me some retrowave.
« Reply #2291 on: Sat, 27 January 2018, 08:09:32 »
New Release 2.06.01
  • Add SCANCODE_FN0 for selecting the default layer if it isn't default
  • Rename SCANCODE_FN to SCANCODE_FN1
  • Python 2.7 is no longer supported, switch to Python 3.6
« Reply #2292 on: Sun, 28 January 2018, 03:18:36 »
Sounds great, except the Python 3.6 bit.  Really must upgrade...
« Reply #2293 on: Sun, 28 January 2018, 08:51:57 »
2.7 still works, I just don't support it anymore.
Offline kamilakas
« Reply #2294 on: Fri, 09 February 2018, 12:33:20 »
Hi, guys. Can someone help me with writing macro like on the screenshot?
« Reply #2295 on: Fri, 09 February 2018, 12:53:31 »
What is that supposed to do?  Are you trying to map a key to Alt+Tab?  If so, you don't need a macro to do that with EasyAVR.
Offline kamilakas
« Reply #2296 on: Fri, 09 February 2018, 13:07:32 »
It must "imitate" Alt+Tab then pressed Alt. It's the shortcut for switching windows in Windows (lol). For example, press this "alt+tab", holding it (keycode is Alt, hold). Then you just press default Tab to switch between windows.
« Last Edit: Fri, 09 February 2018, 13:13:58 by kamilakas »
« Reply #2297 on: Fri, 09 February 2018, 14:03:48 »
Okay there's definitely a language barrier between us.  I think you're trying to either:
1) Map a key to Alt+Tab.
2) Map a key to Alt when held, and Alt+Tab when tapped.
For (1), all you have to do is map the key to Tab, then add a "with modifier" option and select R_Alt.
For (2), that is not currently possible, although it probably should be, and we could add a PR to fix it.
If you want to make a macro of Alt+Tab, you it would look something like this: \ALT(\TAB,)
Offline ErgoMacros
« Reply #2298 on: Fri, 09 February 2018, 14:17:45 »
(I didn't read the code, I could be all wet here) I think what he wants is:
Key #1 behavior:
  On press does Alt-down, Tab-down, Tab-up (and Alt is still down)
  ... on release does Alt-up
   On tap does Alt-down, Tab-down, Tab-up, Alt up
Key #2: Normal Tab key behavior.
Use:
  Key #1-Down and release generates Alt-Tab down and Tab-Alt up == Switch to next app (using a single tap)
  Key #1-Down, Key #2 tap, Key #2 tap, Key #1-up == Switch to next app + 2 (with a hold and 2 taps.)
Unusual, perhaps, but it you swap between the 2 front-most apps a lot it would add efficiency, while not eliminating the ability to get to other apps.
« Last Edit: Fri, 09 February 2018, 14:29:34 by ErgoMacros »
Today's quote: '...“but then the customer successfully broke that.”
« Reply #2299 on: Fri, 09 February 2018, 14:46:33 »
Oh, yes, I think you're right.  That makes sense.
This is not currently possible with EasyAVR.  The problem is getting one key to act as a modifier and a macro at the same time.  Just describing that kind of behavior in the GUI is hard to imagine.
