Author Topic: Easy AVR USB Keyboard Firmware and Keymapper  (Read 2186895 times)
Re: Easy AVR USB Keyboard Firmware and Keymapper
« Reply #850 on: Mon, 20 April 2015, 07:34:40 »
New beta posted.  Just bug fixes.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #851 on: Mon, 20 April 2015, 08:08:18 »
Flip now works...
But which device do I load?
Any hint on how to find the correct one?
Should I check for the ATmega32U4 device that Acanta used for his KMAC?
EDIT: Nope, that gives me an "atlibusbdfu.dll not found" error.
It's ATmega32U4.  You need to install the DFU driver.  Put it into boot mode, go into device manager, right click the bad device and choose update driver.  Then select find your own driver and go into the Flip install directory to get it.  If possible, please take screenshots and post them, I want to make a HOWTO
It works! Thanks for the help. :)
Leds aren't working though so I have to try again in the future.
Made a quick Album for the how to. Keep in mind that some of it is in Dutch but I think it should be clear enough. :)
Links used:
- LightSaver opening post
- HOWTO: Program your KMAC
- Easy AVR USB Keyboard Firmware and Keymapper
« Last Edit: Mon, 20 April 2015, 08:11:25 by JaccoW »
|||My other keyboards :
x
« Reply #852 on: Mon, 20 April 2015, 08:14:02 »
AWESOME.  You only have to do this once so I've never been able to go back and take screenshots.  Thanks, dude.
As for the LEDs, they work on my Orion, although I haven't tested the newest build.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #853 on: Mon, 20 April 2015, 08:26:58 »
No problem. It's the least I could do. :thumb:
Turns out I forgot to assign a key to change the LEDs. But that was an easy fix after all this. ;)
Having Ctrl on CapsLock feels a whole lot better. <3
« Last Edit: Mon, 20 April 2015, 08:29:11 by JaccoW »
x
« Reply #854 on: Mon, 20 April 2015, 14:27:07 »
New beta, new error :(
Error: list index out of range
I guess the layouts won't be changing so I can try and test doing that?
« Reply #855 on: Mon, 20 April 2015, 14:40:09 »
Do you get that error even when starting from a new layout?
« Reply #856 on: Mon, 20 April 2015, 14:44:27 »
Yeah, just went with default handwire and added a couple of random keys.  Not going to spend a long time on a layout until it works :)
« Reply #857 on: Mon, 20 April 2015, 15:14:17 »
I guess it's time I actually tested the damn thing, eh?
« Reply #858 on: Mon, 20 April 2015, 15:20:32 »
If you like :))
« Reply #859 on: Mon, 20 April 2015, 17:10:58 »
I have a new idea. What if the pins were also configurable?
« Reply #860 on: Mon, 20 April 2015, 17:22:16 »
Not a bad idea, would have been a great one before I wired up your specifications despite them not matching the physical layout at all yesterday :-\
Offline RavenII
« Reply #861 on: Mon, 20 April 2015, 17:51:18 »
metalliqaz, does this version have the fix you included for the issue I found?
« Reply #862 on: Mon, 20 April 2015, 20:08:01 »
I can't remember which that was, but the latest version should include all fixes.
« Reply #863 on: Mon, 20 April 2015, 20:47:37 »
Another day, another bugfix release.
« Reply #864 on: Tue, 21 April 2015, 02:25:19 »
It works!
Thanks metalliqaz, will do my layout tonight :)
Offline vicibz
« Reply #865 on: Tue, 21 April 2015, 11:26:54 »
Cool! I just gave it a go for my custom keyboard (which I have working with tmk) but could not make it work :(
I think I got it right:
- Changed the pin assignment in cfg/handwire_hardware.cfg. I had to remove a couple of cols and both leds.
- Made the layout in AVR look like my matrix.
Result after flashing: keyboard unresponsive.
Any other custom keyboards around with AVR working?
« Last Edit: Tue, 21 April 2015, 11:29:03 by vicibz »
« Reply #866 on: Tue, 21 April 2015, 11:41:22 »
Did you read the section about diode direction? That could be it.
You're using a Teensy?  If you want me to try troubleshooting, you could send me yourTMK matrix file and I could give it a shot.
Offline vicibz
« Reply #867 on: Tue, 21 April 2015, 11:55:31 »
Yes, it's a Teensy 2.0.
I just read about diode direction, and it could be this.
I soldered the diodes exactly like matt30 did: http://static.cubiq.org/uploads/2014/03/VcSDW6r.jpg
« Reply #868 on: Tue, 21 April 2015, 12:55:01 »
My custom numberpad works.  It's upside-down, but it works :))
« Reply #869 on: Tue, 21 April 2015, 13:56:47 »
Thats easily fixed.  Just reverse the row order
« Reply #870 on: Tue, 21 April 2015, 17:10:18 »
It's sideways in the editor anyway as the Arduino only has 5 rows and the pad has 6, it's not so bad having the top on the right rather than the left as long as I remember.  Would be easier if there was a way to add a space as there is physically, but everything I try seems to hide 1/4 of a key under the next one.  Is there a way to do it without having an empty row's keys to manipulate?
Gap or not it works and that's the main thing so thanks for all your work :)
Offline Photoelectric
« Reply #871 on: Tue, 21 April 2015, 21:14:18 »
Any chance this firmware works for KMAC Happy?  It's not explicitly listed on the supported list.
Looking at the software, it's probably a no...  I can load an 87-key KMAC layout, but I'm not sure a customized version of that would translate properly to the KMAC Happy firmware.
« Last Edit: Tue, 21 April 2015, 21:27:24 by Photoelectric »
« Reply #872 on: Tue, 21 April 2015, 21:50:30 »
I can port it to the happy.  The handwire could never work.  KMAC needs a port.   Honestly, though, I wouldn't be surprised if the regular KMAC firmware works.  Those guys like to reuse designs.  Ill look into it
« Reply #873 on: Wed, 22 April 2015, 00:24:13 »
That would be excellent!  Thank you!  I've put your firmware into everything I could so far :)
« Reply #874 on: Wed, 22 April 2015, 08:35:12 »
Seriously, try building a KMAC binary and loading it.  I'd like to know how it works.
« Reply #875 on: Wed, 22 April 2015, 10:12:10 »
Using an 87-key KMAC layout and ignoring the function layer and such?  I thought normally the function layer would start at column 0 row 0, not the number row (as is the case with KMAC Happy).  I just don't want to mess up the alignment.
« Reply #876 on: Wed, 22 April 2015, 11:02:29 »
Im just curious how close the hardware is.  It will never work completely.
« Reply #877 on: Wed, 22 April 2015, 11:08:53 »
What do you mean by the last sentence?  This is not my personal keyboard--something I'm modifying for a friend--so I'd love for everything to work properly before I return it.
« Reply #878 on: Wed, 22 April 2015, 12:38:02 »
Adding new hardware support is a process.  code-build-test, code-build-test, until it works.  When I don't own said hardware, I require a partner who does in order to test.  Most builds take at least two tries before I get it right.  If you can help me support the KMAC happy by testing, that's great, I love adding new support.  If you won't have the board for long then it probably won't work out.
For the first test, I was wondering how close the (known) KMAC and (unknown) KMAC happy designs are.  That build would never work right, but it could give me some good information.  Then I could go start coding a firmware that does work right.  It takes a certain amount of savvy to work this process, because you have to have a backup firmware ready to program when my first few builds inevitably fail.  I'm working blind here!
« Reply #879 on: Wed, 22 April 2015, 13:37:36 »
Sure, I'd be glad to get it working.  I'll message you later today or write here.  In the meantime, how should I proceed with creating a test layout?  Do I use your default 87-key KMAC layout within the software or how should I proceed?  I think I have the original KMAC Happy firmware file downloaded (but not tested) from some of Litster's old links.  Thank you.
« Last Edit: Wed, 22 April 2015, 13:40:16 by Photoelectric »
« Reply #880 on: Thu, 23 April 2015, 17:16:46 »
I just downloaded on another machine and there's a new version which allows completely custom matrix - very nice!  Seems you're done for a while so here's a feature request - can it have a dynamic number of LED slots too?  On a small board there are plenty of gaps in the matrix wasting pins which could be used for layer indicators :)
« Reply #881 on: Thu, 23 April 2015, 18:43:18 »
It can't.  The baseline binary is stuck at 6x17x2
Offline Hzza
« Reply #882 on: Fri, 24 April 2015, 04:34:07 »
I was having a play with the new tap keys function and either I'm misunderstanding what it does or it doesn't work...
I'm trying to get it set up so that my up/down/left/right arrows produce pg up/pg down/home/end on tap. I've tried both ways around (up arrow with pg up on tap and pg up with up arrow on tap) and both ways around the tap key doesn't work.
Am I doing something daft or is it the firmware not working? (I downloaded a fresh file from the OP last night I think, I can give you a revision number when I'm back at home, trying to get this working on the Six Shooter).
« Reply #883 on: Fri, 24 April 2015, 05:42:22 »
If you really dig in to the docs, you will see that tap keys only work on modifiers.  I can't think of a real scenario in which you'd actually use that configuration. Remember that if it was implemented and you tapped that key, you'd get one 'down' press and one 'pgdn'  press.  Dual use keys don't disable the primary use, even when tapped.
Offline Hzza
« Reply #884 on: Fri, 24 April 2015, 05:47:56 »
Ah ok, it wasn't doing what I thought it was then, thanks for the explanation.
« Reply #885 on: Sat, 25 April 2015, 12:23:45 »
If you're bored at any time it might be worth making a smaller version with more LEDs, maybe 6x15?  I know I'd use it :)
Also would it be possible to assign an implied mod to a whole layer at once?  I'm thinking shift and backspace = delete but that would need a layer with all the other keys being their shifted versions.  Not too bad on a JD40 but it would be tedious to do a 60% layout...
« Reply #886 on: Sat, 25 April 2015, 12:35:02 »
You can add Shift to the Fn key.  That will shift the whole layer, unless you are toggling.
« Reply #887 on: Sat, 25 April 2015, 12:48:58 »
Ooh clever!  Thanks :)
« Reply #888 on: Sun, 26 April 2015, 11:21:53 »
Forgot to answer this.  Of course it's possible but I'm not sure how far I can go with this.  Everyone seems to have slightly different needs and it's impossible to support them all.  I think I need to collect some data points.
« Reply #889 on: Sun, 26 April 2015, 21:52:46 »
Just to float this out there: The Pegasus Hoof, which fits into the TKL Filco MJ2, also fits into the Filco Zero.
« Reply #890 on: Sun, 26 April 2015, 22:01:03 »
Cool. Is the matrix the same?
« Reply #891 on: Sun, 26 April 2015, 22:02:33 »
I really hope so. I'll let you know if it works for me after I do the switch swap. esoomenona and bpiphany seemed to think it would work just fine so I"m hopeful it will work out fine for me.
Offline Hzza
« Reply #892 on: Mon, 27 April 2015, 03:21:11 »
I'm pretty sure I put my HID liberator in my Zero way back when and it worked OK.
Offline Pitrek
  • deskpads gallery
    • deskpads gallery
« Reply #893 on: Wed, 29 April 2015, 15:16:45 »
Can you build .hex file for me? I need firmware for 2-switches keyboard. (Z, X)
There isn't default setup + i can't build it on my own. Thank you!
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #894 on: Wed, 29 April 2015, 17:01:54 »
... ok how are you putting alps/matias switches on a Filco PCB?
« Reply #895 on: Wed, 29 April 2015, 17:16:07 »
The zero is an alps board.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #896 on: Fri, 01 May 2015, 07:47:44 »
Is there a way to have the LEDs default mode be "ON"? Whenever the my pc goes into hybernation it switches off and I need to turn it on by cycling through the mode key 15 times. :P
x
« Reply #897 on: Fri, 01 May 2015, 10:25:24 »
You want to set the default backlight enable.  It's a setting in the config console.   For more information, use the Help menu in the keymapper.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #898 on: Thu, 07 May 2015, 12:58:43 »
Finally got around to trying this again. Cool way of doing this. :)
x
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #899 on: Thu, 07 May 2015, 13:21:56 »
Do you remember the state this was in for the JD45?  Mine comes up fully lit, and the lighting level scancode doesn't appear to do anything.
 - Ron | samwisekoi
(Auto-typed by my JD45 keyboard.)
