Author Topic: Blank home keys with "nibs"  (Read 5742 times)
Offline Arbalest
« on: Fri, 22 November 2013, 14:35:15 »
Are blank keys available with the home key bumps?
Are people making their own bumps?  How?
I added a little super glue to the bumps on my non-blank home keys so as to feel them better. It works but it looks a little ugly, although I can live with that. But I don't want to mess up a new set of blank caps.
Offline regack
Re: Blank home keys with "nibs"
« Reply #1 on: Fri, 22 November 2013, 14:48:01 »
You should be able to find those, if not at Signature Plastics I know you can get them at WASD.  I'm sure some of the vendors could get them as well.
« Reply #2 on: Fri, 22 November 2013, 14:51:31 »
Signature Plastics has some blank DCS-profile PBT keycaps with homing bars:
From: http://www.keycapsdirect.com/inventorypdfs/DCSPBTInventory.pdf
302588 DCS - 1X ROW 3 HOMING BAR - BLUE (BCT) PBT 101
300646 DCS - 1X ROW 3 HOMING BAR - BRIGHT WHITE (WFJ) PBT 88
212018 DCS - 1X ROW 3 HOMING BAR - CREAM (WBK) PBT 730
302919 DCS - 1X ROW 3 WITH HOMING BAR - LIGHT GRAY (GRA) PBT 431
You can order from here: http://www.keycapsdirect.com/key-capsinventory.php
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Fri, 22 November 2013, 22:13:10 »
0.o super glue to keycaps.
Offline bedrift
« Reply #4 on: Fri, 06 December 2013, 10:25:48 »
I'm also asking for suggestions how to make more prominent home key bumps.
I'm using a laptop so I would rather not change the key caps. I don't mind making them a little messy. Is glue the way to go, is it really healthy to touch glue all day long?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 06 December 2013, 11:55:29 »
Get some round head finishing nails, get it hot and press it through the keycap, then clip off the excess length... you could have something like this:
Offline daerid
    • Rossipedia
« Reply #6 on: Fri, 06 December 2013, 13:32:49 »
I cannot believe they don't have black ones.
I've been doing fine using deep dish DSA for my F and J keys on the ErgoDox. But still, homing nubs would be much better.
Offline Phagocytosis
« Reply #7 on: Fri, 06 December 2013, 14:09:43 »
wow this is a smart and simple DYI
Leopold TKL - Ghetto Green
Apple Extended II - Orange Alps
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #8 on: Fri, 06 December 2013, 20:43:16 »
wow thats really clever.
"Obviously, windows are central to Windows. But what is a window?"
Offline TheHydroMule
« Reply #9 on: Sat, 14 December 2013, 02:40:19 »
Hey are these your keys? Mind showing what the inside of ones that have the nail look like so I can get a better idea of what to do? That or a step by step would be cool
HAVE: KBT Pure Magenta LED | CM QFRapid
« Reply #10 on: Sat, 14 December 2013, 10:17:08 »
No I don't have that. It only gave me the idea.
Offline 0100010
  • Not Sure
« Reply #11 on: Tue, 17 December 2013, 22:28:14 »
Unicomp blank PBT BS key sets have the three (F / J / 5) keys with nubs included.  Always figured every key set would?
