Author Topic: Chicony 5181 and 5161 with new switches  (Read 6312 times)
Offline 8ax
« on: Sat, 23 November 2013, 07:00:29 »
Hi, I just bought a Chicony KB-5181 and KB-5161 for $10, and I've gotten switches I that aren't mentioned in the wiki.
I'll open them up later.
KB-5181: Cherry MX Black? I was kinda disappointed to see that it didn't have Monterey Blues.
KB-5161A: Alps White or Cream? Feel really crappy, they need lubing. EDIT: PCB only says 'Chicony Copyright 1987'.
Also, doubleshots.
« Last Edit: Sat, 23 November 2013, 07:22:27 by 8ax »
Offline AKIMbO
  • HHKBro
Re: Chicony 5181 and 5161 with new switches
« Reply #1 on: Sat, 23 November 2013, 07:26:20 »
5161 is mitsumi switches
| KBD75 (box reds)
Offline 8ax
« Reply #2 on: Sat, 23 November 2013, 07:28:37 »
Interesting.
Is it worth anything?
« Reply #3 on: Sat, 23 November 2013, 10:43:00 »
Be careful with those metal Mitsumi switches. They can break easily, even from just pulling a cap off.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sat, 23 November 2013, 12:01:38 »
The only thing that is consistent about Chicony 51*1 keyboards is they are not rubber domes. They can have any kind of MX, Alps, Monterrey, SMK, Futaba, Mistsumi... clones of any of the previous. Keycaps can be lasered, pad printed or sometimes doubleshot. There is no way of knowing what you might get unless you can get seller to verify first. For some inexplicable reason they seemed to have simply used whatever was available to them at the time and couldn't be bothered to change the model number.
Personally I would retrobright up the doubleshots and put them MX one. It has some nice vintage blacks on there.
Offline 8ax
« Reply #5 on: Sat, 23 November 2013, 13:19:53 »
Yeah, I was thinking about doing that since I don't have enough free time to lube the Mitsumis, however, the doubleshots are slightly shorter/lower profile than the original ones, I hope that won't become a problem.
« Reply #6 on: Sat, 23 November 2013, 15:11:55 »
Doubleshots look like Cherry profile, so they should be totally fine.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Sat, 23 November 2013, 16:57:48 »
Also, doubleshots.
vintage blacks can be very nice!
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #8 on: Sat, 23 November 2013, 18:57:38 »
@8ax: Does the 5161A say "NKEY" on the PCB anywhere? Does it have diodes? Are you able to get 6KRO (if using PS/2 to USB) or NKRO (if using PS/2) from it using something like Aqua's Key Test?
The other 5161A keyboards that I've seen specifically state "NKEY" on the PCB, and it would be nice to know for sure that this one is also NKRO (in case the 'A' means something else).
(I didn't even realise you'd posted about this here: this forum is not related to the wiki you posted the details on, which is why I sent you a PM at Deskthority regarding references for the wiki updates, and I had forgotten to check GH all day >_<)
Bore Awards
Offline terran5992
  • One With The Cup Rubber
« Reply #9 on: Sat, 23 November 2013, 20:59:44 »
Also, doubleshots.
Care to elaborate?
Offline 8ax
« Reply #10 on: Sun, 24 November 2013, 08:42:00 »
I'll open it up later today; I haven't been able to check the rollover since I don't have a PS/2 converter yet.
Also, I totally forgot about my Deskthority forum account...
« Last Edit: Sun, 24 November 2013, 08:45:09 by 8ax »
