Author Topic: Buckling Spring Caps Comparison  (Read 2632 times)
Offline Michael
  • Formerly Bro Caps
« on: Sun, 24 November 2013, 15:27:46 »
So what exactly makes these incompatible with one another? (as I have been told).
Is the barrel larger for the M series versus the M15?
Re: Buckling Spring Caps Comparison
« Reply #1 on: Sun, 24 November 2013, 18:42:06 »
I have never had an M15 but I have had a couple of M2s.
First, with standard Model M/Fs, all stems are the same and all caps have the same profile (and they will fit M2s/M15s).
The M2s (and, presumably M15s) have differing profiles, and different stabilizers, so there is no direct interchangeability, although you can make a standard stem work in a pinch.
- Oliver Willis 2026-08-01
Offline 127001
« Reply #2 on: Sun, 24 November 2013, 19:36:20 »
I haven't really been brave enough (had the time) to take keys out of my M15 yet unfortunately.
Offline AKIMbO
  • HHKBro
« Reply #3 on: Sun, 24 November 2013, 21:02:26 »
They look interchangeable to me.
| KBD75 (box reds)
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Sun, 24 November 2013, 21:30:49 »
They arent? Have you tried yet?
Offline Michael
  • Formerly Bro Caps
« Reply #5 on: Sun, 24 November 2013, 21:44:51 »
I don't have a regular M or F right now to test it.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #6 on: Mon, 25 November 2013, 17:31:34 »
Hi all,
Just caught this topic.
There are a few reasons why standard M's and M15 keys are not that compatible but here are the two most important ones:
1) As is evident in the OPs photos you can see that the M's stem is longer than the M15's. That right there is the main reason.
2) Offset, the M keys have a different offset (front to back) than the M15 keys.
So what exactly can you do with them in stock form you ask?
Well you can put either one on either keyboard, but... only one will likely work
M15 keys don't work on M's without modification
M keys work on M15 boards but they are hella loose and fugly but will register keypresses, with some occasional binding. They are too tall and they twist more than Chubby Checker. They will also sit too far forward and likely wont comfortably fit the "top" cap. But the inner stem cap will fit, but again they will be leaning/shifting far forward. M keys are also bigger not only in height but in girth in general. It's footprint is larger.
For the TL;DR crowd
M15 on M, LuLz, turtle head stance, no dice.
M on M15, if you're into psychedelic drugs go for it!
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline Michael
  • Formerly Bro Caps
« Reply #7 on: Mon, 25 November 2013, 17:33:10 »
Hi all,
For the TL;DR crowd
Excellent, thank you for that.
Offline 127001
« Reply #8 on: Mon, 25 November 2013, 17:35:38 »
Good to know, thanks.
