Author Topic: Help Opening Keycool 84?  (Read 1350 times)
Offline Pacifist
  • on hiatus
« on: Sun, 24 November 2013, 17:19:24 »
I decided to open up my keycool 84. Removed the do not remove sticker, and nothing was below that. Removed the sticker with the information about the board, and nothing. Tried to pry the little tabs holding the case in, and couldn't get both sides to open. Anybody know how to open the keycool 84?
EDIT: You need to pry off one side of the tabs then the other to open it. No screws, the top case holds the bottom case and plate together.
« Last Edit: Sun, 24 November 2013, 17:28:12 by Pacifist »
