Author Topic: Need help finding a set  (Read 2921 times)
Offline Emrys
« on: Sun, 24 November 2013, 17:42:29 »
Where can I begin to look for a set like this in thick pbt's instead of wasd's abs keys?
Would like to have my poker 2 look like this someday  :)
Offline acidtrip69
Re: Need help finding a set
« Reply #1 on: Sun, 24 November 2013, 18:04:54 »
you can try imsto ^_^ they have great pbt keys
« Last Edit: Sun, 24 November 2013, 18:29:31 by acidtrip69 »
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #2 on: Sun, 24 November 2013, 18:10:00 »
Very expensive (IMO), but Originative has something quite similar: http://www.originativeco.com/collections/keysets-1/products/bsp-classic-beige
« Reply #3 on: Sun, 24 November 2013, 18:11:18 »
wouldn't fit his poker, 1.5mods and stepped capslock
  • Cherry Peasant
  • keycult.com
« Reply #4 on: Sun, 24 November 2013, 18:12:56 »
Ah, yep. Still learning ;).
« Reply #5 on: Sun, 24 November 2013, 18:17:25 »
IMSTO probably has something.  Also you can sometimes find PBT white/grey sets on eBay.  This one is close, but red legends.
Offline terran5992
  • One With The Cup Rubber
« Reply #6 on: Sun, 24 November 2013, 21:34:20 »
You should mention that you want a white/gray 2 tone keyset
« Reply #7 on: Sun, 24 November 2013, 21:53:41 »
is that not clear enough from the picture?
Offline Wildcard
  • When caffeine isn't enough
« Reply #8 on: Mon, 25 November 2013, 00:19:30 »
Isn't that just Feng's ebay store for selling IMSTO caps :)
Offline terran5992
« Reply #9 on: Mon, 25 November 2013, 00:38:32 »
I guess if he needs help with the name of the set
