Author Topic: How to stop getting stuff in "Show new replies to your posts"  (Read 1859 times)
Offline Arbalest
« on: Tue, 26 November 2013, 14:41:42 »
I added something to the Simple Questions topic now every time anyone contributes to that entire thread it shows up when I click on "Show new replies to your posts".
Is there a way to stop this?
I would want to know if someone is responding to my post -- but not everything else added there.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: How to stop getting stuff in "Show new replies to your posts"
« Reply #1 on: Tue, 26 November 2013, 14:43:22 »
hahahahahahaha
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #2 on: Tue, 26 November 2013, 14:46:04 »
Try the "unwatch" button at the top of the page?
Offline Tym
« Reply #3 on: Tue, 26 November 2013, 14:47:19 »
I'm guessing you want to see just what people post in direct reply to you? (as in quote you?) If that's what you want there isn't that option here (at least what I know of) But that would be pretty useful.
Offline Moosecraft
  • HHKB Pro
« Reply #4 on: Tue, 26 November 2013, 14:48:58 »
Then again people might answer you without quoting your post.
Offline Tym
« Reply #5 on: Tue, 26 November 2013, 14:51:06 »
Yeah I thought that, would be a flaw in the plan. Although maybe a system where I could go
@Moosecraft :P
and it would use the same system the PM thing uses where it links to whoevers name you use.
Offline hashbaz
  • Grand Ancient One
« Reply #6 on: Tue, 26 November 2013, 14:59:56 »
I believe there is an actual reply structure to threads -- replying to a post (via the quote button) is different from replying to the thread as a whole (which creates a new top-level post that can have it's own reply subtree).  IIRC in profile options you can set up to view threads in reply mode (what email clients usually call "threaded mode") or flat mode (what I think everyone uses).
All this to say that it seems like it should be possible to get what Tym is describing.
