Author Topic: Cherry tampoprinted and lasered keycaps  (Read 2657 times)
Offline Chloe
  • Switch Kitten
« on: Tue, 20 January 2009, 06:54:19 »
My G84-4700LUCUS-2 arrived this morning. I am a little disappointed to see the legends look cream compared to the white tampoprinting on my G84-4100PTMGB-2. Also, the casing and keycaps on the G84-4100 are a darker black. The G84-4700 looks a bit washed out. If the box wasn't sealed I would say it had been left in the sun. I'm so fussy. :( I was expecting them to match perfectly.
In this photo you can see the difference but it is more noticeable in person. It is strange that the lasered keycaps on the numpad feels like paint sitting on the keycap rather than coarse etching.
On the plus side the switches don't feel too stiff. I wish it had an LED on the numpad itself.
Offline Chloe
  • Switch Kitten
« Reply #1 on: Tue, 20 January 2009, 10:25:49 »
I took some macro photos of the keycaps. They both have a smooth stone-like texture but I prefer the feel of the G84-4100, it has a little less tack.
Offline lam47
« Reply #2 on: Tue, 20 January 2009, 11:09:39 »
you could try a little toothpaste to get them white again.
Or a TINY amount of tcut.
Would be painstaking though.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline lal
« Reply #3 on: Tue, 20 January 2009, 11:11:39 »
And the G84-4100 texture looks more regular, like a grid. I can understand that you're disappointed because of the (quite extreme) mismatching colors. Such imperfections drive me nuts.
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline Chloe
  • Switch Kitten
« Reply #4 on: Tue, 20 January 2009, 17:18:48 »
I just tried some whitening toothpaste on a cotton bud but it didn't help brighten the lettering. The texture of the keycap around the lettering has become a little shiny. If I do it any more it will be noticeable, which I don't want.
I can't use Rit dye either because the keycaps are thin ABS which will melt too easily.
